Question about KitchenAid Washing Machines
My awesome Kitchenaid washer sounds like it has a belt off - when it spins it knocks really badly and stops. When it does spin its slow and doesn't wring the water out. Should I (54 year old female) attempt to fix? Hate to pay if its easy to do. Thanks!
    Top Expert:
  • KitchenAid Master
  • 76,691 Answers
The washer tub rear bearing has failed, u will need to replace it.
Posted on Sep 11, 2010
  • mjames75957 Sep 11, 2010
    Do I replace the whole washer or just the bearing and can a regula person like me to this?
  • yadayada
    yadayada Sep 11, 2010
    this is a huge job and best left to a trained professional, also it will cost about $450 for the repair
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
The washer will fill up and go through the cycles, it will drain properly, but then the spin doesn't work proprerly. It does not spin at quickly, only very slowly and a knocking sound will occur. When...
Since you didn't say what brand and model you have I can only give you generic advice. If its a GE washer, it has a belt and sounds like it may be very loose or/and worn out. Other brands have belts as well. if it doesn't have a belt then a knocking sound could mean the transmission is out.
May 15, 2011 | Washing Machines
KAWS677EQ0 washing machine.KitchenAid. It Wont agitate,spin,drain,hum,nothing.It stopped in the rinse cycle with wet clothes and all the water. what is wrong . the outlet works.
Thanks for choosing FixYa and welcome. If your washer doesn't drain or spin, you may read and learn what parts may cause this. First, you will want to check your water pump. You need to make sure it is working. Make sure you check the belt on the pump. Make sure it is not broken or loose. Also, make sure your pulley is not stuck in place. Sometimes, they will stick or barely turn at all. If this is the case, you will need to replace it. If the pump, pulley, and belt are working, make sure your motor is working. You should be able to hear it if it is. If it isn't, check your lid switch. The lid switch can cause the motor to not work. It may need adjusted. If not, go ahead and change it. A bad lid switch may cause the washer to not work at all. Now, if your pump is pumping and the washer still won't spin, you will want to check your belt and clutch. Once again, the belt may be broke or loose. Check to make sure your clutch is not worn also. This may be a case of a bad lid switch again as well. You could have a bad drive motor. This is what controls spinning, draining, and agitation. You could have a broken motor coupler. Over time, they will go bad and need replaced. It is possible that your transmission is slipping or damaged. And lastly, you could have a bad basket drive ir spin bearing. This is what allows the inner tub to move. If this is the case, you will probably hear loud sounds or loud banging.
Mar 21, 2011 | KitchenAid KAWS700L Top Load Washer
Washer Won't Spin / Drain. Need New Belt or Pump? Need Diagram?
based on feedback that i received on the forum, i realized that the washer doesn't have a belt (it's a direct drive machine). then, i replaced the motor coupler, which was a lot easier than i thought when i posted this question.
detailed instructions can be found on an excellent post by jsrock516 on fixya.com. even though the washer is labeled 'kitchenaid,' look for whirlpool, top-load washer, tips. then, search for replacing a motor coupler.
jsrock516's instructions look complicated, but they're really just a very detailed, step-by-step guide written so you don't need any pictures. read through them before you start, and then follow each step as needed. great stuff.
Aug 23, 2009 | KitchenAid Washing Machines
Maytag MAV 7000 stopped in rinse cycle with water in tub. When turned on, there is a low buz sound. Was making a louder noise prior to stopping.
RepairClinic.com
The top of the washer lifts up like a car hood after two clips between the top and the front panel are pushed with a putty knife. Once the top is flipped open, the screws that hold the front panel in place at the top can be removed and the panel lifted off. The belt may be bad or something may be stopping the belt like a bad pump. Or the transmission drive pulley and bearing may be going bad. If the bearings above the transmission drive pulley fail the brake will not release correctly in the spin cycle causing weak, slow or no spin. The belt & pulley system can be accessed by tipping the washer back. The belt is routed around all three pulleys under the washer and is fairly loose until the motor starts. It is the torque of the motor that gives the belt tension. Leaking or loud "jet engine" sound in spin indicates a bad main tub seal at the outer tub which has caused the spin bearing to fail. This is a complicated repair as the inner and outer tubs need to be removed from the washer to access and replace the seal and bearing components.
Go here for: Maytag-Washing-Machine-Parts
May 05, 2009 | Maytag Atlantis MAV7000
Spinnig slow sqecking noise
This is joyce
sounds like the belt needs to be tighter. sounds like its slipping on pully. that may be why its not spinning correctly.
thanks
joyce
Feb 06, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Frigidare front loader washer GLTF1040ASO
your bearings are shot your washer needs to be rebuilt but it is cheaper to buy a new washer
Dec 26, 2008 | Washing Machines
KitchenAid KAWS777E Washer will not spin
We are having the same problem. Try the lid switch. It is located just under the oval hole in the rim of the washer. There is a plactic pointer on the lid that pushes the lid switch down so the basket can spin. It is a safety thing. The plastic lid switch costs around $43 and is really not a problem to put in. Good luck!
Jun 22, 2008 | KitchenAid KAWS850LE Top Load Washer
Washing Machines Logo
243 people viewed this question
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
