Question about Samsung V20 XTC 1800 Notebook
My NC10 netbook works normaly until i try to run it with the power cable plugged in ...the screen goes blank (white)...unplug the power and it runs OK. roger.
    Guru:
  • 689 Answers
First thing i to check psu model specs,(should be on sticker on psu) is as supplied with your model(manufacturers site)
Posted on Sep 11, 2010
Why is my screen going white?
The high voltage inverter is usually in that area. Remove screen bezel to access it. Unplug and replug the connectors to it an see it that helped. Bezel screws are usually under paper or rubber covers that pry off.
Jul 20, 2014 | Samsung NC10 Netbook
I have a samsung netbook and there must be a short somewhere. it is getting worse. my screen goes completely white. if i fiddle with opening and closing a bit, it pops back up. if i take the power cord...
The symptoms you describe sounds typically like the interface cable between the netbook & the screen has been damaged due to opening & closing the laptop numerous times.
There is unfortunately no quick fix if this is the problem. You will have to take your netbook in to a repair shop in order to replace the cable.
Best wishes,
Graeme
Mar 11, 2011 | Samsung NC10 Netbook
My samsung netbook NC10 has the following problems, i would like to know how i can resolve it: 1. When i put it on charge, i cannot use it, the screen goes white 2. When i take out the charger, the...
Its mainly occur in hardware problem only.. In Western Cape South Africa also samsung service centres is available....I attached the address below go and check it there...your problem will be solved...
CG Appliances centre
no:66 st john street oudtshoorn oudtshoorn,western cape
mail address:cgappliance.centre@odn.co.za
Jan 01, 2011 | Samsung NC10-14GW Notebook
My samsung nc10 screen goes white whilst charger plugged vin
the lcd cable that joins the screen to the motherboard is most probably faulty under AC power input. To fix it you need a new ribbon cable. Samsung will charge to sort it without warranty however the NC10 has a 12 month warranty so check your receipt date. Failing that a local computer shop is likely to be the cheapest option.
Jul 29, 2010 | Samsung NC10-14ROBL Notebook
NC10 netbook screen keeps "whiting out"
If you have to wiggle it on the hinges then it sound like it is a bad ribbon cable connection, it it has somehow broken. There is a thin flat ribbon that runs from the pc to the display. Some patience and care will required. If at a ll possible, take it to an authorized service center, should still be under warranty. Best way to test if from one end to other (pin to pin) for continuity with a volt meter.
Jul 18, 2010 | Samsung NC10-14GW Notebook
My NC10 netbook screen is blank (dead) when powered on
try looking for an FN button and an icon on your keyboard that has 2 screens on it one is blank and one has an outline in it Hold the FN button down and press that key with the icon usually the icon is blue on a keyboard and is on the F1-12 buttons or on the numberpad
Apr 09, 2010 | Samsung NC10-14ROBL Notebook
Samsung NC10 notebook screen blanks out
Hello and thank you for using Fixya!
You may want to purchase an electrical conversion plug. I had a co-worker that went to China, plugged in her laptop and it surged it out. I am not sure about electrical regulations in other places but this sounds familiar to her situation.
I do believe this would be covered under the warranty without the travelling part included. They may honor the warranty as a faulty hardware.
If they do not, then more than likely it is the video graphics card or inverter on the screen that got surged.
Test:
Attach an external monitor and see if this happens. If it doesn't happen while attached to the external modem, then it is the inverter andyou will need to replace screen.
If it continues to do this while connected to external monitor, then the video graphics card is going out.
Hope this helps!
Jennifer
Dec 21, 2009 | Samsung NC10-14GW Notebook
What cable connects my netbook to my tv?
Most plasma/LCD's have a PC monitor plug on it. Most laptops will have one too. (or even DVI, which is usually a white plug, and wider than the VGA cable)
Either way, i'm confident that you'll probably have the BLUE 15-pin standard VGA on the monitor and the computer. If so, buy that. If you have the wider white (DVI), it'll be even better!
Nov 20, 2009 | Samsung NC10-14ROBL Notebook
I have a samsung NC10. I have connected to my TV via the PC cable. I can see the screen but here no sounds. I have connected the red/yellow/white audio cable to the tv. It has a jack plug on the other end....
The cable you are using is a rca audio/video cable. The colors translate to:
  • red=audio,right
  • white=audio,left
  • yellow=composite video
Your laptop headphone input uses a ⅛′ (3.5 mm) mono and stereo (TRS).
You need a Stereo 3.5mm mini phone plug male to 2 RCA female connectors.
Nov 07, 2009 | Samsung NC10-11PBK Netbook
Samsung NC10 will not boot up
Take it back to the store and get the manufacturers to fix it.
Jun 13, 2009 | Samsung NC10-14GW Notebook
Samsung V20 XTC 1800 Notebook Logo
64 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
