Question about Canon PIXMA iP4300 InkJet Photo Printer
Canon Pixma IP 4300 printer - 3 blinking panel lights indicate paper jam, however no paper jam is present. I turned off machine, pulled power plug, waited for 5 minutes, turned on printer, but problem did not go away.
  • Canon Master
  • 17,130 Answers
It is possible that the printer is having an error due to either a sensor fault ( optocoupler) in the paper detect section or a possible software issue.
So disconnecct printter, and uninstall the soft ware , the reinstall and then connecct printer to be detected and installed.
If the fault stays then the sensor must be checked.
Posted on Sep 11, 2010
I have a Canon ip 4300. Recently I had a paper jamb (81/2 X 11)
it maybe the sensers which tell the faults has moved out of position or wires loose
Jul 06, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
The printer warps paper on entry .
try to reset your Canon printer, turn the printer off with the power button. Then disconnect the data cable from the printer. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable. Then turn the printer back on.
Jul 02, 2008 | Office Equipment & Supplies
Printer says clear paper jam then press reset
Could there possibly be:
A) Paper jammed internally: Power Off. Open the cover and remove the paper or scrap carefully. Do not touch the internal printer parts. Close the cover. Power on.
B) Foreign objects in printer: Power Off. Open the paper support and confirm that there is no foreign material in the auto sheet feeder. (If so, remove it by hand or with tweezers). Open the front cover and confirm that there is no foreign material in the unit. Avoid touching the inner workings of the machine.
C) Reset the printer:
1. Turn the printer off with the Power button
2. Disconnect the data cable from the printer
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. Attach data cable.
4. Turn the printer back on.
If all of these suggestions fail, your iP1600 may require repair service. Please note: With the suggested retail price of $29.99 USD, repair does not seem cost effective - you could just go out and purchase a new printer.
Dec 28, 2009 | Canon PIXMA iP1600 Printer
Rear Paper Jam - No paper present.
Look for a small piece of paper that may be stuck in the switch indicating a paper jam.
Jun 01, 2009 | Canon PIXMA MP610 InkJet Printer
Keeps blinking E3
Hi. Canon says this
E, 3
Paper jam.
If paper has jammed in the machine, clear the jam, reload the paper in the machine correctly and then press the Black or Color button.
There is another step to fix this, also from canon.
Issue: ERROR LED: E, 3
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Apr 21, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Green and orange lights flashing, saying service error 6000
read all first!
you didn't say how many blinking
and in what order so ...
First thing you need to do is print an EEPROM information page, step number 2 below.
Once you have an EEPROM print you can reset the waste ink counter, if needed, which is step number 4 below.
Service Mode: This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
With the printer powered off, hold down the "Resume Button" and press the "Power Button".
While holding down the "Power Button", release the Resume Button" and press the "Resume Button" twice in succession. Now release the "Power Button".
The indicator will blink in green and remain lit in green.
Select one of the following service mode functions by pressing the “Resume Button” the specified number of times.
1 time = Service test print.
2 times = EEPROM information print.
3 times = EEPROM initialization
4 times = Waste ink counter resetting
5 times = Destination settings
6 times = Print head deep cleaning
Then press the “Power Button” one time to perform selected function.
If you press the "Power Button" two times it will take you out of service mode.
This information is listed above in this thread and many times in other Canon threads in this forum. I simplified Canons wording so I could remember the service mode functions easier.
PIXMA IP 3000 service error 5100
I got service error 5100 after a paper jam sometimes 5 times blinking orange. in my PIXMA IP 3000
to fix it
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
or: and Also;
Unplug unit, hold power and reset button down then plug it in while still holding both buttons down;
Then to step 3 above.
Feb 19, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
I have a canon pixma ip 3000 and i need to empty inktank can u help
Ther is no ink tank it is a counter pre set by canon who decided you can only print so many pages . it is artificial number.
reset your machine by the following should help
read all first
to fix also :
to fix it
1. Turn off printer
or: and Also;
THEN plug it in while still holding both buttons down;
Feb 18, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon ip 3000 photoprinter not working
things to check.
1. check for any paper that may have jam inside the printer.
2. check for open covers, back, top covers and close them properly.
4. check your power adapter if its giving correct voltage to the printer.
3. Try to move the ink cartridge to the left gently and return back to the right most part.
please let us know if this works.
Feb 07, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon ip 4300
Google "canon ip4300". The canon.com entry near the top has a support tab. and enter "paper skew", you'll get a roller cleaning procedure.
As a matter of fact, it didn't solve my problem. The alternative, of having the machine repaired, is, of course, silly vs. buying a new machine. But in the meantime, the lower paper feed still works, albeit slightly less convenient.
Apr 22, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
PIXMA iP1700
hi dear
turn off your printer,
try with this metode
Waste Ink Counter Reset. Manual for Service mode
1. Turn off the printer. And disconnect the printer cable.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.)
should be orange.
5. Press and release the RESUME button again, the indicator
6. Release both buttons
oke try to print
Mar 23, 2008 | Canon PIXMA iP1700 InkJet Photo Printer
Canon PIXMA  iP4300 InkJet Photo Printer Logo
258 people viewed this question
old marine
old marine
