Question about GE J Series 18.2 cu. ft. Top Freezer No-Frost Refrigerator TBX18AABWW
Older (serial # erased) GE freezer top frost free Water pools in bottom of frig. cannot find drain.
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Drain is under the coils and may be froze shut...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 11, 2010
Ice in bottom of freezer. What causes this?
Usually cause by a clogged drain in the back of the freezer. try to clean with hot water and make sure the water goes all the way downn to the drain pan. .
Note: all frost free refrigerator defrost a couple of time a-day; the water needs to drain into the drain-pan under the frig. check under the frig to see if the drain pan is totally dry, if dry, the drain is surely clogged.
good luck
Jul 22, 2014 | Refrigerators
Water Pooling & Freezing
Assuming your fridge has a defrost cycle ( I.e. is a frost free model), you are probably suffering a blocked drain hole or pipe, leading to the top of the condenser or a tray nearby, where the frost water can evaporate.
The pipe can block with food or a mould plug, leading to water retention that freezes and further blocks the drain. the water is produced when a heater switches on in defrost mode and thaws the internal or external ice build up and, with nowhere for it to go it will pool on the bottom and may, when in defrost mode, run out onto the floor.
With frost free fridges/freezers, there is a drain outlet, usually hidden behind a removable panel inside the fridge/freezer compartment or, a drain hole near the bottom. If there is a drain pipe as well, access is usually from the rear base of the machine. The pipe is usually removable and can be cleaned out but prepare for some water to escape. An ice block in the drainage hole can be thawed using a hair dryer BUT GENTLY, so as not to warp the plastic inners of the fridge.
Jan 20, 2014 | Refrigerators
Hotpoint model #ctxy14epjrwh slow water drip from inside of the refrigerator. inside the top of the frig, center, there are several components that appear to come down from the freezer. the lowest one...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the centeroldtech2332_52.jpg
Aug 24, 2011 | Refrigerators
I have Hotpoint model CTX18BABKRWW Serial#ZT515963. Water is collecting in frige under two drawers. I cannot find a drain or a drain tray. Sounds like a low hum noise. Frig is cold and freezer is...
The exact location of drain is under the coil behind back freezer plate in the center.
This picture may be a slightly different moldel that years but it shows where that drain is
Aug 15, 2011 | Hotpoint Refrigerators
My automatic defrost freezer in my frig does not drain the water down to the drip pan. Instead the water is coming through vents inside the frig directly under the freezer. this is an older Amana. We...
If the drain isn't stopped up than the water isn't draining into the drain.
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Aug 11, 2011 | Refrigerators
Hi I have A GE 18 cube frig model GTA18QBNBWW. Initially the food on the top shelf was freezing in the frig I discouver the coils were blocked by massive clumps of cat fur. i cleaned it out. next day i...
you have done a good job so far . so next ck the dampner at the top in the fresfood side . it may be stuck open causing the freezing . but the evap coil was frozen so you may have a heater out in the freezer so ck the defrost system heaters and defrost terminator . ..mm hope this helps feed back pls
Jan 19, 2011 | Refrigerators
Model TBX21KLK water pooling UNDER vegetable bins
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 21, 2009 | Refrigerators
Water building up in the main compartment
this is a plugged drain there may be a small cup up in the back of the fridge you can take out or you have to remove the freezer plate to access the drain
Apr 29, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
WATER LEAK IN FREEZER POOLING AT BOTTOM & FREEZING THEN MELTING
The problem was indeed a clogged frost water drain. I had to pull the frig out from the wall (found an incredible amount of dust accummulation in the alcove), then remove the vertical metal and horizontal cardboard covers to expose the drain catchpan. The 1/2" rubber drain hose end was only about 1/8" above the pan pointing directly into it perpendicularly. This was not enough clearance. There was a plug (formed by dust and water) in the end of the hose that came out easily when I 'roto-rooted' it with a screwdriver. The water flowed easily after that, but I went ahead and trimmed about 3/8" off the end of the hose and pushed it back into its slot. Then I cleaned as much as I could. The prevention is to keep the area behind the frig cleaned!
Bob
Nov 07, 2008 | Refrigerators
Refrigerators Logo
115 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Lawrence Oravetz
okcchemist
Level 1 Expert
