My hp pavillion a6720y will not turn on. There is a small green light on the back of the cpu where the power suply is but that is all. I have opened the cpu and checked to make sure all connections are tight. I am hoping it is just the power supply but am not sure
  • 624 Answers
SOURCE: System will not power up
Here is a Compaq document will walk you thorough a fairly lengthy procedure that should solve your problem. Here is the link: http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&lc=en&cc=us&dlc=en&product=431080&query=presario%20sr1220&dest_page=product#N561 Let us know how this turns out or if you need any additional assistance.
Posted on Jan 02, 2007
judesoul
  • 127 Answers
SOURCE: dell dimension 5100 won't power on
might be a problem with the power button...try exchanging the power adapter and the reset adapter in your motherboard...this would become:
RESET BUTTON: as power button.
view your manual on where to find this adapters in your board.
Posted on Nov 19, 2007
  • 35 Answers
SOURCE: hp pavillion desktop will not
Step 1 : Turn off the system by pressing the power button for 5 - 10 sec until the power LED is off. Removed all cables including the power cable (Exclude monitor cable and KeyBoard/Mouse).
Step 2 : Press power button for 5-10 sec again to drain fela power.
Step 3 : Reconnect the power cable at the back of the tower/computer and power on the system.
**If the same problem exists, Call HP tech Support (800-474-6836) because there is a high possibility that you have a bad Motherboard or Power Supply on the system.
Posted on Oct 28, 2008
jtuckerj
  • 59 Answers
SOURCE: HP computer doesn't turn on
Your power supply is bad--you will need to replace. I suggest looking at tigerdiect for a replacement.
Posted on Dec 12, 2008
sparky1500
  • 1066 Answers
SOURCE: Is the Antec EarthWatts 500-Watt
should be.
Posted on Dec 24, 2008
Power supply in HP slimline s7310n
It sounds like the CPU is over heating. It probably has poor ventilation. Unplug the unit and open the side panel. Carefully vacuum all the dust inside. Be careful not to damage any electronics. You can use a small brush to loosen the dust before vacuuming. Good luck!
Apr 11, 2017 | Computers & Internet
HP Pavillion a1514n Won't Turn On
Hook a monitor to the video output, if no change! the video graphics chip is bad located on the motherboard.
Jun 29, 2012 | HP Pavillion dv9740us Notebook
Power light on computer flashes..tried the trouble shooting advice w no results. Bestec power supply model atx 250-12z. Unplugged computer to clean and now wont turn on..No fan no nothing..Just a green...
If you didn't accidentally unplug the four pin connector near the CPU, you need to replace the power supply. This is actually a fairly common occurrence with the cheap ATX power supplies being tossed into systems these days.
Jun 15, 2011 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
Compaq presario sr2020nx will not turn on
Just check the power suply behind computer case , or check your cable power.
May 24, 2010 | HP Compaq Presario SR2020NX PC Desktop
My hp pavillion dv000 wont trun on, when i press p[ower buttin , lights comes on, no fan noise, dvd drive make litlle noise, green light on and off, after20 seconds alllights trun off, please help
mother board repair or replace disc check and bios is still coming up but the part that kicks on fans for cpu isnt working hope fully it didnt damage cpu but its possible
Nov 07, 2009 | HP Computers & Internet
Hp pavillion media center a 1540n motherboard.....computer cpu fan runs, power supply runs, when i hold the switch it won't power-down unless i un-plug computer....no video (not even bios) does this mean...
Hello!
Try clear cmos, if the motherboard bad you must wait so long, maybe you can turn on computer, and they can work perfect, but when you turn off computer on power suply, you can´t again turn on computer.
If this so you have trouble with motherboard.
Oct 30, 2009 | HP Computers & Internet
I have an HP Pavilion a384x. It will not turn on
First with the computer turned off make sure the switch on the power supply is set to 115v.
If you turn the computer back on and you still get a flashing green light on the back of the power supply and a constant light on the front of the computer with no video, then try replacing the power supply with either a new one or a known working good one.
If that doesn't do it then it has to be the motherboard at that point.
Keep in mind normally on those power supplies, the green light should be constant. So it has to be either the power supply is bad or the moterboard is bad and you'll know when you put a new or known good working power supply in the computer.
Aug 03, 2009 | HP Computers & Internet
Computer will not turn on
Posible bad power supply try using another power supply.
Jul 03, 2009 | HP Pavilion a620n (PC028A) PC Desktop
Laptop hp pavillion ze4300
Probably bad memory or loose CPU module. First try removing and resetting CPU. You'll need to remove Keyboard, Palmrest, and heatsink and shield beneath Keyboard. You'll need a small Phillips screwdriver to remove screws and small standard size screwdriver to loosen screw holding CPU. After removal/reset, put everything back together and try powering back on. If still same problem, replace memory located on bottom of LT located behind door. Also, you may have a memory module located under Keyboard next to CPU that may be bad.
Jan 06, 2008 | HP Pavilion ze4300 Notebook
Computers & Internet Logo
343 people viewed this question
David Payne
David Payne
