Question about Jenn-Air JDB1105AWS Stainless Steel Dishwasher
Out of the blue our Jen-aire jdb1105aws doesn't want to power up. No lights, no cycles etc. Checked the plug etc and no tripped fuses. Any thoughts appreciated.
  • Jenn-Air Master
  • 17,130 Answers
If there is power present on the controller but not outputting to the circuits then it is possible toi have the controller faulty which can be getting error messages/fault messages from the sensor or a failure of the main board..
Posted on Sep 11, 2010
Dryer will not start
If you manually turn on timer can you hear the faint ticking? #1Verify breaker is not tripped. #2 Unplug dryer. Remove back cover. On many makes there are 2 blue wires that connect to a white and black "fuse" towards the bottom of the unit. Unplug both wires and electical tape them together. plug in dryer and start the cycle. If it works, unplug and go buy the fuse. Clean lint out of air system from dryer to lint screen through exhaust.
Jan 09, 2014 | Dryers
I have an admiral electric dryer. It stopped in the middle of a cycle and the light is out and it won't turn on. I checked the fuse box, the plug and the belt is still on, so what do I do now?
Did you test the power outlet with another device...Sometimes a power outlet will fail under the load of a high current appliance like a drier...If the drier runs on 220 volt current...and have circuit breakers instead of fuses...make sure the 220 volt breaker for the dryer is not tripped...If it is tripped...reset it....if not...have a tech to check the outlet. oncee it is established that the drier is getting power and still not working...you may want to get it checked out by service personnel....Hope this was helpful....PEACE.....
Jan 25, 2012 | Admiral Dryers
My machine WA37T26G Fisher & Paykel has no power, it will not turn on.
Hello, welcome to Fixya!
The unit not powering on is an indication that it has a power fault.
First, remove the machine's power cord from the wall, wait for about 30mins, then plug it back in. It may cool by then and might power on. If it doesn't power on, plug it into another outlet, to make sure there electricity entering into the unit.
If plugging into another power outlet doesn't power it on then the unit is most likely having a power problem.
When electric current comes from the power outlet into the machine, it goes straight into the power supply board which then circulates the current into the unit. So if the machine doesn't power on, the first thing is to make sure there is power entering into the machine.
So check the power cord, if it is a 3-pin plug, it must have a fuse in it. check the fuse if it is not blown. if fuse is intact, then power supply board should be checked.
If any machine or electronics device doesn't power on, it means its having a power problem. It might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This machine must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the machine turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter and continuity tester in order to read the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store within our vicinity.You might also find visible bad component without testing with a meter. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Jan 04, 2012 | Fisher and Paykel WA37T26G Top Load Washer
Suddenly I have no power to my dishwasher. I checked my main house electrical fuses and they seem fine. Is their another fuse in the washer itself to check?
Do some more experiments...Check power is getting to the power point at the back of machine (maybe plug in a lamp or something if you don't have a multi-meter), check external cable for damage (while not plugged in). Is there any signs of power at all? Any lights that come on or beeps made? If your model doesn't have lights to begin with, it could be a problem in the trip switch in the door for example. There probably is an internal fuse... only problem is that if it did blow, it might have for a reason... keep investigating
Aug 12, 2011 | Maytag Dishwasher
My boiler keeps tripping out when i try to fire it up i have checked all the obvious ie plugs ,fuses ,sockets etc
Try tightening the screws on the breaker and the neutral(white) wire in the breaker box. They loosen up over time and cause the breaker to trip.
Mar 31, 2011 | Heating & Cooling
Changed a buld in hood and it touched casing as I was inserting. Tripped the breaker. This is reset but now have no power to bulbs or fan. Is there a trip in the hood?I dont have the model number, it is a...
check to make sure you have power back to the junction on the hood,sometimes just resetting the breaker wont do the trick,it may be a wire at the hook-up open now,there may be a fuse protecting the unit itself for the fan control,but the lights are usually wired direct so re-check the incoming power first
May 02, 2010 | Jenn-Air JXT8136ADS Kitchen Hood
Dead microwave
There are replacable fuses inside. Taking the microwave apart requires removal of a lot of screws and the cover that can be rather bulky. make sure it's unplugged and safe before you begin. you can get replacement fuses at radio shack, ect. be sure to buy the same type and amperage. if the blow a second time there may be other issues.
May 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Faulty Diplomat Dishwasher - tripping mains fuse
My dishwasher a diplomat 12 program (hja8640) was doing exactly the same where every now and again when turned on at the plug it would trip. After engineers coming out several times and failing to fix it, they condemed it. New one was supplied, however did exactly the same thing. The electrician came back, checked the RCD power breaker and this was fine. It was then discovered that some dishwashers and washing machines send out a lot of earth leakage, combine this with other appliances on in the house can be enough to trip.
Soloution. The electrician removed the kitchen circut from the RCD breaker and intalled another breaker RCD just for the kitcehn loop, this therefore means that the kitchen has a seperate trip from the rest of the house, and touch wood, has solved the problem. This mind you has taken about three months to work out so i hope it saves you some time.
Always use a fully qualified electrician though.
Thanks.
Oct 21, 2008 | Dishwashers
Dead microwave
If it gives a little beep, then there's still some life in the control board. That's an encouraging sign.
In most cases, we can fix these boards. We repair these for customers nationwide with our guaranteed $39.95 service.
We have full details, plus critical safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa.
At our site, we now have a video available showing how to remove a typical control panel assembly in under 5 minutes.
Feel free to contact me directly.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Jul 29, 2008 | Jenn-Air JMV8208AAS Microwave Oven
Jenn-Air JDB1105AWS Stainless Steel Dishwasher Logo
168 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
