Question about Craftsman Garden
Replaced all lines (2) plus bulb and still can't prime blower.. if I put gas in spark plug hole runs fine.. even tried leaving off the filter in tank. thanks
    President:
  • Craftsman Master
  • 1,545 Answers
I am under the assumption the primer bulb is atop the carburetor. There are check valves under the bulb in the primer base assembly of these carbs. Sometimes, the valves stick and sometimes they go bad completely. There are very small and for all practical purposes unserviceable, however...you can try this...pull the fuel lines off of the carb and spray WD-40 into the brass inlet and outlet. Remove the primer bulb again and liberally spray some WD onto the top of the primer base assembly...this being done in hopes of freeing up a sticky check valve. If you have extra or old fuel lines, hook them to the carb...inject WD-40 and work the bulb to attempt to move the lubricant back and forth out of the carb. Sometimes this works, sometimes not..if valves are bad. There are replaceable parts and kits for the primer base available on the manufacturers websites. The primer bulb does not have to be completely full of fuel to allow the engine to run, but the base assembly can cause problems in fuel flow to and from the carb and even mimic a flooding condition. Don't use carb cleaner and dont soak the carb in any,. Try this and post back if needed.
Please vote on this solution.
Posted on Sep 11, 2010
Weedwacker has fire to the sparkplug and new gas to the primer bulb but will not start
sad these little gas engines always fail when we don't want them to . requires a lot of compression to run and if not properly oiled thru the gas will fail .
Aug 08, 2015 | Craftsman 27cc 2 Cycle Crank Straight...
How do you fix the plastic gas line? It doesn't stay in the gas tank. When I prime the bulb the gas squirts out and when the echo blower is in use, gas ends up leaking on my leg.
The holes in these gas tank are made to fit available fuel lines tightly enough to prevent the problems you are having. If yours is leaking either someone put on too small a fuel line or made the hole larger so it would be easier to put the fuel line in the tank. The only fix is to get the next size larger fuel line or replace the tank. You can try to seal the line with RTV or silicone but he gas will degrade it and it will leak again plus you'll have a harder time the next time the line has to be replaced.
Jan 05, 2011 | Echo Back Pack Blower Rack Fits Stihl...
Won't prime, the only way i start it is to remove spark plug and put fuel in cyl. I have replaced the primer bulb and line, and the fuel mixture is correct, My next step was to buy a new carb?
try to keep it running on wd-40 after you get it started and sometimes it will clean-out the carbs varnish blockage,if not remove and clean or replace the carb
May 13, 2010 | Troy-Bilt 31cc 2-Cycle Gas Powered...
Craftsman gas leaf blower will not start. Spark and gas lines ok. Not getting gas to plug even after prime and several pulls. How do I find gas supply problem. Diaphram in carb looks ok .It actually...
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 25, 2009 | Craftsman Garden
I have a 25cc Craftsman Blower/Vac model 358.794941 which will not start. I have replaced the spark plug and carburetor. This is 2 years old and not even 10 hours on it.
hi
if you have compression and spark(a blue one) try priming the engine,put some gas in the sparkplug hole and start the engine.if it fires only the gas you putted inside there is a delivery problem to find and fix(carburator and hoses.
bye
Oct 05, 2009 | Craftsman Garden
Crafsman gas blower: fuel lines to primer bulb had to be reconnected; now blower won't fire at all. Replaced plug and made sure it sparked; still nothing when I try to start.
Hi
Priming the engine(put some gas in the sparkplug hole ,after you have checked the sparkplug,the colour of the spark has to be violet).Start the engine.If it starts there is a carburation problem,change the fuel lines to primer bulb.
wish you good luck savumihai71
Dec 04, 2008 | Craftsman 4 Cycle Blower/Vac
Featherlite will not start
Suggest , Clean Spark plug with Gas and wire brush.... drain all gas, add new gas with correct gas:oil mixture..... spray Gumout/Carb cleaner in air intake and spark plug hole.. these are the easy solutions to try.. good luck -Doug
Nov 21, 2008 | Poulan Featherlite Gas Blower, with Low...
Leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Oct 25, 2008 | Craftsman 4 Cycle Blower/Vac
Poulan leaf blower won't start
I had spark and compression. It was definately a fuel delivery problem as the primer bulb was not filling with fuel. I tried taking off the carb spraying it with cleaner, blowing compressed air through the fuel lines and removing the fuel filter.
Finally I took the top of the carb off (the two screws holding the primer bulb on). I sprayed the ports with carb cleaner and used compressed air to blow through the fuel inlet and outlet.
When I put it back together, the bulb filled with fuel on the first prime, and the engine fired up on the first pull. The throttle response is also much snappier than it has ever been.
I'm not a mechanic, but it worked for me. Hopefully it will help someone else.
Oct 20, 2008 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Garden Logo
357 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
