Question about GE Tritonr XL GSD6260JCC Dishwasher
The door is not closing. it appears higher on one-side than the other (like it was lifted)?
  • 101 Answers
Brokem hinge in dont think its replaceable
Posted on Sep 12, 2010
I have a 2005 ford focus and the rear driver door will not close. This problem appeared seemingly out of nowhere and I can't figure out why. Any ideas?
check the latch in the door jam it should be up if it looks closed try lifting it with your finger if it doesnt go up try unlocking that door while you lift on it
Oct 06, 2013 | Cars & Trucks
Location for the door lock relay on a 1993 olds ciera. It is not on the passenger side kick panel above the glove compartment. Does anybody know where it is?
It appears that the relay is located on the passenger side, behind the glove box, higher up close to where the bottom of the windshield meets the frame. Happy hunting.
Oct 04, 2013 | Cars & Trucks
I have a sears kenmore elite refrigerator. It is a side by side. The doors don't line up when closed. The freezer side is about 1/4" higher. It looks funny when closed.
there are plastic spacers located at the hinge on the bottom of these units, and they break after wear and tear , they are also beveled so they help the door close,, check to see if yours are in good order, if not you'll have to replace them,, to do this you remove the top hinge,, its just a couple of screws that hold the hinge on under the plastic deco cap ,, once you've done that Lift the door off the lower hinge,, install the spacers, and place the top hinge back once the door is reset
Aug 25, 2011 | Kenmore Side by Side Refrigerator
HP Photosmart 3310 All-in-One Printer - I opened the ink cartridge door & it now seems locked in open position - won't close.
Your printer does have a lock that clicks in when you open the printer to replace ink catridges. The User Manual has no specific comment on steps required to release the lock.
Is there a release tab/button that you grip when lifting? If so, suggest you try pressing this same release as you lift the cover, lifting slightly higher to see if the lock will disengage allowing you to close.
If no release tab/button simply try lifting slightly higher as above to see if the lock will disengage.
If either of these does not resolve isse I would inspect losely to see if there is a way to disengage the lock; simply using more force may result in damage.
Dec 22, 2010 | HP Photosmart 3210 Printer
Door has droped down and cant close unless you lift door back up
if you take the door off you can pack out the hinges with a fuw washers to lift the door up then it will close just fine
Jan 05, 2010 | Hotpoint HSS25GFP Side by Side...
DCS 30 inch oven door fell off
First thing is be careful them sprins are strong and will hurt your fingers bad if not careful. That said place both hinges in 1/3 open position they should stop there. if not put both all the way open then slide door back on and close. supposed to only lift off in 1/3 open position but whatever works.
Jul 25, 2009 | DCS RGS-305 Professional Gas Kitchen Range
Driver's side door not latching / closing
pull the outside handle and unlatch the latching assembly by hand by insertins a screwdriver where the striker would normally be if the door were closed - and pry out.
You can adjust the striker by loosening the bolts, and moving it in toward the cabin.
If the door itself is droopy, adjustments are made by the hinge by loosening the bolts and lifting up or down.
Multiple attempts will be necessary to get it just right.
Dont get frustrated if it doesnt fit properly in the 1st or second attempt.
Good Luck!!
Jan 16, 2009 | 2000 Chevrolet Blazer
Chev extend cab 2002 truck side window stuck 1/2 way down
Presumably an electric window? Stand outside truck with door open and hold the window between your palms. Gently lift the glass to a closed position while someone activates the control (with engine running). You should be able to determine if the glass is jammed (moving glass slightly backward and forward should aid movement) or if a little hellp makes the window move easily.
If the window appears jammed, it could be off the track. A repair would require removal of the door panel.
If the window appears to only require help to close, your door motor could be getting weak or some how the window track could be causing a bind.
At least you should be able to get the window closed.
good luck.
KK
Jan 12, 2009 | 2003 Chevrolet Silverado 1500
Hotpoint side by side door problem
Check the refrigerator for level. Front can be a little higher than the back. Check for products that many be stored that may be holding the door from closing completely. Check the door hinges and make sure they are tight.
Apr 28, 2008 | Hotpoint HSS25GFP Side by Side...
GE Tritonr XL GSD6260JCC Dishwasher Logo
51 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
