Question about Kenmore 800 6983 Electric Dryer
My Kenmore 80 Series electric dryer is smoking, it isn't the lint so does anyone have an answer?
  • 4,102 Answers
Hi, their is 2 possible cause the first and most likely cause is going to be the belt is slipping and getting hot and causing the smoke, this could be due to the belt being loose or the drum bearing may be seizing and could need replacing. try turning the drum by hand to see how easy it is.
now the second problem could be that the motor is over heating due to the drum bearing failing or even the motor itself failing, see how easy it is to turn the drum if its quite easy and feels smooth then the chances are the belt needs replacing, if its stiff to turn or feels rough then this could be drum bearing or motor failing.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Sep 11, 2010
Kenmore 80 series electric dryer does not heat up. No early indications of an issue, just stopped working. Thoughts?
Usual suspects are:
heating element
thermal overload fuse
Dec 15, 2014 | Kenmore Dryers
Why isn't My Kenmore Heavy Duty 70 Series Soft Heat Extra Capacity Electric Dryer drying clothes on any one cycle?
One possibility: Air flow! Make sure that the lint trap is cleaned before each cycle. You likely need to thoroughly clean out the vent piping out the back of the machine- a buildup of lint in here can also restrict airflow.
Sep 04, 2012 | Kenmore 659 Electric Dryer
MY KENMORE 80 SERIES DRYER ISN'T HEATING
remove the entire exhaust vent and clean it thoroughly. Any build up of lint inside of it will cause the moister sensor in the dryer to shut down the burner or grid which ever you have, gas or electric
After cleaning it and it still does not work correctly the sensor is at fault and needs to be replaced
May 17, 2010 | Dryers
Kenmore series 80 dryer, ryns with no heat. i
that is ur glow bar or igniotror that is common,, check ur ignitor, thermal fuse, or secondary gas coils, those are what are usually wrong with no heat on gas dryers
Feb 03, 2010 | Kenmore 62802 Electric Dryer
Kenmore 80 series keeps shutting off. new motor and lint line cle
take off the vent line from the back of the dryer,if it runs fine your vent line is blocked or the outside vent where the flapper opens might have a cage on it to keep animals out of the line,it keeps the animals out but it's a lint trap.if you have a long run use a leaf blower and blow out the vent line,if that's ok check the t-stats on the heater box,
Nov 12, 2009 | Kenmore Dryers
Kenmore Electric Dryer Series 80 110.86980800 burning smell
If this is a new element, this is normal until it has been used a few cycles. Use it and watch it carefully for a while. If it continues have a competent person to take the rear panel off and check for burnt wires or lint inside the unit.
Sep 21, 2009 | Kenmore 62802 Electric Dryer
Kenmore Electric Dryer Series 80 Model
Disconnect the dryer from your vent completely,. pull dryer out 3 ft. from wall and test to see if the smell continues, You have to test for a few minutes to clear out any burning lint from vent restrictions. If the smell hoes away then you know you have venting problems. Also check on the grate that covers the element( the part you look through when you see the orange glow from the element) sometimes plastic or clothing burns onto this grate and needs to be cleaned off. I the smell remains, you will have to tear down the dryer to see if you can find the cause of the smell.
The machine work but no eat
recently we had same problem and guy across street told us to clean out the
exhaust that runs to outside .. it was full of lint and when i cleaned it out the
dryer worked fine
Apr 15, 2009 | Kenmore 62602 Electric Dryer
Kenmore 80 Series Model #110.74842400 Series MR5112733
There's a few things on this dryer that can stop it
from heating. 1st thing your going to need is an ohm meter, your testing simply for continuity. The main items that cause no heat at all on this gas dryer is the igniter on the gas valve, the thermal fuse located on the blower wheel housing the thermal cut out located on the burner box or the flame sensor on the burner funnel and lastly the coils on the gas valve. the sequence is from most too least common. Of course unplug it and shut the gas off.
Jul 30, 2008 | Dryers
Electric dryer
the thermostate is in most cases dryer has the lint screen going in the top its in the back also the thermo fuse is there ck it both one on canister and ck element if is lint screen on the inside remove bottom panel off its all right there
Mar 18, 2008 | Zanussi TC7102W Electric Dryer
Kenmore 800 6983 Electric Dryer Logo
222 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
