Question about Sony PlayStation Portable (PSP) Console
PSP Go Erro 8010850f Como resolver Passo a Passo
4 Suggested Answers
  • 5 Answers
SOURCE: psp go i have an error code 8010850f it says i
If you are getting this error when trying to play games from memory stick i might have the solution for you.
1) Back up your data on memory stick to PC using usb cable.
2) Format your memory stick from PSP.
3) Copy game from your PS3 to your PSP using usb cable.
4) Copy game saves etc. from your PC back to your PSP.
5) Play your games on PSP.
Posted on May 17, 2010
SOURCE: psp i have an error code 8010850f it says i must
no need to delete anything all you need to do is go to account management, system activation, then games then you should know what to do from there on out lol
Posted on Jul 06, 2010
  • 15 Answers
SOURCE: on my psp slim 3004
I want to just make it clear to you, that you can repair the following problems at home with a good repair guide. There is no technical knowledge needed you simply do what you see on the step by step vids or the paper guide.
The best thing is you get to keep your psp guide for life so if something goes wrong in the future you can just review your guide and fix it.
so better download thisI want to just make it clear to you, that you can repair the following problems at home with a good repair guide. There is no technical knowledge needed you simply do what you see on the step by step vids or the paper guide.
The best thing is you get to keep your PS3 guide for life so if something goes wrong in the future you can just review your guide and fix it.
so better download thisClick Here
Posted on Aug 21, 2010
Riso RZ200ep. como resolver o erro codigo A - 06 -403
Jul 08, 2012 | Office Equipment & Supplies
Tip
PSP ERROR CODE "8010850f"
How to fix error code "8010850f" on your PSP:
Error code "8010850f" sometimes appeared when you downloaded certain games on your PSP. It will requires you to activate the system to use the content and could only work when activated through PSN. Here are some tips and tricks on how to fix this error.
Option 1: Go to account management by signing in to PSN on your PSP. Once under account management go to activation/activate - games then activate the PSP.
Option 2: Connect your PSP to your PS3 using a USB. Then go to [Accountmanagement] - [activate/deactivate] - [PSP] - [games].
After you processed either of the 2 options you can now play your games with no interruption.
Hope it helps.
on Feb 21, 2011 | Video Game Consoles & Games
Psp error code 8010850f when trying to play demo games
From TIPS section:
Hope it helps.
Jun 18, 2011 | Sony PSP (Piano Black)
Activar el sistema 8010850f
Lo que usted está tratando de jugar, tienes que descargar de nuevo en la tienda dePSP. No contará como descargarlo en otro sistema.
Por favor calificar mi respuesta!
May 06, 2011 | Sony PlayStation Portable (PSP) Console
Quando ligo a maquina dsm715 ela informa logo o codigo sc322. como faco para resolver?
Independente do modelo ser Dsm715 ou Dsm745 esse codigo corresponde a um erro na Unidade de Laser, mais precisamente com o sincronismo.
A primeira coisa a verificar nestes casos é se a Unidade de Laser está suja. Por vezes cai toner para o Laser e provoca estes codigos.
Se tiveres conhecimento tecnico saberás chegar á unidade de Laser. Se não tens esse conhecimento aconcelho a não mexeres (chama alguem que o saiba fazer).
Na minha opinião este deve ser o primeiro passo a dar. Deves fazer uma limpeza na Unidade de Laser.
Se não resultar replica para mim ou volta a colocar a questão no Fixya. Existem otros factores que podem provocar este codigo.
Fica bem!
Apr 25, 2011 | Gestetner DSm745 Black and White Copier
I'm getting the error code 8010850f
Hi antoniodarri,
It seemslike you can't play games with your PSP. You also mentioned about the error "8010850f". Don't worry you can remove this error by applying the options below andthere's no need to delete anything or need of formatting your PSP.
Option 1: Go to account management by signing in to PSN on your PSP. Once underaccount management go to activation/activate - games then activate the PSP.
Option 2: Connect your PSP to your PS3 using a USB. Then go to accountmanagement - activate/deactivate - PSP - games.
After you processed either of the 2 options you can now play your games with nointerruption.
Hope it helps, Thank youfor using FixYa.
Feb 02, 2011 | Sony PlayStation Portable (PSP) Console
Não Consigo acessar Serviço de hp plotter Calibração T610. apresentou o Código de 21.1:03 Erro, Substitui uma Estação de Serviço e continuou o Mesmo Erro, Substitui...
helo
Try the following:
Switch the Power OFF from the back of the Printer and disconnect the
Power cord. Check the Primer Tubes. Reconnect the power cord and
power On the Printer.
Perform the Service Station diagnostic test to troubleshoot the problem
further
If the System Error continues, replace the Service Station .
If the System Error continues, replace the PrintMech PCA
Jul 29, 2010 | HP Designjet T610 InkJet Printer
Psp go i have an error code 8010850f it says i
Mar 21, 2010 | Sony PlayStation Portable (PSP) Console
Psp i have an error code 8010850f it says i must activate system whats wrong how do i activate?
Hi vam7576,
With this type of error "8010850f", you really need to activate your PSP. You need to get rid of this error so you can play and use your PSP with no interruption. You can activate your PSP by doing either one of the options below. No files will be deleted during the process and no need to reformat your PSP.
How to remove error
"8010850f":
First Option:
Connect your PSP to your PS3 using a USB. Thengo to account management - activate/deactivate - PSP - games.
Hope it helps,
Thank you for using FixYa.
Best regards,
Reyjoshua07
Feb 27, 2010 | Sony PlayStation Portable (PSP) Console
Activate system 8010850f
como activo este sistema en mi psp 3001? gracias...
Jan 12, 2010 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
74 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
