Question about Casio MQ24-7B2 Wrist Watch
I want to change battery to an casio MQ-24 (705) wathc and I don't know how to remove the back.
Just put a small screwdriver blade between the case and the strap, in the center part, and gently lift it off. It will pop up and off. To put it back just press it into place again. Easy!
Posted on Sep 12, 2010
Testimonial: "Thanks! Solved"
How to change the battery on my casio w-753 watch
change the battery on my casio w-753 watch Lee, Check the attached links,video,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
replace the battery in the watch casio 753 CAR FLIP REMOTE CONTROL ALARM...
How to replace the battery on Casio watch
CASIO 753
Aug 02, 2016 | Casio W753-1AV Watch
Trying to find battery for casio watch MQ51W back of watch has 336 but no one has it.
I opened mine (back marked MQ-51W and 336) and it has a "371" battery.
Apr 18, 2014 | Watches
How do I change the battery in my Casio F-105
When I didn't see an answer, I tried it anyway since I already had the battery and little to lose. Undo the 4 small screws holding the back on (careful - don't drop them). Be careful to keep the small rubber gasket around the edge in its grooves. Do not take the workings out of the watch. There is a small silver arm running across the back over to a cream colored plastic piece with 3 grooves in it. Pieces of the arm are in the outer 2 grooves. Use something small to pry open the arm using the middle groove . Peel it back just a little and replace the battery. The watch should now be working. Snap the arm back in place, be sure the gasket is in place, put the back on,
and screw in the screws. Simple when it works.
Jun 19, 2011 | Casio Watches
How do you change battery for casio 1174 CMD-40?
I like these little RC IR watches. They're great fun!!! For this tutorial, you will need....
  • A small Phillips heads screw driver
  • A pin (or needle)
  • A replacement CR2032 battery
Instructions :
  1. Remove the 4 screws from the back of the watch
  2. Carefully remove the back plate, do not damage the delicate rubber seal
  3. Carefully remove the delicate rubber seal
  4. Use the pin to remove the small rubber block from the battery cover clasp.
  5. The pin should then be inserted in the gap of the white plastic lug, where the rubber block was removed.
  6. Use the pin to gently pull back the clasp of the battery cover.
  7. The battery cover will then open with a 5mm gap approx. It does not need to be removed.
  8. Use the screwdriver to remove the battery.
  9. After the battery has been replaced, just follow the instructions backwards.
I hope this little tutorial has helped.
Feb 10, 2011 | Casio Watches
How di i change the batteries in my Casio Pathfinder 2782
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Sep 20, 2010 | Casio PRG-40T-7 Pathfinder
    How do I replace the batteries on my Casio Pathfinder PAG40B-2V watch?
    Thank you for contacting FixYa.
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
    Sep 19, 2010 | Casio Pathfinder PAG40B-2V wristwatch
    Changed battery .A square piece of metal the size of match head fell out. No alarm or light, casio forester FT200
    mcdevito75 here, Of couse without the watch and piece of metal that fell out it"s very hard to say. Most likely it was part of the lock-down tab to keep the battery in place, in any event don"t lose that piece of metal. If your casio is working ok don"t worry about it, just don"t lose that piece of metal that fell out.
    Jul 05, 2010 | Casio Forester PAS400B-5V Wrist Watch
    How do I replace the lithium battery in a Casio Privia PX-100?
    mcdevito75 here, I've also riuned a number of Casio watches replaceing the battery, extra, extra care is needed, first remove the back cover screws, then you:ll have to remove another cover for the battery, after replaceing the battery the work begins, very carefully reverse the removal procedure, any un do pressure will cause the movement to break and the face of your watch will turn Black. Best with your casio is to let a watch repair shop change the battery, look for a small shop to save some money.
    Jun 14, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
    Casio module 2273 battery change
    did u ever figure out how to get the retaining clip?
    Mar 13, 2010 | Casio PRG-40T-7 Pathfinder
    Can't remember where the little spring go in the g-shock 300
    The used of the spring of your watch is for the speaker connection of the back cover of your watch. Your watch is still working even without the spring but no sound of alarm or whatever sound feature.Just go to watch service center im sure they have spear for the spring if not they can make spring from the watch spring bars.
    Hope it may help you;
    Regards;
    VOTIT
    DONT FORGET TO RATE;
    Jan 26, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
    Casio MQ24-7B2 Wrist Watch Logo
    4,724 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
