Question about Passport 8500 Radar Detector
I get laser alerts all the time. Sometimes when the car first starts but also intermittently as I drive. It's been doing this for months. It started giving these false alarms in my Chevy Tahoe and has continued with my new Honda accord, regardless of RPM of the engine. The Passport 8500 X50 is about 3 years old. tls@lhtech.com
  • tls9 Sep 11, 2010
    Yes I hope. I've cleaned the device as instructed so now I just need to test it, to see if the problem goes away.
  • tls9 Sep 11, 2010
    After driving about 70 miles this afternoon and not a single false laser alarm I think your advice has fixed the problem.
    Thank you.
    Brigadier General:
  • 3,917 Answers
Hi
Please check this related link regarding your query :-
http://www.radartutorial.eu/18.explanations/ex10.en.html
Unscrew the three screws, pop the three components apart (it really is a no-brainer since they only fit back together one way. Use canned air to blow everything out and just use the Q-tip on the front window and the parts that looked like the detector window internally.
Please accept the solution if it’s helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 11, 2010
I have a 200 1.6 glxi in thailand, have intermittant engine shut down, electrical as all goes off, sometimes instant re start, back fire, and away, otherwise start off the key whilst rolling, i have c
check the battery terminals and posts are shiny clean and tight. Check for loose wires and other terminals that may be dirty or loose.. Have the fault codes read
Mar 25, 2014 | 1998 Ford Laser
Kf laser 5spd manual 1.6 carb
The idle circuit on the KE and KF Laser carby engines is controlled by the ignition module inside the distributor. The symptoms are intermittent stalling. There are also windings inside the distibutor that should be replaced at the same time as the module because these can short out the module.
Nov 07, 2013 | Ford Cars & Trucks
Intermittent starting
the starter selenoid is most like bad or you could have a short in the wire to your starter causing heat to build. Heat causes battery to not be able to turn the cars engine. waiting lets the resistance to disapear. and the cycle continues
Jun 20, 2010 | 2005 Jeep Grand Cherokee
I WILL BE DRIVING DOWN THE ROAD AND THE ENGINE CUTS OFF
Do you have a big bunch of keys swinging from the ignition switch? Sometimes the weight of lots of keys wears out the contacts in the back of the switch and you end up with an intermittent case of the car dying. Try wiggling the key when you are driving and see if that creates your problem. If that is your problem, the only fix is a new ignition switch. This problem won't give you a code because, so far as the computer is concerned, you have switched off the engine and switched it back on again.
Apr 07, 2010 | 1995 Oldsmobile Eighty Eight
Intermittent grinding noise, mosly in the back (wheel area?)
could be brakes or trans axle. I would need to drive
Jul 20, 2009 | 2002 Chevrolet TrailBlazer
2001 automatic Renault Scenic wont start every time & keeps stall
Possible tdc/crank sensor. this can cause the car to not start and cut out
Jul 07, 2009 | 2000 Renault 181
1998 Volvo S70 stalls intermittently
Have tried getting quality gasoline at a reliable station? It sounds like water in your fuel system. Add a couple bottles of Iso-Heet fuel system dryer everytime you fill up the next few times, and that should cure it.
Feb 20, 2009 | 1998 Volvo S70
8500 Alerts for no aparent reason
Got to the bottom of my false alarming situation. I finally called Escort and discussed the behavior with the technician who immediately concluded the antenna was failling and needed a repair. $30 worth of shipping and about a week later I got my repaired unit back and it works perfectly. Not sure the root cause but I am going to treat it as gently as possible and hope it keeps working, I sure like it better than the V1.
Dec 05, 2007 | Passport 8500 Radar Detector
Passport 8500 Radar Detector Logo
1,571 people viewed this question
Top Escort Vehicle Parts & Accessories Experts
John Nolan
Jason
Steve
Are you an Escort Vehicle Part and Accessory Expert? Answer questions, earn points and help others
