Question about LG LRE30755 Electric Kitchen Range
Lg lst5601st stove outer burner ring works but inner ring does not work do I need a fuse
5 Suggested Answers
appldoctom
  • 311 Answers
SOURCE: MER6772 front burner......is there a fuse that controlls the out
sounds some like you know a little about appliances.if power is leaving switch and burner not working.its your burner.take a look at wiring diagram it will show you the power path, use volt meter[looking for out put at switch],[the limiter that you see in wiring diagram is built into the burner and can not be replaced by its self]so if power leaving switch replace burner.hope that helps.God bless ,tom
Posted on Jan 06, 2009
Testimonial: "great"
erpaalai
  • 999 Answers
SOURCE: one of the dual zone stove burner stopped working.
You have to determine if the control or the burner is bad. Only way is to verify power from the control. If power is there the burner is bad. If the control is not powering the burner then the control is bad. Rarely is it both but not a impossibility. 240 volts so a trained professional is preferred.
Eric
Posted on Dec 11, 2009
  • 161 Answers
SOURCE: LG stove F-1 display stays on. Burners or oven
Your control is faulty. Check your owners manual for a two year warranty on eletronics. If not under warranty you need to call an authorized LG service dealer.
Posted on Jan 25, 2010
Testimonial: "Thank you!!"
  • 161 Answers
SOURCE: How to replace inner ring on a glass top stove.
Look at the front edge of the cooktpo. Remove the screws and lift the top up then you have to remove the retainer bar to get the element out. Unplug the old element and plug the new one in. re-assemble
I have KitcheAid KERS 807, electric stove/oven range. Left lower part of ceramic stove top that has single/dual heater sizes is malfunctioning. Single one is still working but from recent dual does not.I...
Either the knob has gone out or the burner element. I would test the knob first to see if there is current when turned to the large zone. If the knob is working, next would be to test the burner to see if the outer ring has burned out. I would guess more likely the control has gone out. Burners have less failure (typically).
Apr 14, 2014 | KitchenAid KERS807SSS Electric Kitchen...
Frigidaire stove front large/small burner combination. Large burner works but the small burner in the centre of the large burner does not come on at all with any heat. ??
This is a inner/outer burner type assembly? Sounds like a glass top.
Either way, your switch for that burner or the burner needs to be replaced.
If you are able and it is possible, inter change switches to see if it makes a difference. Interchange Large with large, small with small.
If yous switches are connected as one unit, you will not be able to do this. Sorry, I have not looked up your wiring diagram.
Oct 23, 2013 | Frigidaire Gallery GLEFM397DS Electric...
No flame touching thermocouple
There must be a blockage on the inner flame ring as the gas is not getting to the thermocouple .
Apr 21, 2017 | Gaggenau 11 in. VG 232 Gas Cooktop
How to replace inner ring on a glass top stove. Broken burner is the dual sized one. Any help would be greatly appreciated.
Jan 10, 2010 | LG LRE30755ST Kitchen Range
One of the dual zone stove burner stopped working. The inner one has stopped the outer ring is still working
Eric
Dec 05, 2009 | Whirlpool GR448LXPQ Electric Kitchen Range
Middle section of element on smoothtop stove not working
yes you can
goto appliancepartspros.com
type in your model number
under the section top
you will find your part number...
when it arrives unplug the unit and remove the screws holding the top down under the froont lip
lif the lid and mark where your wires connect, remove the wires, and the two 1/4 scres holding the burner
sometimes 4
switch out the burner, and re plug all your wires
drop the lid and test
Oct 15, 2009 | Kitchen Ranges
Jan 06, 2009 | Maytag MER6772 Gemini Electric Kitchen...
The inner right front element will not heat up on our Kenmore Elite ceramic stove top. The middle and outer elements on the right front work fine. Why is this happening?
inner element burned out. Either burner needs replacing or control switch is bad. Take out burner and see if coil has a break in it. IF not, then switch is bad. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Kenmore Kitchen Ranges
COOKTOP
its been my experience that the dual burner switch is far more likely the culprit, unless you can physiclaly see the outer ring is broken( visual inspection works wonders. as far as trying to ohm out i generally look at theelemnet itself (4 wires lead to the elemnt you can trace 1 to the outer portion of element, and 1 to the inner portion.WITH POWER OFF Iswithc those 2 wires and the restore power try element ad watch for outer ring to work inner ring no good. now i know its the switch not sending power. reset wires and order new switch
Mar 08, 2008 | Cooktops
LG LRE30755 Electric Kitchen Range Logo
154 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Mike Carew
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
