Question about Euro-Pro Shark GI490 Iron
Taking apart shark 1490 iron. Got screws from back, then two inside screws. Something is holding it in place yet at the front. How do I loosen that?
4 Suggested Answers
  • 19 Answers
SOURCE: shark euro-pro iron cord replacement model 4750
six screws on bottom plate two hidden under rubber feet on bottom under lower screw holes
Posted on Aug 16, 2009
miket756
  • 2702 Answers
SOURCE: shark iron wont turn on
take it back to were you got it from i think the regulator has just packed up
Posted on Jun 20, 2010
HansPP
  • 2510 Answers
SOURCE: The power cord is shorting
Normally you need to remove the back plate to replace the power cord, and this is usually held on by one or two screws. With the modern trend, these covers are clipped as well and the screws are of the tamper proof type. Tamper proof drivers and bits are available at hardware stores or some importers of Chinese products. If this does not help you, please come back to me and also describe the back cover. I doubt if you can access anything useful to you through the underside of the iron.
Posted on Apr 22, 2011
How to remove back cover of Shark Iron?
6 screws hold the cover on, 4 are visible, two are under bumpers on bottom. pry out the bumper.
Jul 05, 2012 | Euro-Pro Shark GI490 Iron
DISASSEMBLE SHARK G1465D ELECTRIC IRON
there are 4 screws that you can see and two more under the large rubber stand off at the bottom. I also need you post the wire in the back because I took mine apart and now don't remember the position of the wires
Jan 23, 2012 | Euro-Pro Shark GI490 Iron
Shark iron wont turn on
Jun 20, 2010 | Euro-Pro Shark GI490 Iron
How do I take the iron apart. something loose inside
umm i think you should consult an electrition incase something goes wrong
hope this helps!
Jun 06, 2010 | Euro-Pro Shark GI490 Iron
My shark steam iron is leaking when ironing
It is quite possible that this is a defect in the shark G1490F... I had the same problem and it was a crack in the water holding tank caused by tightening the two front screws (hidden) that hold the tank to the base... It seemed fine at first but after a full heating it developed a crack where it had been weakened when it was assembled... I suggest returning it or if warranty is up , throw it away and get something else..
May 23, 2010 | Euro-Pro Shark GI490 Iron
It suddenly quits...i have to juggle the line cord to have a power.
Sounds like a loose connection from the screws inside the housing of the iron. It is a wee bit of a bugger to get INTO this iron, but with a little patience, and a screwdriver (phillips, the + one) you should be able to get to where the power cord connects to the terminals inside the iron. Loosen, and retighten the connection. If the wire seems 'worn', you may have to cut it back a bit and score off some of the plastic, and re-wire.
Mar 17, 2010 | Euro-Pro Shark GI490 Iron
My Shark Iron leaks....
fill with water turn iron on max keep turning steam dial all the way to the right until you get to self clean hold iron horizontal and make sure you have a towel or something to catch water drips and debris coming out of iron let iron steam and spit water out until it stops on its own turn dial back to regular steam settings wipe residue off of the plate with a towel adjust temp settings back to normal
Aug 14, 2009 | Euro-Pro Shark GI490 Iron
Shark euro-pro iron cord replacement model 4750
Nov 18, 2008 | Euro-Pro Shark GI490 Iron
Taking a Rowenta DX1900 Apart
To get the base off, you have to remove the 2 screws from the face.
the button for the reel has a screw behind it, that needs to be removed.
Take a thin piece of metal, like a spark plug gapper, and slide it in the side to push back the tabs. You have to do it on each side. Remove button and take out screw. The base will come off.
Now you need a special torx srewdriver that allows for the center of the screw to enter the screwdriver.......
Learned the hardway and didn't have the correct torx..... Good Luck
Feb 27, 2008 | Irons
Euro-Pro Shark GI490 Iron Logo
2,082 people viewed this question
Top Euro-Pro Irons Experts
Henry  Thomas
Henry Thomas
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
