Question about Whirlpool LER7646E Dryer
My whirlpool dryer model #ler7646eq1...has trouble getting started, when u hit the start button it hums like it is wanting to start, it will do this sometimes for the whole cycle without starting. and then sometimes it will start but only for about 5mins to 15mins before it cuts off...and then the hum comes back until it starts up or until we put the timer back on and then maybe it will start back up (i have a 15month old son and a mother with terminal cancer, i can not afford a new dryer or repairman,if you can a asap response would be appreciated)
    Habit-Forming:
  • 84 Answers
Motor overheating,motor will have to be replaced
Posted on Sep 12, 2010
I have a whirlpool dryer model # LEP6848AW0 and when you hit the start button it just hums like something is binding. Open the door and hold switch in and hit start button it hums and you spin the the drum...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 16, 2010 | Whirlpool Dryers
The Whirlpool LER7646EQ1 dryer will not start. Outlet has 220 v power.
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Aug 28, 2010 | Whirlpool Dryers
I tried to start the dryer (whirlpool LE5700XK or the LG5701XK, not sure which) and when I hit the start button there was a loud buzzing noise, but no start. I turned the dial to the off position, and then...
Could be a couple things, depending on the buzz you are getting, if it's a buzz from the board like an alarm, it could be a door switch, if it's an electric sounding humming buzz it could be something stuck in your blower wheel like a sock
Jun 24, 2017 | Whirlpool Dryers
Hello...i have a whirlpool dryer ler7646eq1...the dryer will not start...i can hear some action near the switches but dryer will not start at all...any idea where to start....it is getting proper power...
Here are somethings to check.
Make sure you have power and inspect power cord.
Check the door switch when you push in the door switch does it click? Try setting the timer to a different setting see if it works there. The next thing to check would be the thermal fuse but this would require opening up the cabinet.
Apr 08, 2010 | Whirlpool Dryers
When I push the start button the dryer will not start
May need to replace the starter swithch behind the control panel. MAKE SURE ALL POWER IS DISCONNECTED. If you still hear a humming sound when you hit the start button then it is not the switch, but the motor and if that is the case you may want to look into your warranty.
Aug 16, 2009 | Kenmore 63942 Dryer
Dryer wont start when start button is pressed, but humming sound
I'd sure start by making sure the belt isn't broken. You can usually see the belt with a flashlight after accessing the panel (some are in front, others in the rear) - don't go probing around bare armed without unplugging the unit....
Jun 20, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool Dryer LER7646EQ1 Motor?
Could be something jamming the fan blade but if the motor shaft turns freely then your motor is bad.
May 28, 2009 | Whirlpool LER7646E Dryer
Drum wont turn
yes the start whinding shot,,,replace motor..
Jan 25, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool Dryer Model # LER7646EQ1 won't start
I'd check door switch first. Improper voltage, thermal fuse, start switch, motor, and wiring are also possibilities.
Nov 11, 2017 | Dryers
Dryers Logo
144 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
