Question about Kenmore Sewing Machines
The bobbin keeps tangling up under the plate - Kenmore Sewing Machines
    Genius:
  • 1,788 Answers
Totally rethead your machine, and use a new needle. Make sure that your bobbin is inserted correctly.
Posted on Sep 11, 2010
Thread keeps getting tangled in bobbon and wont sew
try changing the needle
rethread using EVERY thread guide
make sure the thread has not come off the thread take up lever
make sure the bobbin is inserted the right way--counter clockwise
make sure the bobbin case is inserted correctly if it's a side or front loading bobbin
clean in the bobbin area and under the needle plate
Dec 15, 2014 | Sewing Machines
Baby lock pro BL40, bobbin thread tangles, tried new bobbin, cleaned under plate, needle is straight, what to do?
make sure the bobbin is turned the correct way in the bobbin case
make sure the top thread has not come off the thread take up lever
could also be a timing problem
Jul 28, 2014 | Sewing Machines
Husqvarna Viking Designer Diamond I get the following error code: Remove any thread under the stitich plate and in bobbin area.
Can you get any other codes in the window or is this the only one that keeps showing up? You may need to put a new needle and bobbin in as they may have been damaged even slightly when things got tangled. Kate
Feb 04, 2014 | Husqvarna Designer I
My machine will sew one or two stitches then the threads get all tangled under the plate. appears to be the top thread, not the bobbin
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Aug 20, 2013 | Baby Lock Ellure
It keeps getting tangled up here the bobbin is underneath and keeps getting jammed
try changing the needle--make sure it's the correct one for the fabric
being sewed
rethread the machine ---using every thread guide
try using a different bobbin
try turning the bobbin over the other direction
clean under the needle plate and in the bobbin area for lint
also could be a timing problem and the machine would need to be
checked at a sewing machine repair shop
Apr 12, 2013 | Singer 3116 Simple
How do I fix error E4 whe no thread is tangled?
rethread the machine top and bobbin
make sure the bobbin is turned the right way in the bobbin case
also possible that something has gone wrong with the computer
part of the sewing machine.
Nov 30, 2012 | Sewing Machines
Why is my brother sewing machince lower thread tangle
make sure the bobbin is wound correctly and not over wound
Nov 29, 2012 | Brother Sewing Machines
Thread is getting tangled in the bobbin chamber of my brother xl3125 when I sew. When I pull the fabric out, several strands come out of the bottom and the bottom side of the sewing is tangled and loose. ...
try these suggestions
change the needle
rethread the machine top 7 bobbin ---make sure the presser foot is in the up position before rethreading--use every thread guide
clean under the needle plate & in the bobbin area for lint
make sure the bobbin is turned the right way in the bobbin case & that
the bobbin is not over full
Sep 27, 2012 | Brother Sewing Machines
My 6440 Viking keeps knotting up on the underside..it will take a few stitches ..lock up..and when I remove the fabric the upper thread is all tangled up in the throat plate..can you help me..I have t
rethread the machine top & make sure to use every thread
guide
& make sure the bobbin is inserted correctly into the bobbin
case
clean under the needle plate & in the bobbin area for lint or
threads
make sure the top thread hasn't come off the thread take up
lever
Aug 14, 2012 | Husqvarna Sewing Machines
Thread breaks
Hi!
Check to see if the lower thread be tangled. Also, the bobbin could be threaded improperly in the shuttle hook. Rethread the bobbin in the shuttle hook.
How to detangle a thread---
  • When a machine stops operation due to tangled thread, do not turn the pulley by force.
    If the pulley is turned by force then, lower thread might not be picked up correctly and stitches might not be formed correctly.
  • If threads get tangled, remove a needle plate and cut the tangled threads by scissors or cutter.
  • Do rate the solution if you find it helpful & useful.
    Thanks
    Rylee
    Jan 30, 2009 | Husqvarna Viking 1
    Sewing Machines Logo
    Top Kenmore Sewing Machines Experts
    Tally Girl
    Tally Girl
    Irene Tulloch
    Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
