Question about Maytag Atlantis MDE8400AY Electric Portable Dryer
When i pull out on the start knob,nothing happens except that the light on the indicator for what stage the clothers are in comes on. The knob doesn't catch like it did before.
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The timer is broken...but...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
How do I get steam from my new bar 32?
It may take a few moments to come through.. if you can't hear the pump operating, it may indicate the unit is faulty..
May 10, 2014 | DeLonghi Coffee Makers & Espresso Machines
I have a frigidaire gallery front load washer that won't start a regular wash cycle.When i select a regular cycle and pull up the start knob,the cycle light comes on and nothing happens.When i mov
Good Afternoon Leszek - Thank you for your question. Based on the symptoms you are describing it sounds like the unit has a faulty timer or a potential wiring failure. Try reprogramming the unit by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn on the unit. If issue persists, then at this point I strongly suggest reaching out to a professional that can accurately diagnose and repair the washer.
Jun 09, 2013 | Frigidaire Washing Machines
GE Spacemaker Washer/Dryer wont start only washer or only dryer
Did you figure out a solution to this problem? I just bought a brand new Frigidaire and it is doing the exact same thing, except it never worked properly. I thought it was the unit and had HH Greg bring another out but the 2nd one did the same as the first.
Feb 09, 2010 | GE WSM2700W Unitized Spacemaker Washer and...
Maytag Performa will not come on. Nothing happens
Burned Thermal Cut Off thermostat. at the bootom of heater housing, which means you have clogged vent as the root of your problem, probably it was taking long time to dry prior to your experiencing dryer not running.
Oct 31, 2009 | Washing Machines
I can't get oven to work on broil or bake; only self-cleaning.
Hello
Welcome to Fixya
My name is Huum,
Try turning the breaker off for 5 minutes and see if this resets the system.
if not you may have a defective Control board and you will need to have a HANDS on tech to diagnose these parts to be sure! They will have the diagnose equipment !
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 21, 2008 | GE Profile JTP18 Electric Single Oven
Dryer won't start, light comes on
hi thanks for the question the thermal fuse fails allot caused by poor venting yo the outside this fuse is located in the front on the air duct thanks the appliance doc
Jul 08, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Front loading frigidare washing machine
Check breaker only one breaker are function recock it the two breaker try to start it .
Jan 07, 2008 | Frigidaire GLTF1670A Front Load Washer
Open Questions:
Only the extended tumbler option works. I have similar Maytag dryer model MDE8400AZW.  On any of the dryer settings, the dryer does not work (I will pull the handle and hold, the "damp" indicator light turns on without starting the dryer). I know it's not the motor because when I turn on the switch for extended tumble and turn my knob to extended tumble, pull the handle, the dryer will begin rotating as if nothing is wrong. I know it's not the door problem, because when I use my finger to press the door close "button" the interior light turns off and the extended tumble still works even though none of the other settings work. One strange problem I had was the turn switch.  Periodically, I would turn the setting to any random setting, try to turn on.  Repeating this at times would start dryer.  At first, I would only had to do this one or twice before working.  Later, I had to do this more and more.  Now it's not responding at all. I don't think it's the fuse because when I tried pulling the plug on the fuse, the extended tumbler doesn't work either. My first instinct was to replace the knob (I have not done so yet), but why is the extended tumbler working (every time) and nothing else? My guesses are 1. Knob is problem after all,  2. something is preventing any cycle that requires heat (maybe a thermomitor problem) One last thing, I've taken out the thermomitor (originally thinking it was the fuse).  When I shake it gently, I hear rattling metal pieces.  I'm not sure if this is normal or if it's broken.  I believe it's the maytag part 33002742.
Jan 05, 2009 | Maytag Atlantis MDE8400AY Electric...
Maytag Atlantis MDE8400AY Electric Portable Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
