Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
I have a hosizaki ice machine. the warning buzzer is continious. is it the control board?
    Sergeant:
    Novelist:
  • 193 Answers
Check to see if you have the correct water pressure going into the machine. You need at least 30 psi. Also if your machine is water cooled, be sure cooling water is entering the machine. on water cooled machines there will be a continuous flow of water into the drain whenever the machine is running. If it is air cooled check the condenser coil to see that air is flowing freely through the coils.
Posted on Sep 11, 2010
  • dr_fixitlikn Sep 11, 2010
    plunty of water clean coils
    air cool
Why did my hoshizaki ice machine stopped making ice?
bin stat is what is used to shut machine down. if it goes bad in any way, no power will go to the control board. Start there.
Aug 11, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Where is the electrical box for hosizaki ice machie 255-bh
Not real clear of your question but most machines have the control box in the compressor compartment. It has a switch that shows: Wash, Off, Ice. Your incoming electrical is on the rear of the machine. Hope this helps ya.
May 21, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Hosizaki ice machne 3 beeps then after i reset it it runs for 7 seconds and shuts off?
the 3 beeps means that the freeze cycle is longer than 60 minutes. This could be because: float switch stuck, water valve leaking water into the sump, low on freon. If not one of those, it is a more technical issue that would require a service tech. Reset button is a small white button on the control board. Press it while the power is on to reset it.
Ice machine not harvesting
if you are sure the float swith is good and the dip switches on the board are correct, you most likely have a bad 1 minute timer on the control board. will have to replace board.
Nov 30, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Where is the LED found in a km500mwe
If you are asking about the LED's that are on the control board, the board is inside the electrical control box.
Aug 08, 2012 | Hoshizaki Freezer Commercial Ice Machines...
How to reset hoshizaki ice machine
small white button on control board. press once to stop beeping. Very small but it is labeled and very hard to see.
Feb 09, 2012 | Hoshizaki Freezer Commercial Ice Machines...
KM450MAB my machine makes a batch of ice then goes into harvest cycle and dose not come out of it, it gets realy hot. What can be the problem?
Probably the suction line thermister, this sensor should signal a timer in the main control board to initiate harvest. If the thermister is OK than there may be a problem with the control board
Nov 20, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Warning buzzer sounding
this is usually an indication of a temp. problem you need to check the seal around the lid,make sure there is not gaps and or the door was not left open.
Jan 31, 2010 | Kenmore 5 cu. ft. / 142 liter Chest...
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
177 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
