Question about Haier 5 cu. ft. / 142 liter Chest Freezer HCM050LA
The chest freezer was sitting unpluged in the garage for 8 months. I plugged it in and it is not cooling. The compressor is getting verry hot. What can i do to make it work?
  • 4,793 Answers
Leave it alone for 24hours, switched on,then get back....
Posted on Sep 11, 2010
Just bought a used GE chest freezer model FH5DSAWH from friends. Brought it home plugged it in and it doesn't get cold. Can hear it running and the compressor gets hot. Any ideas? Was told it worked great....
your ptc overload relay on the compressor is bad,unplug it off the compressor and get a replacement at an appliance parts store,plug in the replacement and this will solve your problem
Apr 27, 2010 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
Powers on, but doesn not freeze. There is no noise coming from the freezer.
Try this, unplug the unit for about 5 minutes. This will give the compressor time to cool. Plug it back in and listen to the compressor. See how long it takes for it kick on. When it does is there a click sound, shudder, or is it quiet. Touch the compressor, is it hot. Be careful when you do this as it might be very hot. There could be a chance that the freon has leaked out. Check to make sure there is no dust, lint, debris blocking the filter / vents. Vacuum as needed, it has to breathe. When the compressor kicks on and if it gets hot there is a chance it is bad. The repair for this is expensive and another solution might be to check out craigslist as you can find some great deals. Hope this helps.
JimmyC
Sep 27, 2009 | Magic Chef Chest Freezer MCCF5WBX
The front surface of the chest freezer is pretty hot.
the condenser lines are between the walls of the frzr and if it has a fan to cool the compressor down and it is stalled is the reason the walls are so hot and no it will not cool down over time if new is a flaw in making of this unit take it back or if older only the side should be getting warm not hot then if older be cautious of this no repair can be done on these type of unit they are between foam filled walls....
Aug 19, 2009 | Kenmore Freezers
The freezer works fine, but if you unplug it, it won't start back up, you have to let it sit unpluged for about 30 minutes to an hour before it will come back on. Its like it needs to cool off, it does get...
The high side and low side of the refrigerant system , have to equalize , before the compressor can start . If you unplug , then plug back in , the high side has a lot more pressure , therefore the compressor will not start and the overload will cut the compressor off . When overload cools slightly , compressor will try to start again . If pressures not equalized , overload will cut compressor off again . As this happens , the compressor will get hotter and hotter . Eventually , pressure will equalize and compressor will continue to run . Very bad on compressor and components .
Aug 06, 2009 | Freezers
Frigidaire uprite freezer won't cool
it's scrap
they use steel lines inside the cabinet and when you unplugged it the lines rusted through
Jul 30, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Outside of chest freezer gets hot
it is normal for outside to get hot. that is where the condensor coils are located. if unit is working don't worry.
Jul 26, 2009 | GE Freezers
Plugged in chest freezer is cooling inside but hot to touch on the outside
yup, if you make cold theres gonna be heat. they run the lines through the case for cooling. it will get usually warm so maybe cause it's running alot to get cool initially. then it should normalize. if after a day it's still pretty hot, then it may be an old freezer and the compressor may be wearing out slowly, pumping slower and causing more heat.
Jun 20, 2009 | Freezers
Freezer Problem
If it started to cool again the compressor was running. Check the condenser and make sure it is clean. Provide as much air movement through the garage as possible . 100 degrees is a high temperature to be operating a refrigerator in.
Jun 10, 2008 | Frigidaire Freezer 16.7 cu. ft. Upright...
15 cu. ft. chest freezer
Remove the back panel, if there is one, find the compressor. Put your hand on it. If its very hot, you have a problem. You should feel a slight vibration if good and running. If The overload is shutting off keep your hand there and wait a few minutes, see if there is a clicking noise coming from the compressor. This is just a start, but you said it has been off for a while so my first suspect is a compressor. Do these things and let me know for a follow up.
Dec 20, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Freezer is freezing but the outer wall are extremly hot
This is a normal condition.  The condensor coils are in the cabinet and their job is to remove heat which is why it is hot.  You will want to make sure the freezer isn't in a tight spot where air from the room can't flow across it.  Without good air flow it will become too hot and not cool properly and lead to the compressor failing too soon.
Oct 13, 2007 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Haier 5 cu. ft. / 142 liter Chest Freezer HCM050LA Logo
356 people viewed this question
Top Haier Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
christian nielsen
jdthefixer
Are you a Haier Freezer Expert? Answer questions, earn points and help others
