Question about Microsoft Xbox 360 Console
Xbox wil not start light turns green then turns to red
  • 4,102 Answers
Hi you have got the dreaded red ring of death, this is very common with all xboxes and their are people out their that will fix them for you for a fee.
their is nothing you can do yourself to solve this problem as its a case of taking the xbox apart and removing the heat sinks and the x clamps and fitting new parts and new heat sink paste, this is a big job and requires special tools. so its not for the novice to do.
i do the repairs to these on a regular basis and 8 out of 10 i fix work again but others tend to be to far gone.
any way the reason you are getting this warning light is due to it over heating, check the date on the sticker on the back of the xbox as it is covered by warranty for 3 years for this exact fault so if its less than 3 years old go to the xbox website and get them to replace it for you, if its outside this time then you have 2 options you could either repair it or sell it.
you can buy repair kits and get the instructions off the net but without having done it before it can by really hard to do and you could do more harm than good.
when they built these they used cheap parts and cheap heat sink paste now over time this causes it to over heat and then you get the dreaded red ring of death and this shows you the either the gpu or cpu chip has over heated.
now the repair involves taking the xbox apart which is not easy but can be done you need to then remove the x clamps and then remove both heat sinks. once their removed you need to clean them up and remove all the old heat sink paste and use new paste, you also need to get xbox rrod repair kit as you wont be using the cheap x clamp bits anymore these will go in the bin as this is what caused the problem in the first place.
let me know what you would like to do or if you need further assistance ok
i also be damaged xbox's but im based in UK
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Sep 11, 2010
My xbox 360 will not turn on just getting the orange standby light on power adapter. what do i do to get it started up again?
If the power pack wil not go green - it sounds very much like it is the faulty component. Be careful when purchasing a new one that it fits the back of the xbox and has the right wattage - as they do vary.
Apr 09, 2010 | Microsoft Xbox 360 Console
My xbox controllers will not charge with the plug in kit. The light turns red, then either immediately green, or it starts to blink red-off-red-off.
I had the same problem. The Battery pack on mine was dead for a long time as i havent touched my Xbox 360 in a while. So
SOLUTION
Step 1. Plug the play and charge cord into the controller
Step 2. If Light turns green within a minute or so, Unplug the play and charge cord and go to Step 1 (Repeating this process until the light stays red on the play and charge cord (3-10 times))
Oct 08, 2009 | Microsoft Xbox 360 Controller
Two red and green lights around the on button?
http://ezinearticles.com/?What-Do-Xbox-360-Red-and-Green-Lights-Mean?&id=1981493
Jun 15, 2009 | Microsoft Xbox 360 Console
2 Red lights for player1 and player2
Check the light on the power supply and if its orange that means that the console is on stand by mode, The light on the Power brick should be green when the console turns on. if the light turns red that means that the power supply needs to be replaced. call xbox support and check the warranty status of your 360
Mar 29, 2009 | Microsoft Xbox 360 Console
2 red light
I suggest you to try DIY Guide that wil explain solving the 2 red lights along with some other common problems of Xbox like Disc Read Error, No Video/picture Problem and most famous RROD. Even a novice can solve the problem with the help of step by step process given at the guide. I think it's worth trying. If you try this method, you won't have to wait for 3-4 weeks and you can enjoy your gaming experience within 2 hours, once you try this guide.
Oct 18, 2008 | Microsoft Xbox 360 Console
Two red rings
that meas your xbox is broken
Jul 16, 2008 | Microsoft Xbox 360 Console
3 flashing green lights!
I would call xbox, worst case scenario, they will give u a new controller.
Jul 06, 2008 | Microsoft Xbox 360 Console
XBOX - Flashing Red Ring on console after startup,
I had the same problem & it turned out the plugs wernt all the way in so check & make sure thaey are in
Aug 01, 2007 | Microsoft Xbox Console
Center light flashing red and green
If you have not "opened" your Xbox (taken the case off the main unit) and you are having problems, think about calling 1-800-4MY-XBOX that is the customer support number for Microsoft. If you have had it less than 90 days it should be covered under warranty. If you open the unit they will no longer fix your system for a reasonable charge and it will be cheaper to buy a new one. Check out some of the light errors here http://www.llamma.com/xbox/Repairs/xbox_motherboard.htm It depends on your exact sequence of flashing lights as to the exact problem. Hope this helps.
Jul 01, 2007 | Microsoft Xbox Console
Microsoft Xbox 360 Console Logo
85 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
