The program does not strart there is a signal F: 21
  • 15,935 Answers
“F21” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 11, 2010
2004 Chevrolet Silverado 2500 HD LS crew cab 6.0 4x4 right turn signal activates hazards. What would the steps be to diagnos this problem without purchasing parts that do not fix the problem
Do you know how to test automotive electrical circuit's using a wiring diagram an a DMM - digital multi-meter ? Do you know what a factory diagnostic flow chart is ? This will not set any diagnostic trouble code's in the BCM - body control module . Looking at factory symptom chart , their is no diagnostic trouble chart for your symtoms . Have four choices .
Hazard Lamps Always On
• Hazard Lamps Inoperative
Turn Signal Lamps and/or Indicators Always On or Flashing
• Turn Signal Lamps and/or Indicators Inoperative
Which one would you use to diagnose this problem .
Or would you just view wiring diagrams an wing it ?
Step
Action
Yes
No
Schematic Reference: Exterior Lights Schematics
Connector End View Reference: Lighting Systems Connector End Views or Body Control System Connector End Views in Body Control System.
Did you perform the Lighting Systems Diagnostic System Check?
YES - Go to Step 2
NO - Go to Diagnostic System Check - Lighting Systems
Verify that the turn signal lamps and/or indicators are inoperative.
Do the turn signal lamps and/or indicators operate normally?
YES - Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
NO - Go to Step 3
Are only the turn signal indicators in the instrument panel cluster (IPC) inoperative?
YES - Go to Step 4
NO - Go to Step 5
Test the inoperative turn signal supply voltage circuit to the IPC for an open or high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
YES - Go to Step 21
NO - Go to Step 13
5
Is only one turn signal lamp inoperative?
Go to Step 6
Go to Step 8
6
Inspect the inoperative bulb/socket for an internal short, poor terminal contact, or an open filament.
Was a problem found?
Go to Step 18
Go to Step 7
7
Test for an open, high resistance, or short to ground in the turn signal lamp supply voltage circuit. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 21
Go to Step 16
8
Inspect the IGN E fuse and the FLASHER fuse.
Is either fuse open?
Go to Step 11
Go to Step 9
9
Test for an open or high resistance in the following circuits:
• The turn/hazard flasher battery positive supply voltage
• The turn/hazard flasher ground
• The turn signal switch ignition 1 supply voltage
Go to Step 21
Go to Step 10
10
Disconnect the multifunction switch, turn signal switch.
Test the multifunction turn signal switch for continuity between the multifunction turn signal switch ignition 1 voltage input terminal and the turn signal flasher signal output terminal in each respective position. Refer to Circuit Testing in Wiring Systems.
Is continuity present?
Go to Step 12
Go to Step 14
11
Test the following circuits for a short to ground:
• The multifunction turn signal switch ignition 1 voltage
• The turn/hazard flasher supply voltage
• The left turn signal switch signal
• The right turn signal switch signal
• The left turn signal lamps supply voltage
• The right turn signal lamps supply voltage
• The trailer left rear turn/stop lamp supply voltage
• The trailer right rear turn/stop lamp supply voltage
Go to Step 21
Go to Step 14
12
Test the following circuits for an open or high resistance:
Go to Step 21
Go to Step 15
13
Inspect for poor connections at the IPC. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 21
Go to Step 17
14
Inspect for poor connections at the multifunction turn signal switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 21
Go to Step 19
15
Inspect for poor connections at the turn signal/hazard flasher module. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 21
Go to Step 20
16
Repair the ground circuit of the inoperative lamp. Refer to Wiring Repairs in Wiring Systems.
Did you complete the repair?
Go to Step 21
17
Important: Perform the set up procedure for the IPC.
Replace the IPC. Refer to Instrument Cluster Replacement in Instrument Panel, Gages, and Console.
Go to Step 21
18
Replace or repair the inoperative bulb/socket.
Go to Step 21
19
Replace the multifunction turn signal switch. Refer to Turn Signal Multifunction Switch Replacement in Steering Wheel and Column.
Go to Step 21
20
Replace the turn signal/hazard flasher module.
Go to Step 21
21
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 3
Jan 06, 2018 | Chevrolet Silverado 2500HD Cars & Trucks
Code 21 nissan stagea ignition signal
3_25_2012_4_37_01_pm.jpgIf you are distributor here is the need,Here is a stage.3_25_2012_4_39_42_pm.jpg
Mar 25, 2012 | Cars & Trucks
I am using Panasonic KX-T7730 i could not make out going calls wich strarts by " 0 " i change my phone but the problem is still there My extension number is 114 we are using pbx system
Is your extension programmed to allow dial 0 calls? The phone is just an instrument, it has no programming. Guess where the program is and who controls it? Yep, see your system administrator.
Carl
Apr 14, 2011 | Panasonic KX-T7730 Corded Phone
My laptop with windows 7 is start up with a black screen and ask me wath operation sistem i want to strart windows 7 an 2 more but this 2 more no starting only w 7 this problems came before i instal a...
hi jose,
what is the problem exactly? this 2nd operation system appearance? you want to get rid of this black screen and go directly to win 7, correct?
thank you,
dim
Mar 22, 2011 | HP Computers & Internet
Remote will strart car then shut right off will do it the three time will not stay running
Here is the link to get the manual. http://www.caralarm.com/manuals/MARS/MARS-22.pdf
See pages 20 & 21 ( see picture) With the engine running you will turn either the Smart Start or Tach Wire adjust screw, depending on which setting your box is set on. You will turn one or the other until the LED LIGHT blinks consistently.
Sep 22, 2010 | Omega MARS-22 Remote Vehicle Starter with...
1993 nissan altima code 21 ignition signal - how to fix/repair
Replace the O2 Sensor, reset the ECU, and subject solve.
Good luck.
Jul 19, 2010 | 1993 Nissan Altima
I want to delete symantec from my pc.
Press strart---control panel---add/remove program, press in norton and press remove.
Apr 30, 2010 | Toshiba Satellite A60 Notebook
Ipod hang gogear display
my ipod get hanged while playing song how can i solve this problem
Jul 20, 2009 | Philips GOGEAR SA6045 MP3 Player
About lurn
try this online tutorial
http://www.vbtutor.net/vb2008/vb2008tutor.html
Oct 20, 2008 | Computers & Internet
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
