Question about Lexmark E250dn Laser Printer
ERROR LIGHTS ON MY PRINTER LEXMARK E250DN - Lexmark E250dn Laser Printer
  • DaCentaur Sep 23, 2010
    Please clarify: Exactly which lights are on or blinking? Do you have an error code?
  • 157 Answers
SOURCE: HAVE REPLACED BOTH THE PCU & THE TONER IN MY
you need to reset the counter. the new pcu should have come with instructions to do this. 1. Turn off the printer. 2. Open the front cover. 3. Press and hold the Continue button (Big silver button with Diamond shape symbol) and turn the printer on. 4. Hold the button down until the last light (error light) is on solid, release the button and close the front cover. 5. When the cover is closed, all the top 3 lights should be on solid. 6. Press the cancel button (triangle symbol) 4 times very slowly until you see the toner low light (second light from top) on solid. 7. Press the continue button and wait until you see the light sequence. 8. Press the cancel button and wait until you see the light sequence. 9. Finally power off the printer and power it back on to exit the configuration mode.
Posted on Jun 16, 2009
Nic61
  • 1073 Answers
SOURCE: Reset Lexmark E250dn IP address
Yes you can, but you need to lock that ip in your router to so its always goes to your printer.
Just make sure that your router dosent use that ip for it self, the usal ip for a router is 192.168.0.0 or 192.168.0.1, but you never know. Check it to be shure!
Posted on Dec 18, 2008
SOURCE: Lexmark E250dn Laser Printer Free driver download
get it here:
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Please rate me ;)
Posted on Apr 14, 2009
don_farr
  • 1018 Answers
SOURCE: Lexmark E250dn Laser Printer free dawonload driver
I do not understand your question.
1) Did you download the driver from Lexmark.com?
2) What operating system are you using?
3) Please describe what you did and how you did it.
Posted on May 20, 2009
  • 217 Answers
SOURCE: lexmark e250dn printer, toner light is flashing, new cartridge
Could be photoconductor at end of life.
You shoul still be able to do a printer test print (press the arrow button).
Look on the printed pagesfor Toner AND Photoconductor.
These show as OK when new or very low count, and 100% when fully used.
If the toner is showing as 100% when you've just replaced it, either the chip is faulty, the wrong one, or if the cartridge is a remanufactured one possibly nor been replaced.
Posted on Mar 30, 2010
I tried to install my printer. I do not have the original set-up cd. The error light does not go off. I don't know if insatlled properly.What do I do?
Please try to download and install the correct drivers from support.lexmark.com website, make sure you filter the correct operating system.
If the error light does not go off, please press the continue button to display the secondary error codes.
For further assistance, please contact Lexmark Technical Support
Sep 10, 2011 | Lexmark E250dn Laser Printer
All of the lights on my lexmark E250d are flashing????
The printer has a service error, and printing has stopped. Press Continue twice to see the secondary code. The secondary code will indicate where to locate the problem.
For further assistance, please contact Lexmark Technical Support.
Jul 14, 2011 | Lexmark E250dn Laser Printer
Driver for Lexmark E250dn laser printer
LEXMARK E250dn Driver
Visit the above link. Select the OS (Operating System) and download the required drivers.
Hope it helps! Good Luck!
CreativeTECH
May 02, 2011 | Lexmark E250dn Laser Printer
All front panel lights blink
This light sequence means that the printer has a service error, and printing has stopped.
Please Press Continue button (green button) twice to see the secondary code. The secondary error code will help locate the problem. Please take note which light will be flashing for this will reveal what problems you have on the printer.
Feb 01, 2011 | Lexmark E250dn Laser Printer
How do I find out the IP Address of my school's Lemark E250dn printer?
You can print the network setup page to view the Lexmark E250dn's IP address. Visit the Lexmark at http://bit.ly/9kdDvc for the instructions on how to print the network setup page. Thanks.
Sep 28, 2010 | Lexmark E250dn Laser Printer
Hi, my name is alex a Computer - printer technician i have a lexmark e250dn all lights are blinking,indicating a service error ,sometimes all the lights are just on and not blinking ,i have tried to...
If you can see an error code and let us know, that would be good.
Failing which, you could try re-seating the cables connecting the print head, fan, etc to the system board.
If the error was due to low voltage, your printer might have started working again by now. :)
Sep 22, 2010 | Lexmark E250dn Laser Printer
I changed the toner on my Lexmark E250dn and now it has the "!" light on all the time and won't print. It's a new cartridge what is going on?
"!" means error.
Try removing cartridge and installing it again and might be one of the cartridge missing.
Try operating manual. Might helps, there are lots of reason for the error
ftp://ftp.lexmark.com/depot/LXK/E250_Depot_Repair_rev092606.pdf
Suspected
Follow the link on dispute about wrong cartridge due "Toner cartridge region mismatch"
http://www.techsupportforum.com/hardware-support/printer-support/379157-lexmark-e250dn-amp-quot-toner-cartridge-region-mismatch-amp-quot.html
Hope this helps
May 21, 2010 | Lexmark E250dn Laser Printer
HAVE REPLACED BOTH THE PCU & THE TONER IN MY LEXMARK E250DN PRINTER BUT STILL KEEP GETTING ERROR MSG TO REPLACE PCU IT HAS REACHED THE END OF IT'S LIFE
Jun 16, 2009 | Lexmark E250dn Laser Printer
Lexmark E250dn Laser Printer Logo
370 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
