Question about Frigidaire ATF6000ES Front Load Washer
I have noticed a little bit of water pooling on the floor under the washer. It appears it is running down the inside of the front cover. There are a couple small tears on the door gasket on my front loading washer. I'm guessing this is where the water is coming from. Can I patch the holes or should the gasket be replaced?
    Problem Solver:
  • 15 Answers
Hi dear you have first to check the detergent drawer and be sure that the soap or softner compartment not blocked inside it because if its blocked the water goes back when its filling water if not blocked then you check gasket ,and be sure that the filter fixed well .
Posted on Sep 11, 2010
    President:
  • 1,430 Answers
I have patched the holes until the new parts came in and customers have said it hasn't leaked. I used clear 100% silicone. This has lasted for several weeks on some occassions. Clean it good then let it dry for at least 24 hours. If you need to replace it here is a link that should help http://appliancehelponline.com/washerdoorseal.html
How do you remove the cover of a Kenmore elite top load washer . Have a leak and need to find where it is coming from.
water coming from the bad seal on the shaft. Lift agitator, bolt underneath, loosen pull out basket. From spindle. ..seal underneath. Must take cover off first. Slide a butter knife at edges in front at seam. there's a two ,clips. in there. Usually 2 bolts up towards top on inside edge of front cover. Make sure power cord unplugged.turn basket upside down. You will see seal.
Sep 11, 2014 | Kenmore 24032\24036 Top Load Washer
My washer sometimes ends up with a couple inches of water in the tub a day after last used. Also, at times water leaks on the floor. Neither of these things happen consistently.
It is likely that the fill valve located inside the rear panel is leaking, especially if you leave the supply lines turned on all the time. One annoying fix is to turn off the water supply after each laundry session but than you have to remember to turn the water on again next time
Dec 28, 2012 | Maytag PAV3240A Top Load Washer
I just noticed a large pool of water under the duet washer. it is not coming from the supply lines- It only appears when the washer is running. I see it leaking down the side (just above the pedestal). ...
door boot/gasket is bad replace and problem solved.but first take the front panel below door off and make sure before you buy a door boot but if it is leaking you can tell by wipeing finger below door while running usually.
Nov 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore fridge, 7 yrs old, freezer on top. Water sprays periodically from somewhere at top inside of refrigerator, apparently from downward pointing chute or holes on either side. This seems to be part of...
Removed inside rear and floor panels of freezer (ice machine also) as ably advised by your tech. Found ice damming he suspected underneath floor panel. Thawed overnight with pot of hot water in freezer. could see that small rear drain tube was iced shut; why all water going into fridge below. Avoided floor mess from thawing water flow to evaporation pan on floor by tilting unit forward on blocks and laying several old towels inside freezer door to catch water that would run out. Also placed some in front at base of unit on kitchen floor. Continuing to thaw pipe to unclog, it is iced some way down, again as tech said it might. Will reassemble and be careful with freezer setting, in case it may have been too cold. Also, some food crumbs had found their way behind panel near this drain tube and may have fallen in to block it. Will clean out any remaining.
Jan 05, 2010 | Kenmore Refrigerators
There is water collecting inside my refrigerator.
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 11, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water Leaks from front door
My tenants informed me that water was showing up on the floor in front of the refrigerator. I checked the back where the evaporator tray is and it was dry. When i looked inside the refrigerator I notices water pooled inside, under the plastic bottom drawer. Anybody have any idea what i should do? thanks.
May 29, 2008 | Refrigerators
Amana washer leaking.
Have your husband disconnect the power and water lines, pull the washer out and tip it back so he can check the hose connections to the water drain pump in the bottom of the washer. That pump should have two hose connections. In older machines, it is entirely possible that a hose has either come loose or cracked. If the hoses appear fine, check the pump itself for possible cracks. If all looks well, check the hose clamps for tightness.
Feb 23, 2008 | Amana ALW880WH Top Load Washer
GE WJSR 1070A Leaking
It sounds like you have a leaking pump. The pump is easy to replace:
#1 Use a shop vac and pull all the water out of the drain line. This will keep you from having to clean up about 1 gallon of water off of the floor.
#2 Lift the front of the machine enough for you to get under and see.the pump just inside the front of the washer.
#3 Lift the 2 retaining clips off of the pump. This will allow you to pull the pump off of the motor.
#4 Remove the 2 clamps off of the hoses.
#5 Install the new pump into the hoses, and reinstall the clamps.
#6 With the retaining clips installed into the motor housing, install the pump.
#7 Attach the retaining clips, and set the washer back on the ground.
You have now replaced the washer pump.
If you have any questions, let me know
Please rate this solution
Jan 24, 2008 | GE WJSR1070A Top Load Washer
Water Leak
When the machine has filled TURN THE POWER OFF.then tip the machine back & lean it on the wall, look around for the leak it should be fairly easy to see. It may be the door seal which has split, you should be able to see this be examining the seal with the door open
Oct 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Bad odor
This is the fix for the HE3T Sears front loading washing machine with a bad odor problem. We HAD this same problem but now it is fixed. You don't need to call the repair man, it's just a waste of time, money and endless frustration. Tools: 9/32 socket or T-20 torx head bit. Bunch of rags you don't want when you're all finished. *****UN-PLUG THE WASHER****** Lay on the floor in front of the washer and look under the lower panel. You will see three silver colored torx head screws, one on the left, right and center. Loosen these up with your socket or torx head wrench. Remove the lower front cover and set it aside. See all the wires? Did you make sure to UN-PLUG the washer? Good. Now look at the center of the bottom of the washer. You will notice a white cylindrical contraption. This is a drain trap where all of the junk from your washer gets hung up so it won't clog up the water pump that discharges the water from your washer. On the front of this drain trap is an access cap. BEFORE you open this place the rags under the trap, along the sides and under the washer. Trust me, you'll thank me later. Now open the drain trap access cap by turning it counter clockwise. Be prepared for some smelly water to come out, probably 1-2 cups worth. Once the water is drained, pull the trap completely out. You'll find the reason your washer stinks in the trap. We had a blob of black goo and a security label from an article of clothing we bought. That was the culprit. The drain trap was "trapping" all of this junk and getting real funky. Now clean the drain trap out with hot soapy water and a little bleach. Clean out the cylinder where the drain was. Wipe it out with a rag soaked in bleach and soap. Once everything is clean, replace the drain trap and tighten it down. Do not over tighten this or the seal may leak. Replace the front cover and the three torx head screws. Plug the washer back in. Run the washer through the SANITARY CYCLE with bleach. Your problem is solved
Feb 20, 2007 | Kenmore Elite 45986 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
42 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
