Question about Garden
Honda powerwasher model GC190. 3000 psi, 2.5gpm. The coupling closest to the engine has broken. (female part) I am looking for the part name/number to order a replacement.
  • 905 Answers
The GC190 is actually the model of the engine itself (and a good engine it is). The coupler would have been installed by the manufacturer (still might be Honda), and a model # (and manufacturer name) would be needed to find what you need.
Posted on Sep 11, 2010
Why does my karcher powerwasher starts and dies after 2 minutes
dirty carb , clean carb, install a fuel cut off valve ( or start using it if you already have one) when you are done washing, turn off the fuel valve and continue spraying water until the engine stops. That will empty the carburetor bowl and the carb will stay clean until you want to use it again.
Sep 07, 2014 | Karcher 2500 PSI Pressure Washer
How do i replace water intake line on craftsman powerwasher model 580.752070
https://www.walmart.com/search/?query=190588gs&&adid=22222222224329855348&wmlspartner=wmtlabs&wl0=e&wl1=o&wl2=c&wl3=74629383116912&wl4=kwd-74629453980726:loc-190&wl5=65542&wl6=&wl7={loc_interest_ms%20}&wl14=190588GS&veh=sem
This piece can be replaced. Google model n.umber for parts breakdown. then google part number. prices vary from $75 -$52
Jul 29, 2017 | Craftsman Garden
I have a Blue Max high presure washer, 2200 psi.
Hi Greg. Walk into your nearest Lawn Mower parts supply with your engine model number (usually on the recoil) and they will have the replacement part or repair your old one. It is less expesive to have the old one repaired unless the support struts have broken. 2200 PSI should have a Honda GX160.
engine:
Here is another source....
http://www.northerntool.com/shop/tools/product_200327175_200327175
They can range from $32.00 to $68.00 depending on source.
Honda PN is: 28400-ZH8-013ZA (do net search this number) Or call your local Lawn Mower repair Supply with the number.
If you have a Briggs & Stratton engine I will need the ENGINE model number off of the air shroud just above the spark plug.
Thanks for using FixYa.
Kelly
Apr 05, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
Husky 2600 psi Powerwasher will not start, it was only used once, in 2008. gas was left in the powerwasher over last winter. I followed the 13 steps on hooking it correctly and turning it on etc.. when I...
You may have to take out the carb and get it cleaned / air-blown out. Looks like some little valve is stuck. Also make sure you are getting enough sparks at the plug tip. If you have left it long in a damp place it may take several pulls on the cord for the engine to fire-up and run. Try spraying some WD-40 into the cylinder through the plug-hole. Then pull the cord again. After a few pulls remove the plug again, and put like a spoonful of clean 10/30W engine oil into the cylinder, and keep pulling the cord until you see some smokes at the exhaust. If the engine fires up and run a few minutes, but stops later. The engine might be out due to incorrect oil/fuel misture.
Oct 20, 2009 | Garden
Pink vinyl tube under carburetor has fuel-smelling drip
no look to see if the clamp it on good it may have a pin hole in it best thing to do is relace it any auto store will have it...Good Luck
Aug 16, 2009 | Honda Pressure Washer PSI 3000
Lance
Here is a link where you can look up your exact model and replacement parts from coleman...
http://www.ppe-pressure-washer-parts.com/coleman-powermate-pressure-washer-parts
Looks like your model may be out of production though so here's a generic kit that will 99% work with your washer...
http://www.silverbin.com/FAIP-PowerWasher-Universal-Pressure-Washer-Gutter/A/B000EEQ9KM.htm
Hope that helps...
Feb 09, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Honda 2750i Powerwasher
I had the same problem 3 years old, maybe used 10 times - removed the air filter and the washer started fine. The air filter looked fine - I have not tried to replace it or figure out the root cause. I was just happy to get it running again :)
Aug 09, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
