Question about Blaupunkt Car Audio & Video
Hi, I have a Blaupunkt Woodstock DAB 53 car stereo. I havent owned this car for long so I'm still unfamiliar with the stereo an its various settings. I had it set up the way I like it however, it was in the garage for a service and when I got it back there have been changes made to my settings. I was able to return most of the settings to my preference, however tehre is a beep that I hear at random times when listening to the radio. It is present on all radio stations. I would like to know how to get rid of this beep as it is very annoying. It is the same beep that you hear when setting the stereo up, fgor example storing a radio station.
freetek
  • 5568 Answers
SOURCE: jvc car cd/radio
The radio was improperly installed; there are two 12V leads, one services the radio when on, the other, only the circuitry for the clock and presets.
Eventually, this shouldn't be needed if the manufacturers ever think about using a little bit of flash memory for the presets and a coin cell for the clock.
You didn't give any model number so researching the manual is impossible.
If you can find the model number, look for a user's (or installation) guide on line to find the wiring info.
Posted on Aug 25, 2008
natenash7986
  • 53 Answers
SOURCE: Pioneer DEH-1700R - Storing Radio Stations permanently
your constant power wire is not hooked up or it has come loose that is why nothing will stay saved on the unit have it looked at and see if they wont fix your problem cheap...... its a easy fix
Posted on Sep 24, 2008
SOURCE: Setting the reset stations on a DAB radio
I used lateral thinking! looked at the instructions for my other matsui DAB radio and worked it out from there. With this Ferguson model you have to find the station you want manually and then press one of the preset buttons (it only has 4 but these are enough for me)
Posted on Jan 11, 2009
jyackle5
  • 8197 Answers
SOURCE: stereo stations wont stay set
If you have a yellow wire that is the memery wire. It needs to be hooked to a constant hot. If you do not have one you need to get a new plug for the back.
Posted on Feb 24, 2009
Testimonial: "Thanks for the help. everything works perfect "
SOURCE: blaupunkt woodstock 54 has a mind of its own...
Hi
Ive got the same unit & they can be a bit unpredictable.Theres a way around it as the unit facilitates a 'NORMSET' feature which allows the user to reset the unit to basic settings as when it was first taken out of the box.
Also the sd card you use can only be 1gb or less & has to be formatted in 16kb through windows XP or Vista.
If you want to know more get back to me & I will talk you through it,it sounds like the units been corrupted by a sd card that wasn't formatted correctly as this happened to mine but now is sorted.
The WOODSTOCK Range aren't made anymore,the latest version is the NASHVILLE,and I was advised that my unit may have had to go back to Germany for reprogramming as no-one really knows about them in the UK.
However I sought advice and problem was rectified.
Posted on Feb 27, 2009
I have a blaupunkt woodstock dab 54 and its stuck saying wait 1h HELP!
by default you have 3 chances to enter your code, after then time is get much longer for you to wait. what you can do is still keep your radio power on and leave it for 1 hour, Do not power Off. the cycle of wait will reset. then you can try enter you code again. hope its help.
Aug 02, 2014 | Blaupunkt Woodstock DAB 52 CD Player
My woodstock dab 54 reads kcard not ok after i changed the battery and wont let me keycode number
Hey I could do with help on this as I have lost the kcard (Ihave the code)
Feb 18, 2012 | Audio Players & Recorders
Intermittent bleeping on tuned - in -stations
You have the traffic updates on - I'm not sure the traffic function has ever really worked on the 52 but turn it off and you should lose the annoying beep. As an interesting but annoying aside, you won't find this info on the Blaupunkt FAQ page searching under 'beep' because they describe the noise as a 'peep'... go figure!
http://www.blaupunkt.de/index.php?id=882&no_cache=1&L=1
May 11, 2011 | Blaupunkt Woodstock DAB 52 CD Player
Hi, I have a Blaupunkt Woodstock DAB 54, where I don't have the Master Key Card. I can see that I can use a normal SD card, and enter the 4 digit master key again. But I dont have it. I can see that we...
Hi , try 7589 , not sure if it will work but its a maybe , i also have a dab54 and i got the key wrong 3 times , now its been stuck saying wait 1 hour for the past 8 hours , i think imma introduce my hammer to it , hope the code helps :)
Apr 30, 2011 | Car Audio & Video
Peugeot sterio code
You need to ring the Peugeot Dealers, as I had that problem with my Nissan radio on my Nissan. The dealers were able to immediately provide me with the right code to input and radio has worked no problem since. When I disconnect battery I always need to re-input the same code.
If your Blaupunkt wasn't Manufacturer fitted, then whoever of your previous owners who fitted the stereo would have the code, or have you tried Blaupunkt themselves, don't know if they keep codes?
Jul 07, 2008 | 2005 Peugeot 405
Blaupunkt woodstock 54 has a mind of its own...
Hi
Mar 21, 2008 | Audio Players & Recorders
Car Audio & Video Logo
83 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
