Question about Janome 8080 Computerized Sewing Machine
Makes a loud screeching sound when I sew. - Janome 8080 Computerized Sewing Machine
  • 340 Answers
I think it's time to oil your machine. Take a look at you user's manual and clear out any lint (fluff) before adding special sewing machine oil to the moving parts.
Posted on Sep 13, 2010
Why does 835 make a loud noise when sewing?
Is it a mechanical machine? Most mechanical machines make louder sounds when they have not been oiled for some time. Consult the owner's manual and use ONLY good quality sewing machine oil.
Feb 16, 2016 | Husqvarna Sewing Machines
Hi, my brand new 7258 Singer Stylist sewing machine screeches too much. I've cleaned it, oiled (Singer oil) it and changed the needle three times already, following brand instructions. Still screeching too...
Without being able to personally troubleshoot, analyze, and diagnose the screeching, no one is going to be able to solve the problem.
That said, for your understsnding of the gravity of the situation, I provide the following info and warnings!!!!!
Loud screeching like you describe is INDICATIVE OF either a pulley-belt joint slipping at very high speed, OR a BEARING in a high speed application binding, NEITHER OF WHICH IS GOOD!!!!!
To prevent possible total destruction of your machine, I strongly suggest the you unplug it UNTIL you can get it to a QUALIFIED repair TECHNICIAN for troubleshooting.
The symptoms you describe are indicative of a very serious problem which could result in severe damage to your machine!
Jan 17, 2015 | Singer 7258 Sewing Machine
My Serger, Brother Lock 1034D is sewing great but periodically makes a loud screeching noise. Any ideas?
if you heat the area before its oiled it will wick it up
mini torches rule, or just run machine for 3 mins to warm it up a lot
use some wd40 its light oil but evaporates some on some
there are 2.00 stethoscopes out there i use one . got it at tool import
this noise will always be there its a sleeve going bad with offset wear.
the bearings will be on some support structure as the mech passes rods through them.
there are some amazing lubes out there but some can be hazardous to your skin an blood with micro balls.
Jan 12, 2015 | Brother Sewing Machines
My brother 1034d serger makes a loud pop when i,m sewing
Take it back. No new machine should make any noises like that. Exchange it for a better one.
Nov 30, 2012 | Brother 1034D Mechanical Sewing Machine
Sewing machine is making screeching noise
If you are hearing screeching it could be a worn belt. Or it could be that your EP needs servicing (oil and lube)
Nov 03, 2012 | Euro-Pro 605 Mechanical Sewing Machine
I have a Kenmore 385.16221301 sewing machine and it makes a loud noise at high speeds
it's possible that something is loose or worn slightly to make the noise
Feb 27, 2012 | Sewing Machines
Screeching noise
have you tried a new needle--flat side to the back of the machine
check to see if the thread has come off the thread take up lever
it's also possible that there's something wrong with the motor since it sounds a bit loud
it probably needs to be serviced
Feb 23, 2012 | As Seen On TV Mini Mechanical Sewing...
My Bernina sport 801 is making a loud screeching noise heard under the presser foot/bobbin area
clean under the needle plate
clean the bobbin area for loose threads or lint
if this doesn't make the noise stop then it may need to be serviced
Aug 03, 2011 | Sewing Machines
Bernina deco noise
See if drive belt is not running against the plastic body on right side.!
Nov 17, 2008 | Bernina Bernette Deco 600
Janome 8080 Computerized Sewing Machine Logo
158 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
