Question about Homelite Mighty Lite Lawn Trimmer
Trimmer will start but as soon as i depress the trigger it dies. I have had to replace the primer bubble and in doing so made sure the gasket was put back on properly IT JUST WONT STAY RUNNING can you help?
  • 183 Answers
Your trimmer is starving for fuel. If it is less than 18 months old, my guess is that it just needs a carburetor adjustment. If it is older than 18 months, it should have the carb cleaned and rebuilt, or replaced. Check with homelite.com for the cost of a replacement carb, sometimes they are less expensive than having the old one repaired. If it just needs an adjustment, find a local repair shop to do it for you. Homelite requires a special tool to adjust the carb, and won't sell the tool directly to consumers. Some shops will sell the adjustment tool. No special tools are required to replace the carb, just basic tools.
Posted on Sep 12, 2010
  • pjhaire Sep 19, 2010
    yes the brasds why they can not leave it like the good old days when all u need was a small screw diver
  • John Houser
    John Houser Sep 09, 2011
    You can use a dremmel tool or hack saw to cut a slot in the screws so you can use a screwdriver. Make sure the shavings don't get in any open orifices and blow the unit off well after cutting..
Stihl FS85 starts fine, But not take full throttle
Pumping the primer bubble while the engine is running should cause the engine to over fuel and stall (if the tuning is correct). Sounds like its not fueling enough, pumping the primer is forcing fuel through the carb causing the engine to pick up rev's, but this is soon exhausted which is why it wont rev on the throttle.
* Check that the fuel line is not damaged and drawing in air. (if this is intact try the next step)
* Strip and clean the carb. Replace any diaphrams if needed.
* Check gaskets seal between carb, air filter and cylinder.
Just out of curiosity what standard carb settings did you use.?
May 23, 2013 | Stihl FS 85 Weed Eater
I have a 345 e Series 18" (I think it's 18). It's a couple of years old and probably no more than 3-5 total hours usage. Normally starts and runs perfect. Today it won't run, seems to be starving for gas....
If stale fuel has been left in the saw then try draining the tank and re filling with fresh fuel, also hook the fuel line out of the fuel tank and replace the filter on the end.
Apr 15, 2017 | Husqvarna 18" 502cc Prosumer Chain Saw ...
Featherlite SST 25 Gas Trimmer
Clean the carburetor and replace the spark plug and air filter. Also make sure the oil/ fuel ratio is correct.
Feb 10, 2018 | Poulan WeedEater Hedge Trimmer 25cc Engine
Is there a gasket under the primer bubble;it won't **** up gas
the pick up tube in the fuel tank is probably bad
Sep 16, 2009 | Garden
I have a TB425cs that won't accelerate. It will
try adjusting the mixture screws out a bit if any otherwise it will need a diaphram kit
Jul 16, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
My ryobi will start but dies about 5 minutes later
Try running the machine with the gas cap loose. There could be pressure builiding up in the system due to the cap being too tight. There is no vent on these systems like an automobile. If the gas cap is overtightened this could be your problem as the cap is equipped with a gasket that allows the vapor to vent through the cap. Overtightening could be sealing off your vent
Jun 06, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 31cc lawn trimmer carb adjustment
As with all 2 strokes if you have compression and a reasonable spark, you only need fresh fuel with correct oil ratio) and they must go !(as long as you haven't fiddled first and all gaskets are sealing) I start mine by(1) pumping the primer till it is firm,(2) full choke,(3) pull till it kicks ONCE,(4) half choke, pull till it runs,allow to warm up and(5) switch to run (you may need to apply a bit of throttle while pulling as in (4)(or give it a few more pumps if it dies) If all is ok, check that when properly warmed up there is a smooth transition from idle to full revs, if it hesitates it may need the LOW SPEED mixture leaning (clockwise) SLIGHTLY.If it dies the LOW SPEED mixture may need richening(anti-clockwise)(adjust 1/8 turn at a time) Make sure that motor is just peaking at full revs and is on the RICH side of peaking (HIGH SPEED mixture)(this will avoid seizing it Adjust both till it revs cleanly and is JUST rich at full, and idleing nicely and it should start without too much trouble.(If you have fiddled and are lost,-about 2 1/2 turns out from closed on both needles should get you started)
Nov 23, 2008 | Garden
Bad Carb
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. also check the primer bulb for pin holes and proper seating/seal. if that doesn't work have the carb repaired at a service center or replaced.
Aug 03, 2008 | Ryobi 15" Electric Factory Reconditioned...
Homelite Mighty Lite Lawn Trimmer  Logo
572 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
