Question about Mitsubishi Televison & Video
Replaced lamp. timer won't turn off - Mitsubishi Televison & Video
  • 201 Answers
I think the timer light is blinking to indicate the lamp usage is near end of life, it doesn't actually know if lamp is bad it is just a counter. I beleive if you go into the tv menu and look for timers you will see one for the lamp. You can reset it and the counter will be reset to 0 and blinking should stop.
Posted on Sep 11, 2010
How to reset tv lamp on mitsubishi wd-65831
RESET LAMP TIMER
    • 1 Turn on the television after replacing your television's projection lamp with a new unit. If a dialog box displays on the screen asking you to reset the lamp timer, use your remote control's "Arrow" buttons, highlight "Yes" and press "Enter." If the dialog box does not appear on your screen after turning your television on, proceed to the next steps.
    • 2 Turn on the television, then press the "Menu" button on your control. Navigate to the "Setup" menu, press "Enter" and choose "Low Powericon1.png" from the menu options displayed on the screen. Press the "Exit" button on your remote control and turn off the television.
    • 3 Repeat the first step to reset your television's lamp timer. If your television screen is unable to produce a picture after replacing the projection lamp, press the "<", ">" and "Power" buttons on your remote control at the same timeicon1.png to reset the lamp timer.
Read more: http://www.ehow.com/how_7358147_reset-lamp-timer-mitsubishi-65731.html#ixzz33n0pJu2S
Jun 05, 2014 | Panasonic Televison & Video
Replaced XD300U projector lamp. Need to know how to reset lamp timer. Won,t turn on because lamp timer has expired to 0. Needs to be reset. Lost our manual. Please help.
"Reset the lamp counter
i. Press and hold Exit on the projector
for 3 seconds to display the total used
lamp time.
ii. Press Menu on the projector or on
the remote control to access the lamp
hour timer. An adjustment message
will appear.
iii. Press or to reset lamp hours
and press EXIT to leave."
Apr 21, 2008 | Televison & Video
DT27 model won't turn on
1) DT27 timer is same as Kichler 15559.
I don't think either product is still available unless another company such as Brinks has taken over the design.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#DT27
2) Change LR44 batteries
And then reset timer by depressing reset button.
Reprogram.
Check light bulb is operable, and lamp switch is ON. Move timer to different outlet.
Check circuit breaker.
Plug in different lamp.
If functionality is not restored, then buy another timer such as Intermatic DT620 with lifetime warranty (shows just above DT27.)
3) Many timers today do not require battery and have internal rechargeable battery instead.
Timer designs change because CFL and LED bulbs are inductive loads, while many older timers were rated only for resistive loads such as incandescent bulbs.
Jan 28, 2013 | Intermatic Hardware & Accessories
Samsung HL-T6756 DLP TV Standby/temp light flashing and tv won't come on. I have replaced the lamp and the fan is working. Any suggestions?
Remove lamp and inspect the color wheel to see if missing pieces or shattered---it will also just before failing give a high pitched or fan like sound and if running too slow or not at all instant shutdown happens.
Its also possible if you bought a GENERIC bulb--and used original cartridge the new lamp is bad.
Apr 09, 2012 | Televison & Video
I recently replaced the TY-LA1000 lamp but I'm getting a yellow flashing light that goes on every 5 secs.I made sure that it was installed correctly and tried resetting the timer by pressing + and - o
Yellow flashing light? Did you get any picture? Bet, not!
It means: your lamp door interlock is not engaged: did you forget to turn the locking knob? Did you install lamp compartment door? That might be the only issue. Lamp timer blinks 'red", while TV works normally. Reset the timer, it's gone, along with annoying message. Yellow means: interlock or thermal protection is off. Try to repeat lamp installation procedure. then, you'll find out your mistake. don't need to remove the lamp. It would be "red", if lamp won't fire up.
good luck,
Alex.
Dec 06, 2011 | Panasonic Televison & Video
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
Replaced main bulb in front but lamp button on front of tv is still blinking and tv won't show picture
The lamp timer on the Hitachi projector must be reset whenever the lamp has been replaced. The "Lamp" indicator on the display will light red or the "Change the Lamp" message will display when the lamp timer needs to be reset. Hitachi recommends that the lamp timer never be reset without replacing the lamp and to always reset the timer when the lamp is replaced. The message functions of the projector will not function properly if the lamp timer is not correctly reset.
  • Turn the power on. Press the "Reset" button for three seconds until the "Lamp xxxx hr" message appears on the lamp timer on the bottom of the screen.
  • 2
    Press the "Menu" button on the remote control while the lamp timer is displayed.
  • 3
    Press the left arrow button. Select "0" and wait until the timer display clears.
  • If this was helpful a vote on the thumbs up for the free advoce would be greatly appreciated. Thanks
    Apr 04, 2011 | Hitachi 60V500 60" Rear Projection...
    T V won,t come on and timer lamp on front panel stays lit.
    Your lamp hours have expired. Try taking the lamp out then putting it back in. The TV will go to a reset menu for the "new" lamp it thinks that you have put in. From there you can reset the lamp hours from the menu. It it doesn't work, the lamp may be burnt, and you have to replace it.
    Aug 13, 2009 | Samsung PCL542R 54" Rear Projection...
    Timer light did not stop flash
    Lamp is not the issue. It most likely is a your DM card. You most likely have some capacitors that need to be replaced. This is a terrible issue with this unit. Do a google search for "DM" and the model number and you should see hundreds of posts.
    Jul 02, 2009 | Mitsubishi WD-62525 62" Rear Projection...
    Samsung no picture
    There are several capacitors that are known, in Samsung TV's that go out.. ( I replaced mine until the board was burnt through.. bought a new board, they went out again.. BOUGHT A LG TV!!)
    Samsung settlement warrants older TVs with faulty capacitors
    Samsung LCD Plasma TV Capacitor Repair Kit Replacement Parts
    replacing these is not hard at all.. if you can use a soldering iron, you can do it..it just takes time..
    Repair Samsung LCD TV Relay Clicks Shuts Off Won Come On
    WATCH THESE VIDEOS FIRST.
    Samsung TV Won Turn On How to Repair Bulging Capacitor for Clicking Noise
    My Repair of 46 Samsung LCD TV with Bad Capacitors
    Jul 18, 2017 | Samsung - Projection TV replacement lamp...
    Televison & Video Logo
    65 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
