Question about Dell Inspiron 1300 Notebook
My daughter has an inspiron 1300. the problem is that it seems to go through power adapters very quickly. The first dell one had a loose connection and all subsequent adapters seem to burn our after a month or so (connection is fine though) i have got fed up buying adapters (lots of different ones from different suppliers) and now looking to see if the pc is at fault. any ideas?
    Guru:
  • 689 Answers
This is a very strange and disturbing problem,I hope your adapters are the genuine product not some sort of "no-brand" replacement.
you can download or buy diagostic tools that will tell you how your pc is operating.
Certain operating systems have these tools built in (Linux for example)
It could be the case that your pc model is suseptable to this problem (a design Fault)
Your luck y not to have damaged you pc,permenantly
Posted on Sep 11, 2010
Dell Inspiron 1300 Of front left four lights, the third is flashing red
I believe that is the battery light indicator saying that the battery is depleted. If you've attempted to recharge the laptop, I'd put my money on a bad AC Adapter. Try a different AC Adapter. Dell laptops are very picky, so I'd recommend acquiring a Dell-brand adapter to ensure it will charge your battery.
Mar 25, 2011 | Dell Inspiron 1300 Notebook
Dell inspirion 1300 screen goes black
Turn OFF the laptop, unplug the ac adapter and remove the battery.
Without the battery and ac adapter, hold the power button for 10 secs.
Put the power sources back and turn ON.
Mar 01, 2011 | Dell Inspiron 1300 Notebook
How do you do a factory reset without a system recovery disk on a dell 1300 inspiron laptop
for the computer reset or windows? computer reset: disconnect everything ( adapter, battery, etc) then hold the power button down for 30 seconds, connect adapter and turn on. windows: try to get an installation disk if you do not have one of the same copy that's on the computer, run but shortly into setup there is an option for system recovery, run it ( win 7 is listed as "repair my computer")
Jan 07, 2011 | Dell Inspiron 1300 Notebook
Have a dell inspiron 1300 new battery was off about 2 weeks,plugged back in get slow blinking green light after all night wont come on when i push power button ???
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
Sep 12, 2010 | Dell Inspiron 1300 Notebook
Inspiron 1300 PC Notebook: I can not start my Dell Inspiron 1300 , when i plu...
adapter should be fine..if light comes on adapter should be good...leave battery out of the system...just use adapter and when starting system up tap f12...see if u can see this menu..if not try a external monitor to see if u can get a image..if so run the diagnostic..if still no image or no external monitor it may be a mb
May 06, 2010 | Dell Inspiron 1300 Notebook
No power leds. My Ac adapter is new with the right voltage coming out. I have to keep on unplugging the power cord then the green light comes on my Dell Inspiron 1300....I took the Laptop apart and solder...
You will probably find, that the power Jack on the Mother Board has fractured the solder joint, this is a common problem. You may have to get it to a shop.
Mar 08, 2010 | Dell Inspiron 1300 Notebook
If the adapter is new or OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Mar 06, 2010 | Dell Inspiron 1300 Notebook
No power to dell inspiron 1545 adapter
Ya this is a AC adapter Failure if there is no blue light then ,if you have any other known good AC adapter to try with if it works then it faulty call DELL with see whether your system is in warranty, there is 20 digit long serial no on the dell ac adapter,they will replace it if it is in warranty
Jan 09, 2010 | Dell Inspiron 1545 Notebook
Dell inspiron 1300 wont work from the AC adapter
Is the laptop working without the battery, directly on AC. Have you tried using another charger or battery to see if its charging.
Jan 28, 2009 | Dell Inspiron 1300 Notebook
Dell Inspiron 1300 Notebook Logo
Alun Cox
