Question about Kenmore Chest Freezer 16352
Split in plastic liner middle of freezer from top to bottom and ice build up
    Master:
    Sergeant:
  • 449 Answers
Defrost your freezer
Posted on Sep 14, 2010
Ice collects on the bottom of my frost free woods freezer
im not sure if i answered this one before. but this sounds like a blocked drain, the drain is located midway behind the shelves, you can take away the catch tray and poke a coat hanger down this hole hole to dislodge the blockage.
Nov 10, 2009 | Woods 201 cu. ft. Upright Freezer V2003RW3
Frost forming on top of inside door by hinge
you probably have an air leak. if the gasket is bad it needs to be replaced. Air could also be coming in through the door flap if you have water and ice dispensor on door
Sep 17, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have an upright freezer and replaced the rubber gasket around the door. It is not sealing correctly and ice is building up and also, water is leaking from the bottom of the door. It is a Fridigaire...
ice on top of freezer door they came out with a fix but does not work two vent holes on bottom of door seal mthem off with silicone moisture getting in if that don't work you need to take liner off and spray foam the liner cavities
Jun 29, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
FREEZER TOO WARM
Hi, Are you seeing ice or frost? Is frost building up on the freezer back wall? I can help you, just need to be clear.
Thanks
Vic
May 24, 2009 | Freezers
Ice build up
You should to check the Whirlpool Gladiator Freezerator's door sealer to make sure all rubber or plastic seal very well to prevent air humidity come in to build up frost fast. Also, you have to defrost completely and wipe with cloth or paper towel to absorb all waters out and let it dry completely to prevent frost build up.
May 08, 2009 | Whirlpool Freezers
BEKO AB910 Frost Free Fridge/Freezer Ice build up
I have the same model + problem. You should not need to defrost this model manually if it's working correctly, but the ice build up you describe is probably due to a blocked pipe in the auto-defrost system at the back. You need to defrost properly to prevent recurrence.
Behind the upper freezer drawer there's an aluminium tray behind a plastic grille. Every few days this tray warms up to melt any accumulated ice behind this plastic grille (full height of the freezer). A pipe should take the meltwater down to a plastic tray below (pipe + plastic tray are visible if you take the lower panel off the back). Your problem is too much ice blocking that pipe: the heater can't cope and it doesn't melt, so the ice 'cascades' down the back behind the bottom drawer.
When you manually defrost, you must ensure that this pipe is clear, otherwise the auto-defrost won't work, and you may have to defrost manually again within days.
I have found that the best way to defrost the pipe is to remove the lower back panel, disconnect the corrugated flexible plastic pipe from the stub that comes from the bottom of the freezer, + pump steam into the stub (gently) using a hand-held steamer (with tube + nozzle). You don't have to empty the freezer or move your food as the door stays closed, and no steam gets into the freezer until the pipe is unblocked. Be sure to unplug the freezer before taking the back off! [There is a fan in this area that could start up without warning]
Check how much of the pipe is blocked by gentle probing with a pencil: the aluminium tray is about 105mm above the bottom of the stub. This measurement is important…
When the pipe is clear, there may still be too much ice in the aluminium tray above (not sure how much is 'too much') if you only created a narrow 'chimney' though the block of ice (likely to get blocked again). You need to widen that chimney by melting more of the ice in the aluminium tray. I use a simple steam nozzle made from an old-fashioned Bic pen with a couple of 1mm holes drilled just below the coloured bung at the end. This directs steam onto the walls of the 'chimney' rather than upwards.
There's no point steaming the walls of the plastic 'stub' pipe, so only use the home-made nozzle when your probe reaches 105mm (i.e. when you have melted all the ice in the plastic stub tube but before your 'chimney' has broken through the block of ice in the aluminium tray). If you judge this right, you'll melt almost all of the ice under a still-frozen top surface: no steam will get into the freezer and your food will stay frozen. With a probe it will be clear when you've broken through the top surface of the ice. When you have done so, it's time to look inside the freezer to see how well you have cleared the aluminium tray.
It's perfectly feasible to get all this done in 30 minutes.
Don't forget to replace the corrugated plastic pipe + valve at the bottom. It stops humid air from going into the freezer and icing up in exactly the area we've just been defrosting.
Take a lot of care with steam jets as they can burn you badly. You should check a first aid website so you know what to do BEFORE it happens.
Some of these tips may be helpful: (1) run the freezer at -18 degrees (the 'warmest' setting) so it's not working so hard. (2) Leave a big gap (>100mm) between the back of the freezer and the wall. (3) Clean the matrix of delicate tubes to the left of the fan whilst you have the back off [a small bottle brush is ideal; remove the fan for better access]. (4) Put something between the middle of the freezer and the wall to prevent the warm air that's being blown out behind the fridge from being sucked into the air intake behind the freezer (there is a baffle built in underneath, but nothing behind. (5) Mount the fan on spacers (with longer screws) so that it's closer to the heat exchanger… this means that a larger area of grille can act as an air intake. (6) Raise the unit off the floor a little to free up the air intake path beneath the freezer.
Apr 23, 2009 | Freezers
Top & middle shelves COVERED with frost/ice, not middle
That is normal. The refrigerant runs through those shelves. They are the evaporator side of the unit.That is where the freezing effect comes from.
Check door seals for leaking air.
Keep door openings to a minimum.
Get in there and get out.
Those things will help prolong frost/ice buildup.
Mar 12, 2009 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
ICE BUILDUP ON BOTTOM OF FREEZER, DRAIN HOLE FROZEN
There is normally a small filiament of metal which is attached to the defrost element and conducts heat down the drainpipe preventing ice build up. You can pour some boiling water onto this area and even wriggle a piece of plastic tubing down the drain pipe to dislodge any blockage. For future prevention, you can attach a piece of copper wire around the defrost element (in the absence of the original filiament) and extend it down the drainpiple
Mar 05, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Ice build-up on the inside top of of freezer door
yea def , not normal, nor an acceptable amount of ice forming there( good pic). heres what i have been told to try and with good results
first make sure the door gasket is sealing all the way,(small gaps in ht emagnets at extreme corners) is common but with a little amount of "mortite"or "permagum can sometimes be insterted behind the corner of gasket to assist filling the void.
second a small amound of a white/clear silicone be applied to the outer perimtere of gasket, to minmize air movemnt from between gasket and door panel.
lastley in oyour second pic i see "frost free" written on a plastic air deflector. you can remove that with 3-4 screws on backside of it, and then reinstall with a small spacer so as the baffle now with sit with a 3/8in. gap between it and the top of the freezer liner.( a brass ferrel from the compression fitting of a plumbing fitting is just the right size)..... the theory behind this is to prevent the air from gatting "trapped" in the void created when the door closes-- air can now pass back and forth freely.
I hope this gives you some satisfaction if not I would advise another tech be sent who is willing to call for factore tech support( ths is where i got my info from)
Jan 14, 2009 | Frigidaire 13.7 cu. ft. Upright Freezer...
Door liner on chest freezer broke due to ice build-up
if you can't find a replacement, use a piece of flat vinyl siding that goes on houses. You can heat it and bend it as needed, or cut it and screw the pieces to a balsa wood frame for lightweight support. Glue or epoxy probably won't work as the cold temps make them brittle but external caulking may be ok to hold the pieces together. Be sure to sand all edges and corners as the cut plastic can be sharp. If you can disassemble the unit and place the door face down, you can fill the cavity with insulating foam to help stabilize it.
Nov 27, 2007 | GE 25.1 cu. ft. / 711 liter Chest Freezer...
Kenmore Chest Freezer 16352 Logo
94 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
