Question about Moen 7310 Legend Single-Handle Kitchen Faucet with Side Spray Chrome...
Changed the O rings now the hot and cold water are on the oppisite sides
  • 1,040 Answers
You got the water lines switched up when you reconnected them below the sink.
Jim
Posted on Sep 12, 2010
  • 2 more comments
  • Jim Parker
    Jim Parker Sep 12, 2010
    If that is not it than the only other thing it could be is that you have switched the H
  • Jim Parker
    Sorry, you don't have knobs; my bad.
    Jim
  • Jim Parker
    O.K., after some research I have found a PDF file that you can link to. Page six of this manual will help you solve the problem. You may have to copy and paste this link:
    http://www.moen.com/shared/pdf/instructi...
    Good Luck,
    Jim
    P.S. If this was helpful, please change my rating.
    Thanks!
  • Jim Parker
    Jim Parker Sep 17, 2010
    Let me ask you this. When you turn the water on, do you push the handle forward or pull it toward you? If it is put together properly, you will have to push it forward. It sounds like you need to turn the parts around on the inside of the faucet.
    Jim
Why is the hot water pipe dripping after tighening up.
First the is a hot and cold water pipe. To those are connected hot and cold water outlet bib valves to which are connected, respectively, hot and cold water hoses going to (or you could say, coming from) their respective connections to the washer. Correct this if I am wrong but, it appears you might be talking about those hose connections to the water spigots but calling them pipes, not hoses. If that is true, you contecture is correct: it is most typically a worn out hose washer or o-ring and replacing that item should correct any dripping. By sure the part is characterized for hot water.
Oct 28, 2014 | Washing Machines
Leaky faucet after cartridge change
It sounds like the cartridge is not properly seated against the O ring. I am not familiar with this exact model but remove the filter, check and be sure the o rings are ok and re install the filter.
Mar 04, 2014 | Franke LB2200 Instant Hot and Cold Water...
Franke water coming out of hot water handle after I changed the filter
Moen water flow restricted and only warm
Not sure about your particular valve, but most newer shower valves have an anti-scald limiter that stops the handle from turning too far to the hot water side. Check for a ring or a pin under the handle that can be set in different positions. It will need to be moved clockwise to allow the handle to rotate farther to hot.
Hope that helps. If you have trouble finding it, try looking up a diagram for the valve model.
Jul 03, 2017 | Moen & Replacement Cartridge
Change Door
there should be two plastic covers or two screws on the oppisite side.simply unscrew the hinge from the side its on flip the door the oppiste way.remove the door mechanism that is on the frame and put the mechanism onthe oppisite side and rescrew the hinge on the oppisite side
Apr 28, 2010 | Whirlpool GEW9250 Electric Dryer
How to adjust anti scald valve on american standard shower faucet
Remove the handle,and all the trim rings,and the cartridge cover. take a flat head screwdriver and use it to lift
up the red ring behind everything, this is the hot limit safety stop,
this just stops the handle from turning to full hot.
Once you have the red ring lifted up, notice the numbers and the pointer
on the ring, numbers are on the fixture,
O= hottest 7=cold
See what the ring pointer is set to now, and move it half, before you put this back together, just set the handle on the unit and run the water to see if its to hot or not enough. Once you have found what is the best setting, then replace all covers and trim, handle.
Feb 10, 2010 | American Standard Bath Faucet Ceramix...
Moen Single Handle Shower Faucet-turn on get cold, little hot
You can try to rotate the first plastic ring to the left of center a few teeth, this will let the handle advance alittle more to the hot side.
Oct 09, 2009 | Moen 3175 Legend One Handle Shower Faucet...
I have very little water press on the hot water side
Dis-assemble the faucet to get to the valve. The handle comes off and you access the valve from the top, usually by removing a screw on ring.
You will robably find contamination in the hot side of the valve.
You can find instructions on the Moen website.
Sep 09, 2009 | Moen 7310 Legend Single-Handle Kitchen...
Delta tub tap only cold water no hot water or pressure for shower.
take handle off and adjust the nylon set ring it is to prevent kids from getting burned and is probably set wrong youll see teeth and a pointer just pull it out a little and turn it in the oppisite direction then push back in
May 09, 2009 | Delta Faucet Company Classic Collection...
Bathtub water does not get hot enough-
take off handle and you should see a nylon ring with teeth just take off and put back in the oppisite direction that you removed it its there to prevent kids from getting burnt
Feb 27, 2009 | Plumbing
Moen 7310 Legend Single-Handle Kitchen Faucet with Side Spray Chrome... Logo
48 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
