Question about Dell V313w AllInOne InkJet Printer
Can the ink dry up. installed printer ink a couple of months ago but will not print now. printer prints blank pages.
  • 57 Answers
Hi!
yes ink can dry up.. big chance your ink have dried up, since you've installed them couple of months ago.. there's a possibility that the ink may have not dried up but the print head may clogged.. you can try running some maintenance like clean cartridge or print head test using Dell All inOne Solution center..
Hope this helps..
Posted on Sep 11, 2010
Hp lj cp1518 printer printing blank pages
you need new ink if not used it will dry up. if you are not sure go buy black ink
Jun 20, 2014 | HP Color Laserjet Cp1518ni - Printer -...
My printer prints blank pages when I want to print files from my computer, but works fine without a computer
If you don't use the printer often (at least once a month) you probably have cartridges drying up on you. If by chance you have an Epson or canon, the print head is inside the printer, so regardless of how many new cartridges you put in there, you will encounter the same problem.
If you are using a generic or third party ink, it may be too dense or of low quality clogging yourprint head.
You can try to run a bunch of print head cleanings. (your manual will tell you how) If by about 8 you are not seeing any improvement start with a new printer. Do a print head cleaning once a month ALWAYS as a preventative measure. This will ensure you get a long life out of your printer, and a top quality print from your cartridges.
Feb 24, 2014 | Canon PIXMA MP240 All-In-One InkJet...
New Cartridges - not all color ink printing!
It sounds that the ink inside the cartridge has partly dried up.
This can happen to my printer when I don't use it for a couple of months too.
Hope this helps!
Feb 04, 2010 | HP PhotoSmart C4180 All-in-One Color...
Prints nothing on paper. checked ink cartridges
please the your pc in add a printer and again install a printer driver
and you go control panelt and select the printer an dchous this printer
and restart your pc and try printing giveup page
Sep 14, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
G600 printer dock used about 6 months ago. Only
Yes, maybe the ink dry out. Try a deep cleaning several times, from the printer options.
If you don't use the printer, you should weekly print a test page to avoid this problem.
Aug 27, 2009 | Kodak Easyshare Printer G600 Thermo...
Kodak 5100 will not print consistently
I am currently having the same problem with a 17" iMac Intel Core Duo.  The printer worked fine for a few months, now it will only print in black and white and sometimes in color that is extremely faded.  I have tried every troubleshooting tip in the book and still no luck.
Apr 28, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
My printing displays wrong ink levels and prints blank pages
If your cartridge is new (or full) and you know that not just from ink levels display, then you did not used the printer for a while (at least a month) and the nozzles of the cartridge are clogged. If u used the cartridghe 4 or 5 moths ago, then the whole cartridge is dryed out, so get out and get yourself a new cartridge.
If it's just a month, then you should put a paper-tissue on a small plate (like a coffee-cup plate), then put some boiling water on it, just 2~3mm of water over the tissue.
Put the cartridge with the nozzles part downside on the tissue, in the hot water.
Let it stay there in the water 30 min.
Put the cartridge in an other clean tissue, than shake it strongy as if you want to force ink to get out trough the nozzles. Then clean gentle the nozzle part of the cartridge on some sheets of tissue.
Install the cartridges it in the printer and run a few cleaning processes from the printers maintenance software.
If the cartridge is new and just installed in the printer, and you have the inklevels but it does not print, then get it out of the printer and back to the store, they should replace it for you. I hope you removed the protective plastic stripe that covers the nozzles before installing the cartridge?...
OK, let ne know please how things evolve.
Hope it helped you, rate the solution.
Almoust forgot: ink levels are displayed by Lexmark inkprinters by estimating the ink consumed trough you printing process, it has no sensors in the cartridge. It's just kind of a counter, you can evan set an empty cartridge to be seen as a full one.
Feb 13, 2008 | Lexmark Z816 Color Inkjet Printer
Will not print---prints blank pages
This printer is 13 years old. I am a fan of keeping things around,  and those cartridges for $3 arent bad, but its not the best on the environment, and considering printers of this decade print faster, have better resolution and are capable of archival prints.
It's really worth it.
Hope this helps.
Oct 10, 2007 | Apple Color StyleWriter 2400 InkJet...
Lexmark Z517 wont print black ink
I have a z600 that i use. If not used for about a month the ink does clog the print nozzles and eventually ink cartridge does dry out. To avoid this even if i dont have to print anything I run a diagnostics test that prints out a nozzle aligment test every two weeks.The great thing about this is that it uses very little ink.You can find this test in your software that was provided by Lexmark. This will keep your nozzles cleaned and you will notice this helps extend the life of your cartridge.
Sep 21, 2007 | Lexmark Inkjet Z517 Photo Printer
Printer acts like it's working then produces a blank page
Try to print first a self test page on the printer. Does it print a blank page also ? Do you have good or new ink cartridges in the printer ? Let me know.
Jul 31, 2007 | Dell A920 InkJet Printer
Dell V313w AllInOne InkJet Printer Logo
373 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
