Question about HP Photosmart C5180 All-In-One InkJet Printer
The message is Ink System Failure although I have just installed and reinstalled all new ink cartridges. the machine will not turn off with the power button. I unplug the power source, but it comes back on with the same message. nothing wil make it print. Help!
    President:
  • 1,961 Answers
The problem will not be solve by just unplugging the power cord and plug in again. It will need to be reset to clear the error in your printer.
Follow these steps to make it work normal again.
1. While your printer is on.. disconnect the usb cable from the back of your printer.
2. Remove the cartridges.
3. Wait until the message "Insert Cartridge" display on the control panel.
4. Disconnect the power cord from the back of the printer.
5. Wait for 60 seconds.
6. Plug the power cord at the back of the printer...If printer does not automatically on..press the "Power" button.
7. Reinsert the cartridge and close any open doors of the printer.
8. If prompted to Calibrate, do so..
9. Reconnect the usb at back of the printer...and try printing again..
Please don't forget to rate this answer.
Thank you for using Fixya.
Posted on Sep 11, 2010
Ink system failure
Plz provide the exact error message
Mar 22, 2014 | HP Photosmart C6180 All-In-One InkJet...
The c309g HP Photosmart premium printer says ink system failure what could be the problem and solution?
Are you getting any error messages?
The ink system can fail if the cartridges in the printer are installed incorrectly, if the ink in the cartridge is low or out, or if the cartridges are damaged or not correctly vented.
try to follow the given steps...
--Replace empty or low cartridges
--Make sure the cartridges are installed correctly
----Remove, clean, and reinstall the printhead
**If you need any technical help on printer then you can reach at http://www.vtechsquad.com/printer-support/
Mar 08, 2013 | Office Equipment & Supplies
Ink system failure, everything was fine, i put new ink in just like i have many times before and now it won't print anything, it keeps telling me ink system failure on the monitor
This error usually means you are at the end of the life on the printhead or the printhead assembly has a defect causing it to stop working. You can try removing all of the cartridges with the machine on. once they have all been removed unplug the power cord from the socket (be sure printer is still on!) wait about 30sec-1min. then plug back in. the display will Read out of ink install and an icon for each missing color. Reinstall all cartridges and close cover. it will take a minute or 2 for it to cycle and prime the ink. The display should read ink Sysytem Failure, power down machine. Press Power button to shut down, leave for another 30sec. and then turn back on. If the error displays again you will have to contact HP for in warranty service or replacement options. Note: if you are out of Warranty it is a good idea to shop for a new printer via Costco, Walmart, or an Office Supply Store, it will save you $$$
(a friend had this issue and they were going to sell her a new printer for $30 more than staples plus shipping!)
Feb 18, 2011 | HP Photosmart C7280 Printer
My Brother MFC-685CW Printer Wireless doesn't recognise a new colour cartridge despite having cleaned the printer head. It also is not recognised by the PC despite reloading it. Help!! Troubleshooter...
If the message "NO CARTRIDGE" remains on the LCD after you have installed the ink cartridge(s), it is possible another ink cartridge is empty and needs to be replaced or one or more of the cartridges are not installed properly. Complete the following steps:
  1. Unplug the machine from the AC power outlet, wait approximately 10 seconds and then plug it back in.
    1a. If the display continues to show NO CARTRIDGE, verify the cartridges are installed properly by uninstalling and reinstalling all four ink cartridges. Follow Steps 2a through 2f.
    1b. If "INK EMPTY XXXXX" (Xs = color, i.e. INK EMPTY CYAN) is displayed on the LCD, the specified ink cartridge is empty and needs to be replaced. Follow Steps 2a through 2f.
  2. To resolve an INK EMPTY message or to confirm the ink cartridges are installed properly, complete the following steps:
    2a. Open the ink cartridge cover. Pull the lock release lever(s) down and take out the ink cartridge(s). While you have the ink cartridge(s) out of the machine, verify the cartridge(s) are genuine Brother supplies with the Brother logo embossed into the side of cartridge.
    2b. Reinstall the ink cartridge(s). Lift and push the lock release lever(s) until it clicks into place and close the ink cartridge cover.
    2c. The LCD may then display:
    Did you change xxxxxx? Yes No.
    for the color(s) that was replaced. If this message appears, BE SURE to follow the instructions on the LCD to correctly select Yes or No. Select Yes if you installed a new cartridge(s) to automatically reset the ink dot counter for that color. Select No if you did not install a NEW ink cartridge(s).
    2d. After all the correct selections are made, the machine will then enter a cleaning cycle.
    2e.If the display again shows INK EMPTY XXXX, go back to Step 2 and follow the instructions to install a NEW ink cartridge.
    2f.If the machine did not enter a cleaning cycle and the display continues to show NO CARTRIDGE after reinstalling new genuine Brother ink cartridges, your machine may require service.
If your computer is not recognizing the printer you should uninstall and reload the drivers. You might consider downloading a new driver for your operating system from this site:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_list.html?reg=us&c=us&lang=en&prod=mfc685cw_us_as&Cat=112
I recommend bookmarking thihs site for future reference.
I hope this is helpful. :)
Dec 08, 2010 | Brother Office Equipment & Supplies
I keep getting ink system failure on my d7160 printer
Turn off the machine using the power button, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, press the power button to turn on the machine, wait until the printer prompts that the ink cartridges are missing, then reinstall the ink cartridges. If this doesn't fix the problem you may have to re-prime ink through the system. There is a good explanation of how to do this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Jan 31, 2010 | HP Photosmart D7160 InkJet Printer
HP c6150 all in one error message Oxc19acff Ink System Failure. Replaced Yellow ink cartridge an still receive error.
Turn off the machine using the power button, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, plug the power cord back in, press the power button to turn on the machine, wait until the printer prompts that the ink cartridges are missing, then replace the ink cartridges. If this doesn't fix the problem you may have to re-prime ink through the system. There are instructions for doing this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Jan 30, 2010 | HP Photosmart C5180 All-In-One InkJet...
Ink system failure
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
Dec 11, 2008 | HP Photosmart 8250 InkJet Printer
Hp 3210
Solution
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Apr 16, 2008 | HP Photosmart 3210 Printer
No ink display on brother mfc240c
First make sure that you are using Brother Cartridges, their machines are very sensitive to using generic ink. Put a brand new set of ink in the machine. Pull all the old cartridges out and put all new cartridges in. If this does not resolve the issue contact Brother, they are very good about helping their customers.
Jan 02, 2008 | Brother Multi-Function Center MFC-240C...
Pen failure message from utility
HP tech support suggests cleaning the ink cartridge contacts and the contacts inside the printer for the cartridges. If this does not clear the problem, try replacing both cartridges (color and b/w) with new ones.
Jul 25, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
136 people viewed this question
Seeker5211
Seeker5211
