Question about Microsoft Xbox 360 Console
Open and close tray - Microsoft Xbox 360 Console
  • 4,102 Answers
Hi, the problem could be down to one of a couple of things the first and most commone is a dust build up on the runners inside the tray sometimes knocking on top of it would read the games for about 4 days. then knocking will stop working. if you have any warranty left then take it back and get them to fix it or replace it, if you have no warranty left then you could either pay someone to fix it or try fixing it yourself if you do it yourself goolge for xbox 360 repair guid and this will then list loads of sites that show you how to take it apart, doing this will void any warranty and can cause more problems if you get it wrong..
if after getting it cleaned or cleaning it yourself it still dont work then this points to the fact that the dvd drive is no longer working and will need replacing.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Sep 11, 2010
  • 20 Answers
What I get from your explanation is that you tray gets stuck, right?
I can fix it, but I will explain you what causes it, when you insert a disk in the tray and is closes, the spindle, is the middle part at the center the rises up to hold the disk in place while it spins, well that spindle attaches to a small round plastic magnetically at the top of the Dvd drive case that spins along freely when together , Now for some reason that magnet that sticks to the medal part of the spindle sticks too hard and dont want too loosen up from the spindle..
A simple solution is take the dvd drive apart, and on the spindle put on some electric tape, but cut it out the same size of the spindle, like the size of a dime or smaller, stick it to the spindle the and the magnet wont hold the spindel too tight..
Hope this help.
Posted on Sep 20, 2010
Xbox open tray error
Not sure but sounds like you may have bent or broken a plastic tab, or not fully straightened the tray yet. There will be a microswitch or sensor of some type that indicates tray open if it is not closed or within tolerance. The tray must be properly straight and if there is a tab that closes the microswitch it needs to be straight and secure too. It only needs to be slightly bent to fail to register closed. Hope this helps.
Dec 20, 2013 | Video Game Consoles & Games
DVD Tray will not stay closed
There is a leaf switch inside the loading mechanism, which detects the tray to fully closed state. If this switch has damaged, this kind of fault will occur. To repair it, you have to open the set, and take the loading mechanism out, and disassemble it. If you wish to get some details, check the site linked here.Pull up older posts.
Dec 06, 2013 | Haier TDC1314S TV
Tray won't close
Use the following steps to close the disc tray on an original Xbox 360 console.
Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
The faceplate is the plastic piece on the front of your console.
  • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
  • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
  1. Gently move the tray up and down, and then from side to side.
  2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
  3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
  2. Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
Dec 16, 2010 | Microsoft Xbox 360 Console
What does e073 0003 error mean on canon 1180.
E, 0, 7
FINE Cartridge is not installed in the correct position
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
Techbelkin please rate me
Nov 03, 2010 | Office Equipment & Supplies
Error e03, but there is no jammed paper
E, 0, 3
Summary
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
I have a CDX-602 CD Player. I was on a gig the other night I placed a cd in the tray. I pressed the button to close the tray and a cord was wedged so that the tray would not close. Naturally the tray...
The gears have probably come out of sync, meaning the tray is riding on the limit switch. You need to remove the deck, dismantle and re-sync the drawer mech. Check the limit switch isnt bent, it's quite flimsy
Aug 21, 2010 | Philips Gemini CDX-602 Dual CD Player with...
My friend and I are haveing a prolbem with his xbox and it say open tray? can someone please help me?
open tray, unplug power cord while tray is open, plug power cord in, let tray close, open tray again, put disk in, close tray and tap on top of the drive while it loading.
Apr 12, 2010 | Microsoft Xbox 360 Console
Open tray on xbox when it's closed
when the tray is closed and it does not
see a cd it should say open tray
The problem weak or dead laser
laser are chep 30.00- 40.00
and not to hard to swap out.
second it may be a bad drive motor
or bad spindel motor .in that
case you will to buy a new
drive and swap out the P.C. board
from the old drive to the new one
Rob
Sep 16, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
315 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
