Question about Kensington PocketMouse 72214
How do i replace the battery on the pocket mouse?
Changing the battery in a mickey mouse pocket watch
The first answer is a canned answer. Seen it before. Examine the edge of the pocket watch. Start at the stem and look for a slight gap where the back cover meets the case. It is usually at the stem side or hinge side. Once located take a strong sharp knife and carefully pry up the back cover. It should remove fairly easily. I have about 12 pocket watches and they all work the same way. Once open there may be a small screw or two holding the battery in place. You will need a precision screw driver set or a small screw driver for glasses.
682b943c-dbb9-4041-9abb-ed1a67105d52.jpg eff96e41-9266-48e7-9603-ac9206c667a0.jpg 03735b42-603a-41af-9aa7-4d445bd017dc.jpg
Jun 30, 2013 | Watches
Need to replace battery of lorus mickey mouse pocket watch
Try to find a watch repair shop (sometimes called clock & watch shops). Also, many jewelers replace batteries and do watch repair.
Jan 13, 2011 | Lorus Watches
I successfully installed the driver for the Kensington pocket mouse on my S7 notebook, but I cannot activate it to take over the job of the touch pad.
Wireless Installation
Plug in the receiver to your usb port. Install batteries to mouse.
To establish a wireless connection, press the connect
button on the end of the receiver. Then, press the
connect button on the bottom of the mouse.
Click a button on the mouse to go..
Repeat this procedure when replacing the batteries.
IMPORTANT: This wireless device is similar to an FM radio, by
adjusting the antenna you can get better reception. You may
also want to experiment with different locations and positions
of the receiver.
The little light on the receiver should light up and flash fast untill it sees the mouse signal.
Nov 18, 2010 | Kensington PocketMouse 72214
Lost driver for my kensington pocket mouse model
Hi mdriskell,
I'm not sure if this will work for you but go to this site: http://us.kensington.com/html/1466.html#mw611 There is a download of "Kensington MouseWorks™ Software Version 6.11" which might be what you need to make your mouse work. If this does not work, I'll see what else I can find for you. According to the site, it does work with Windows Me. Just out of curiosity, why are you still using WinMe?
Good luck,
Dragon PC Training & Repair
Jan 08, 2010 | Kensington PocketMouse 72214
How do I replace the battery(s)?
Try these steps, I had the mouse a while ago and this is the way I remember replacing the batteries:
1) Simply grip the sides of the mouse and slide the battery cover
back.
2) Replace the old batteries with two AAA batteries
3) Replace the battery cover
May 04, 2009 | GE Wireless Optical Mouse
Pocket mouse "hangs up" when I stop moving. Starts again if I cli
Had nothing to do with the reinstall of XP. Just put in new batteries. Guess it was just a coincidence that the batteries went dead (low) at the time I redid XP.
Jan 10, 2009 | Kensington PocketMouse 72214
Insertion of batteres on 72214 pocket mouse
Try this, Just behind the Left and Right buttons on the mouse, press firmly down on the part where your hand rests and slide to the rear. The batteries are underneath that cover. Hope this helps. Bud
Jan 02, 2009 | Kensington PocketMouse 72214
LX7 cordless optical mouse with dongle
Had the same problem. But before filling the logitech RMA from to get a replacement, I put new batteries into the mouse and the mouse worked again.
I am using rechargeable batteries, and I seems to me even if the green light on the bottom of the mouse is on, the driver warning for low battery does not come on. May be the volage drops to fast with a older set of batteries.
Try out new batteries. Hope this helps.
I am using the LX7 mouse for more than 2 years with lost of abuse (>10x drops from shoulder hight to hard office floor, sitting dongle in my pocket and dropping my backpack onto the floor with the dongle on the botton in the backpack).
Regards.
Oct 03, 2008 | Logitech LX7 Cordless Optical Mouse
DELL pOCKET dj
Hi
You can get one at batterytrader - click the link to go there - Dell Jukebox DJ battery for the Dell Digital jukebox DJ1st and 2nd, also the DJ20, - rechargeable replacement batteries
Nov 14, 2007 | Dell Pocket DJ MP3 Player
USB Mouse
You need a USB driver which the peripheral vender provides in order to use a USB mouse. Your P300 does not support a USB mouse without an additional driver.
Sep 15, 2005 | NEC MobilePro P300 Pocket PC
Kensington PocketMouse 72214 Logo
Top Kensington Computers & Internet Experts
dctocali
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
