Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
How do you get the pulley and nut off on the cutting pulley to change it?
  • 183 Answers
The easiest way is with an impact tool. It will spin the nut faster than the shaft can spin and will remove it very quickly. If you do not have an impact tool, then you will need to stop the shaft from turning. Put a large clamp onto the under side of the deck and then rotate the blade around against it. This will stop the shaft from turning while you remove the nut. If you have already removed the spindle assembly from the deck, you will have to clamp the lower end of the shaft in a vise to be able to remove the nut. It should be a standard threaded nut, which will remove when turned counter-clockwise.
Posted on Sep 12, 2010
How to change the transmission drive belt on a Troy-Bilt riding mower
IF YOUR MOWER COMES EITHER TRANSMISION AMD DRIVE BELT OR ONE EXTENDED BELT, YOU HAVE TO LOSE THE CUTTING DECK AND DISMOUNT THE OLD BELT, TO REPLACE THE NEW ONE FOLLOW THE DRAWING NORMALLY PRINTED ONYSTHE DECK ADJUST TENSION WHEN YOU MOUNT BACK THE CUTTING DECKALOWING THE BELT TO BE LOOSE A LITTLE, BY PUSHING THE ONE PART OF THE BELT IN BETWEEN PULLEYS FOR A ONE INCH OF PLAY AND YOU ARE SET.
Jul 01, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
How to remove front axle on 1999 saab 1999
TO loosen of the idler pulley it is essential that the pulley nut first be loosed off to allow the shaft to be moved . The allen head screw unless it is seized up(rusted) will move freely once the pulley nut is loosened. Before you go to extremes consider other alternatives .--removing the pulley off the shaft ( cut the belt to achieve this) see if there is room to attach vice grips in the head of the screw . If you have space ,drive an allen key slightly larger into the hole. (SAE instead of metric). The absolute thing I would use is a torch in that area as you could wind up burning harness wires or setting fire to the vehicle. If the screw head is in an awkward spot remember that longer bars /extensions may make the job easier.
May 17, 2014 | 2008 Saab 9-5
Need diagram for belt instalation for murray 46" cut
Select Index Numbers here:
2 Asm, Jshaft Housing Head W
3 Q2 Pulley , 46"
4 Shaft, Splined Jacks
6 Nut, Pulley
7 Hub, Blade Adaptor
8 Q4 Blade 46" Mulcher
9 Washer, Bellevile(ard
10 Washer Hardened (ard
11 Nut Hex (ards)
12 Screw, 3/8, 16X1.25
24 Rod Belt Guide
25 Belt Cross Drive Ja
26 Belt Primary 46" J
34 Bracket Cover
35 Bracket, Pulley Cover
36 Qx Lburg# 094605E700 -INACTIVE-
37 Use Lburg# 093349 Zi -INACTIVE-
38 5/16, 18 Hexwdfllk Wh
39 Screw, 5/16, 18X.75HH
40 Cover, Pulley Right
41 Screw, 10, 16 .190X.62
72 711327
72-1 Wheel, Gauge
72-2 Bolt, .500X3.275HHSH3
72-3 Spacer, Slev .515X1.
72-4 Nut, 3/8, 16 Hxctrlkj
72-5 Qxcolor Code Require -INACTIVE-
79 Pin Detent Ring (DP5
80 Asm, Mulcher Plug 46
81 Bolt Carriage (ards
82 Nut, Wing (ards)
89 Zerk, Grease Fitting
Apr 21, 2014 | Murray 46 Primary Lawn Mower Blade Belt...
The drive belt on my husqvarna yth20k46 is off at the pulley above the transmission. How do I get it back on? Do I have to remove the nut at the transmission shaft?
I would remove the nut and pulley. Get belt top of pulley. Start the edge of belt in broove on pully and run it around. You get easyer belt in pulley and install it. May have pull little against spring.
Mar 31, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Spindle pulley will not stay on
try putting some nail varnish on the nut threds to lock the nut up,,,,(pinch some off the wife?) it works just fine, or change the nut for a nylon lock nut,,,
that cost money,,,
Mar 27, 2010 | Shop Fox W1670 1/2 HP Floor Radial Drill...
I changed the blade mandrel from my 42 inch cut craftman mower, I need to put it back together I need a directions on how to put the spring and pulley back on also I damaged the nut on the pulley, What...
Ok Go to partdirect on the Sears website. Enter the 917. xxxxx number that will bring up the drawings and should show you were the spring goes. As for the lock nut its 9/16-18 .You should have gotten a new locknut with the new mandrel.
GOOD LUCK
MIKE
Oct 22, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Where is the tensioner release on 04 F250?
Depends on what engine sometimes but you should see a pulley with spring loaded arm pushing against the belt. That arm will probably have a 1/2" socket drive cut into it, or just a nut in center to pull/push on to relieve tension. Pretty strong spring so it takes a little grunt to get it to move.
May 04, 2009 | 2002 Ford Mustang
Kenmore washing machine he3
I have a Whirlpool Duet HT washer [12-4-2003] and I'm on my 3rd pulley and 4th belt. I am convinced This is a inherent design flaw. I've used Loc-Tite and the nut loosened, but the last time I used gorrilla glue. The nut didn't come loose but the pulley failed and now I need giant vice grips or I may have to cut the nut off with my Dremmel. My hypothesis is when the drum is overloaded it puts stress on the shaft/pulley connection and the softer metal gives way. Over time the key becomes rounded and the pulley starts to wobble, thus leading to belt failure. My next version. Im considering drilling into the shaft and installing a cotter pin to keep the nut from backing off. Either way the problem originates with the pulley design.
PS. I will never buy another whirlpool product. 070498b6-8a05-400f-aab6-d2f7fbf10685.jpg
Jul 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9100LW1, belt came off
I had the same problem and being a procrastinator, I waited until the belt came off before launching a full scale investigation into the knocking noise it had been making for about a year. Here is what I found and below that is my no guarantees fix.....
I removed the nut and pulled the tub pulley off. I noticed the tub shaft has a "shoulder bolt" and the pulley could not be tightened onto the shoulder bolt with enough squeeze to keep the tub pulley from wobbling. Tolerance issue... maybe? I decided to measure the keyed tub shaft with calipers and found the thickest part of the shaft to be 1" ish. The Shaft is part of the tub bearing assembly (from my observation) and the tub shaft is part of the tub bearing which measured 1 1/4" diameter. I found a washer that was 1" inside diameter and 1 1/4" outside diameter and placed it over the tub shaft behind the tub pulley. I tightened the nut snugly and reinstalled the belt. Ahhhhh, quiet operation and no more wobble. I will let you know if it causes another problem but from what I can tell.... replacing the tub pulley with another of the same dimensions will not work.
you don't need a very thick washer(my washer is too thick (.1"ish) so I will replace it soon(yeah right) with 1/32" or maybe 1/16"...I used rubber but I think steel or brass or what ever would probably work too.
Purists will tell you that the lock nut should be replaced, or if you don't use the permanent thread locker you could use loctite.
Hope that helps.
Feb 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
114 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
