Question about Bose Lifestyle 38 System
Under the acoustimass the yellow and green light are flashing is it normal
Makita DC18RA Makstar Li ion Charger three lights
Alternate Red and Green flashing means bad battery. Buy a new one, or take it to a Makita Service center for replacement if it's under warranty.
Normally the yellow light indicates hot battery, but it could also mean dirty battery contacts so the heat sensor can't be read, or that the fan is clogged with dust and unable to cool the battery. The manual says let the battery cool and try again. If the yellow still flashes, it's contacts or the fan.
Read the manual online at:
http://www.makita.ca/data/upload/accessorypbim/417_im_english.pdf
Oct 28, 2011 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
After pressing the on button it turns green for 5 seconds then it flashes yellow/orange for a second then it flashes red.
Yellow Light of DeathThe "Yellow Light of Death" or YLOD is the common phrase people use to describe the following sequence when they try to turn on their PS3:
  • Press Power Button
  • Red Light Flashes Three Times
  • Yellow Light Flashes
  • Green Light Flashes
  • Beeps Three Times
  • Red Light Flashes
The sequence above may vary a bit but you do see the flashing yellow light (sometimes shows up as orange) that normally you would not see when operating your PS3. The YLOD is a general hardware fault that can mean a lot of things. However, one of the problems is cracked solder that leads the PS3 to think one of its internal chips is not connected or is broken somehow. Cracked solder can happen when the chips get too hot (RSX most likely) and leads the motherboard to start bending, which may crack the solder. Changing the power supply (lower the average wattage going to the chips to lower the heat) and better thermal compound (heat dissipates faster to the heatsink) may prevent this error from occurring. However, if your PS3 has already had the YLOD, then you can reflow your motherboard every few months to keep it working (but it is not a permanent fix as the YLOD usually comes back).
Oct 09, 2010 | Sony Playstation 3 (PS3) Console
Garage door light beam one green the other yellow - light on yellow does not go out even when you block the beam
For Genie openers, normal operation is: when you block the beam, green light on one side stays on, while the red light on the other side flashes. The side with the green light is just a "dumb" infrared (invisible) light source; it doesn't know or care what happens to the beam. The other side is the receiver (photocell), and has all the smarts, so knows when the beam is broken, flashes (or turns off) its light, and sends appropriate signal to the opener to prevent or reverse door closing. I'm sure Chamberlain works basically the same way. The colored (visible) lights are to aid in setup (aiming), and for verifying operation.
Apr 29, 2010 | liftmaster Chamberlain Garage Door Opener...
Power light flashs off and on and pc clicks
Most newer models of Dell computers now have a diagnostic LED surrounding the power button on the from of the computer. When you press the power button to boot the PC, the light should be green and remain green under normal circumstances. Any other lights will help you troubleshoot the power issue you are having.
A solid green light means the computer is operating normally.
A solid yellow light indicates the power supply is operating normally but the computer is not processing data. This could mean there is a problem with the CPu or another component on the motherboard.
A blinking yellow light indicates the power supply is receiving power from the wall, but not functioning properly. This generally means the power supply itself is bad and should be tested or replaced.
A blinking green light means the computer is in standby mode.
So use the LED power light codes if your Dell computer has them. Also pay attention to any unusual beeps or sounds coming from the computer. Well, I was sure that the voltage selection switch was in the right place. And I found it highly unlikely that the processor power cable would suddenly unseat itself. Ugh.
Then I had an idea. I flipped off the surge protector and then flipped it back on. Tada! No more orange lights. Weird. The moral of the story: try the simple stuff first.
I hope this helps and please dont forget to rate my answer. Thank you! :D
Apr 28, 2010 | Dell OptiPlex SX280 PC Desktop
My ps3 wont turn on. light turns green, flashes
This is known as the yellow light of death.(ylod) It's about 150 bucks to have it serviced unless it's still under warranty.It says in the manual it is an overheating issue.
As for your problem, call customer support at 1-800-345-SONY
Mar 26, 2010 | Sony Playstation 3 (PS3) Console
CANON I350 DOES NOT PRINT
Green and yellow is a service error, but it flashes a longer green, and then the green yellow flashes, and a longer green again. You need to count the number of yellow-greens in between the longer green flashes, to know the error code.
Sep 17, 2009 | Canon i350 InkJet Printer
Flashing orange and yellow lights
Most likely your battery is dead.
If you are worried about your HD , the best thing to do would be to power it off.
Remove the battery and see if it will boot on the AC adapter.
If it boots , just get a new battery.
If not you have a motherboard issue and need to call Acer if it is under warranty.
Apr 22, 2009 | Acer Aspire 5003WLMi Notebook
Samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Feb 11, 2009 | Samsung Heating & Cooling
No 'green' light on bacl of my 'old' Vivitar 285
Then I'd say it's a reasonably sure thing that the green light is just burned out, The lights are supposed to be off at first, then red when there's a partial charge, then green when there's a full charge, then flashing between red and green when the "battery saver" kicks in. If you're seeing off, then red, then off, then flashing red, then that means everything in the charging circuit is working perfectly, there's just no green light.
Nov 30, 2007 | Vivitar 285HV Flash
Bose Lifestyle 38 System Logo
276 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
