Question about Samsung SpinPoint P80 SP1604N 160 GB Hard Drive
HDD : SP1604 N Samsung Electronic card has been physically damaged. When I replace the card by the Card of another HDD (Which works), The disk is "Noisy" but does not work. Is there something to do ?
  • hvaudor Sep 11, 2010
    The disk was in in an external box. The card was burned by the alimentation of the box
  • 977 Answers
Hi!
Unfortunately, the disk being "noisy" means that it's also mechanically damaged.
Fixing it is a job for a professional, and can not be done at home (extreme conditions are required).
In order to "rescue" your data from the hard disk, take it to a computer lab which specialized in data recovery (Use the internet to locate the closest place to you).
I should say that did procedure is generally not cheap and the price varies and depends on the HDD conditions...
Good luck,
Pelu.
Posted on Sep 12, 2010
    Master:
  • 497 Answers
Hello, May aI ask how the Samsung Card was damaged? I this a laptop?
Posted on Sep 11, 2010
Memory card
Is it visible in Device Manger? If yes then go to Disk Manger and change the drive letter.
If No then Could be physical card damage
Jan 11, 2014 | Jazz DV-169 Digital Camera
Tip
HOW TO REPAIR CORRUPT MEMORY CARD (S60 MOBILE TIPS)
<br />Physically, memory cards are quite fragile pieces of high <a href="http://www.mannuforall.in/2008/03/symbian-mobile-tips-and-tricks.html#"><span>technology</span></a>, susceptible to damage from various silly things like excessive heat, condensation, strong magnetic fields, physical damage from rough handling and/or bending! (similar to most electronic devices then..)<br /><br />Given the natue of mobile memory card products, they are constantly being taken in and out of some form of interface with a mobile phone, a camera, a laptop, or desktop PC, or a separate memory card reader. The number of different devices they have to be able to interact with is in the thousands.<br /><br />It is not too surprisingly, then that sometimes the state of the file system on the memory card can get damaged.<br /><br />This may happen for a number of different reasons, including:<br /><br />* removing the card from a device whilst an application is trying to read/write to it.. (Just be patient...)<br /><br />* battery drain on a device whilst in use meaning an insufficent voltage failure whilst writing to the card.<br /><br />* a poor implementation of the MMC standard on the device using the card<br /><br />* poor connectivity software drivers on the device or the Windows PC/Mac<br /><br />* physical damage like card or device being dropped, bent, getting wet etc...<br /><br /><br />As often as not, the problem is not terminal for your memory card, but just a software issue ( or in physical terms, it could be called "a temporary disalignment of the all the bits and bytes on the card").<br /><br />The fix for this problem is the same as for any other file storage device (like a floppy or hard drive) with corrupt or invalid file system, namely; re-format the file system.<br /> <br /><br />
on Mar 04, 2011 | Cell Phones
I have samsung e2152 dual sim mobile.i have sd memroy card of 2 gb, my mobile is not dectecting the memory card. pls gv the tips and suggestion to get dected. thank you
just check ur memory card by inserting it on another fone, if it doesnt work there that means u r havin problem in ur memory card rather than your samsung mobile,,, it may happens that your memoiry card is corrept or it may have some physical damage tats y it isw not working.....
well if u r conferm that your memory card is all rite it the problem is in your pfone, so jus take ur fone to the service center to sort your problem out.... regards...
llucky746
May 03, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
Hi, i have the conon 7D with a sandisk memory card. i am a photographer and i just did christmas pictures today for a family. when i got home i tried to put them onto my computer and the computer told me...
It sounds as if your SD card has failed. It may be physically (electrically) damaged. Do NOT put the card in your camera any more, as it could make things much worse.
You may be able to use a disk recovery program to get some or (hopefully) all the files off of the card. Be patient when using any programs like that - they can take several hours or even a couple of days to get the data off of a bad card.
If you are linux savvy at all, you can use the program "ddrescue" to recover the files. It may also work on a Mac in the commandline.
Another possibility is that the card is physically ok, but the filesystem is corrupted. Using a filesystem repair program could work in this case, such as "chkdsk" on Windows, or "fsck" on Linux or Mac.
I had the same thing happen with a 4GB Sandisk SD card back in May and was able to recover 95% of the data using ddrescue. My card was electrically damaged and had to be replaced.
There are also disc recovery companies that will do data recovery from a damaged or corrupted card, but they are quite expensive ($500-$3000, depending on difficulty of recovery).
I do it sometimes for others for reasonable. www.ruelphoto.com
I will also assist you in any way I can and have time for.
Dec 15, 2010 | Canon Cameras
My Samsung 250 GB portable HDD is not recognised now. It was working for last 2 years without any problem. Recently I found my PC infected by "WIN32" & Torjan viruses. It may be the reason. But I tried...
Try connecting it to another computer.
If it does not work, then either the disk-drive has failed,
or the USB-cable is damaged,
or the USB-to-disk-drive interface inside the case has failed.
Is the SAMSUNG still under warranty? (1 year? 2 years? 3 years?)
If so, SAMSUNG will replace it, at minimal cost to you.
Sep 25, 2010 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Error message, need help
1. Turn off laptop, unplug all devices and cables.
2. Flip laptop upside down on towel (avoids scratches)
3. Open the PCI panel (you need screwdriver to fit screws)
4. remove the PCI card inside (probably 3rd party WIFI card)
5. reattach AC/PSU cable and start laptop
6 If it starts properly now, you either had a bad PCI card, or it was improperly installed. You can try installing it again (turn everything off first). Sometimes this error is just from the card getting loose, or oxidation on contacts. Insert and remove it 2-3 times to see if it works then. Let me know.
Feb 12, 2008 | Acer Aspire 5100-5022 Notebook
Biostar Motherboard p4m800-m7a
You may have a HDD Problem Diagnose it using the following. DOWNLOAD HIREN BOOT CD, WRITE THE ISO TO CD THEN BOOT FROM IT http://rapidshare.com/files/33987018/NYU_Hiren_s.BootCD.9.1.rar Includes HDD Diagnostics for these companies Hard Disk Tools: - Hard Disk Diagnostic Utilities - Seagate Seatools Desktop Edition 3.02 - Western Digital Data Lifeguard Tools - Western Digital Diagnostics (DLGDIAG) 5.04f - Maxtor PowerMax 4.23 - Maxtor amset utility 4.0 - Maxtor(or any Hdd) Low Level Formatter 1.1 - Fujitsu HDD Diagnostic Tool 6.61 - Fujitsu IDE Low Level Format 1.0 - Samsung HDD Utility(HUTIL) 2.02 - Samsung Disk Diagnose (SHDIAG) 1.28 - IBM/Hitachi Drive Fitness Test 4.08 - IBM/Hitachi Feature Tool 2.03 - Gateway GwScan 3.15 - ExcelStor's ESTest 3.80 - MHDD 4.6 - WDClear 1.30 - Toshiba Hard Disk Diagnostic 2.00b - SeaTools for Dos 1.08 - HDD Regenerator 1.51 - to recover a bad hard drive - Ontrack Disk Manager 9.57 - Disk Test/Format/Maintenance tool. - Norton Disk Doctor 2002 - a tool to repair a damaged disk, or to diagnose your hard drive. - Norton Disk Editor 2002 - a powerful disk editing, manual data recovery tool. - Active Kill Disk 3.1 - Securely overwrites and destroys all data on physical drive. - HDAT2 4.5.2 - main function is testing and repair (regenerates) bad sectors for devices - SmartUDM 2.00 - Hard Disk Drive S.M.A.R.T. Viewer. - Victoria 3.33 - a freeware program for low-level HDD diagnostics Hope this helps ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 23, 2007 | Biostar P4M800-M7A Motherboard
DVD combo drive not working
Did you set your jumpers correctly? How about using a different power Cable? Different Data Cable? If all fails try diagnosing the problem. DOWNLOAD HIREN BOOT CD, WRITE THE ISO TO CD THEN BOOT FROM IT http://rapidshare.com/files/33987018/NYU_Hiren_s.BootCD.9.1.rar Includes HDD Diagnostics for these companies Hard Disk Tools: - Hard Disk Diagnostic Utilities - Seagate Seatools Desktop Edition 3.02 - Western Digital Data Lifeguard Tools - Western Digital Diagnostics (DLGDIAG) 5.04f - Maxtor PowerMax 4.23 - Maxtor amset utility 4.0 - Maxtor(or any Hdd) Low Level Formatter 1.1 - Fujitsu HDD Diagnostic Tool 6.61 - Fujitsu IDE Low Level Format 1.0 - Samsung HDD Utility(HUTIL) 2.02 - Samsung Disk Diagnose (SHDIAG) 1.28 - IBM/Hitachi Drive Fitness Test 4.08 - IBM/Hitachi Feature Tool 2.03 - Gateway GwScan 3.15 - ExcelStor's ESTest 3.80 - MHDD 4.6 - WDClear 1.30 - Toshiba Hard Disk Diagnostic 2.00b - SeaTools for Dos 1.08 - HDD Regenerator 1.51 - to recover a bad hard drive - Ontrack Disk Manager 9.57 - Disk Test/Format/Maintenance tool. - Norton Disk Doctor 2002 - a tool to repair a damaged disk, or to diagnose your hard drive. - Norton Disk Editor 2002 - a powerful disk editing, manual data recovery tool. - Active Kill Disk 3.1 - Securely overwrites and destroys all data on physical drive. - HDAT2 4.5.2 - main function is testing and repair (regenerates) bad sectors for devices - SmartUDM 2.00 - Hard Disk Drive S.M.A.R.T. Viewer. - Victoria 3.33 - a freeware program for low-level HDD diagnostics Hope this helps
Sep 22, 2007 | Samsung SD 616E (729507925578) Internal...
Again reloading(restarts)
DIAGNOSTICS DOWNLOAD HIREN BOOT CD, WRITE IT TO CD THEN BOOT FROM IT http://rapidshare.com/files/33987018/NYU_Hiren_s.BootCD.9.1.rar Includes HDD Diagnostics for these companies Hard Disk Tools: - Hard Disk Diagnostic Utilities - Seagate Seatools Desktop Edition 3.02 - Western Digital Data Lifeguard Tools - Western Digital Diagnostics (DLGDIAG) 5.04f - Maxtor PowerMax 4.23 - Maxtor amset utility 4.0 - Maxtor(or any Hdd) Low Level Formatter 1.1 - Fujitsu HDD Diagnostic Tool 6.61 - Fujitsu IDE Low Level Format 1.0 - Samsung HDD Utility(HUTIL) 2.02 - Samsung Disk Diagnose (SHDIAG) 1.28 - IBM/Hitachi Drive Fitness Test 4.08 - IBM/Hitachi Feature Tool 2.03 - Gateway GwScan 3.15 - ExcelStor's ESTest 3.80 - MHDD 4.6 - WDClear 1.30 - Toshiba Hard Disk Diagnostic 2.00b - SeaTools for Dos 1.08 - HDD Regenerator 1.51 - to recover a bad hard drive - Ontrack Disk Manager 9.57 - Disk Test/Format/Maintenance tool. - Norton Disk Doctor 2002 - a tool to repair a damaged disk, or to diagnose your hard drive. - Norton Disk Editor 2002 - a powerful disk editing, manual data recovery tool. - Active Kill Disk 3.1 - Securely overwrites and destroys all data on physical drive. - HDAT2 4.5.2 - main function is testing and repair (regenerates) bad sectors for devices - SmartUDM 2.00 - Hard Disk Drive S.M.A.R.T. Viewer. - Victoria 3.33 - a freeware program for low-level HDD diagnostics Hope this helps ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 21, 2007 | Microsoft Windows XP Professional With...
Hardisk cant be detected
hard disk can't detected by bios.i also can't format my laptop because of it can't detect my hard disk
Sep 21, 2007 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
Samsung SpinPoint P80 SP1604N 160 GB Hard Drive Logo
190 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
