Question about Brother XL-5600 Mechanical Sewing Machine
Will not stitch correctly stitch length will not change with adjuster
    Genius:
  • 1,788 Answers
Are you maybe stuck between two different stitch patterns? Check your manual for troubleshooting. If, you don't have your manual go to brother-usa.com and download one for free. They also have a frequently asked questions there. 1-800-276-8437 is their customer service help number.
Posted on Sep 11, 2010
Correct tension for fmq
Not sure what you're asking. FWIW, for FMQ, stitch length should really have no affect if you drop the feed dogs. The stitch length is determined by how fast you move the fabric and how fast the machine stitches.
For tension, it is dependent on your particular machine. To make that determination, make up sample sandwiches made of the same fabric and batting as your quilt and practice FMQ and adjusting the tension until the threads meet in the middle of the sandwich. For most of my FMQ, I use a specific bobbin case that has been adjusted and used only for FMQ.
Jan 17, 2018 | Sewing Machines
Singer 7462 buttonholer
try adjusting the size, see if it changes the result and go from there, you might also want to ask other experts, sewing machines are not my speciality.
Sep 28, 2008 | Singer 7462 Mechanical Sewing Machine
Adjusting top and bottom stitches...
the stitch length is set by the amount the foot pulls the material through
adjusting the needle thread tension is the main adjustment to ensure that both threads meet at the center of the materials being sewn
Mar 10, 2017 | Sewing Machines
I have a singer 2868c i cannot get the stitches to lenghten from a tight stich how di i change the length?
The stitch length lever/dial should control that for you. Consult your owner's manual. If it is not changing the stitch length even though you've adjusted it, then it probably needs service.
Feb 13, 2016 | Singer Sewing Machines
Stitch length will not change
Setting Stitch Length: A Quick Look at How and Why ...
www.sew4home.com/.../sewing.../setting-stitch-length-quick-look-how-a...
Mar 3, 2015 - The majority of sewing machines indicate stitch length in millimeters. A 2.4 stitch length means each stitch will be 2.4 mm long. ... When you adjust the stitch length, it's not the needle that is changing, it's the feed dogs (those ...
How to Select Stitch Length ' Sewing Lessons - YouTube
? 2:40
https://www.youtube.com/watch?v=YqwHtYpKBzo
May 31, 2011 - Uploaded by HowcastArtsRec
Learn how to select stitch length when using your sewing machine for ... also not so small that it will take forever to get through your machine.
How Do I Fix My Sewing Machine: Troubleshooting Your ...
www.craftsy.com > Blog Home > Sewing Blog
Jan 24, 2016 | Sewing Machines
The auto stitch isn't working. Also, when I use the Qbot to do a linear design, the stitches are minuscule. Changing the stitch length or speed makes no difference.
The stitch length adjustment may be stuck. You need to manually loosen so the stitch adjustment can work properly. This may require you to open the top lid to locate.
Feb 02, 2015 | Sewing Machines
How do I get the stitch length to be consistent? It changes with speed
consistent stitch length depends primarily on tension settings. there are 2 different tension settings on all machines. 1. upper thread tension. 2. bobbin thread tension. since these work together to create the correct stitch length+width, having either of these adjusted inappropriately can significantly impair stitch quality. "knowing' your machine has a lot to do with knowing how tight or loose the tension should be for BOTH settings. the settings will be different for each type of stitch, for each type of needle used, and for each type of thread used, meaning tensions will need to be re-adjusted after each change. in other words, the setting for a medium-width zig-zag with a size 10 needle using mercerized cotton thread to sew light-weight canvas will be completely different than the settings for a regular straight stitch using a size 8 ball tip needle using polyester thread to sew silky lingerie material.
Jun 14, 2014 | Brother PC-420
The machine isn't making stitches. It's threaded correctly. I have been sewing leather recently and it's been acting up since then. I have cleaned the bobbin area. And have adjusted the tension...
Hello
Adjust the Stitch Length;
To make longer stitches, set the stitch length to a higher number. On many sewing machines, four is the longest possible stitch length and two is average.
To make shorter stitches, set the stitch length to a lower number. At a zero, the sewing machine may not actually make stitches, since the needle will go up and down in one place.
Cut a small scrap of fabric, preferably the same type you want to sew with.
Sew a few test stitches on the scrap. Examine the stitches to make sure they're the length you want.
Adjust the stitch length again as needed.
Jul 12, 2011 | Singer Sewing Machines
How do you adjust the stitch length on Consew 226 R-1?
if it is like the other industrial machines I've used, here is the general principle:
On the machine there is a button with no label. Hold button while turning the handwheel toward you. When you feel the button depressl you can adjust the length. Hold the button in the machine and crank the hand wheel back to decrease the length of ths titch and foward to increase it. I usually put a notch on the fly wheel for my standard length with some nailpolish. Release the button and sew to test the length.
Jun 16, 2009 | Consew 226R-1
Needle Thread breaking after about 30 seconds of quilting
Make sure the feed dogs are dropped (or feed dog cover is on - I can't remember which way this machine works). The stitch length on the machine has no function so ignore it. (I set it to zero so the machine doesn't have to work as hard). Hopefully this is all that's wrong. If not, use a shorter setting for the stitch length on the regulator, oil the hook and move slowly and smoothly.
Jan 18, 2009 | Juki TL-98Q
Brother XL-5600 Mechanical Sewing Machine Logo
99 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
