Question about iRobot Roomba 530 Robotic Vacuum
Did not use for several weeks, now runs only about 5 minutes, red comes on as if battery is dead
  • 944 Answers
What type of red light you get,flashing red light or just red light and your iRobot dies.
Flashing red light with 6 beeps means you need to clean the sensors.There are four sensors that is visible when you put iRobot upside down.Use soft dust wipe to clean the sensors.
flashing normal single red light and it dies it because of the battery is dead:
Since you have not used it for several weeks the battery becomes stone dead.This is normal with batteries.So only you should use it atleast a day in a week to prevent from this issue.You have dead nickle metal hydride batteries.Replace it. Test it by removing the battery and press the power button down for 15 seconds.The charging cycle will restart if its new battery or battery is good else it will not.
Note:In stone dead battery cant conduct volt because the electrons cant move so we called as stone dead battery technically.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 11, 2010
My Cordless Dyson has been plugged in for weeks & only offers short burst of power then goes dead
battery vacs run for 20 minutes on normal speed and 6 minutes on high speed
any thing less indicates problem battery pack
Sep 04, 2017 | Dyson Vacuums
My roomba irobot 700 series is completely dead after being disconnected for several weeks?
I noticed that when I started disconnecting my charger after it had recharged my Roomba, that it didn't run as long later. So I think that the Roomba needs to be sitting on the charger with the charger plugged in. I would put your's on the charger for two days and see if that does the trick.
How mechanically minded are you? Can you get a voltmeter and check what charge is coming out of your charger now? Can you access the battery and use a voltmeter to check what charge it has?
May 10, 2014 | iRobot Roomba 560 Robotic Vacuum
Why roomba clean for 2 minutes then returns to dock?
I suspect the battery is about dead. It keeps coming back for more power.
Run it away from it's charger, force it to run until it dies. Put it onto it's charger and let it charge a long time (Solid green light). Then run it again till it dies and repeat. This will perhaps force the battery to develop a longer memory
May 09, 2014 | iRobot Roomba 4210 Bagless Robotic Vacuum
I have a euralab robot vacuum and it is only lasting about 5 minutes before it runs out of power. I have had it for about 2 weeks and it worked well at first
I can't guarantee that this will solve the problem, but try deep cycling the battery.
Run the robot until it stops completely and uses all of the battery charge.
Charge the battery until fully charged. Let the battery cool for 6 hours.
Repeat and see if the battery life improves.
Repeat this charge/cool/discharge cycle 3 to 4 times.
Gary
Jul 15, 2011 | Vacuums
My scooba is not dispensing the water
Mine started doing thatafteri bought a new battery.
now i wet the floor lightly and let it run. after several minutes the solution comes out.
Jan 23, 2010 | iRobot 5900 Scooba Robotic Wet/Dry Vacuum
Stopped working a few weeks ago - bought and installed new battery seemed to be working OK - now after about a week, it goes for about 15 minutes then stops...
It may need a longer charging period to bring the battery up to full charge. If you have a voltmeter, measure the battery voltage while it is being charged--it should read several volts above the rated battery voltage. If nearly equal, the charge unit may need repair or replacement. Good luck!
Jan 04, 2010 | iRobot 4150 Roomba Vacuum
My Shark vacuum sweeper will run for 10 minutes and shut off. After it sets for 15 minutes it will run for 10 minutes more.
If it runs on NiCad batteries it probably has programmed batteries which can happen, best solution, get new battery, and use til dead before recharge, every time.
Nov 25, 2009 | Vacuums
Roomba 4200 Scheduler
The best for the battery if (NiMH). Discharge completly, than charge full (charge more even the charger indicates full charge)
Clean every part, maybe a hair slow down the wheels and thats why need more power.
Here some tip from the web:
With proper care, one iRobot Roomba battery can last for hundreds of cleaning cycles before you need to replace it. Here are some things you can do to extend Roomba's battery life and keep Roomba cleaning at peak performance:
Use your Roomba frequently. Your Roomba is powered by a rechargeable nickel metal hydride (NiMH) battery, which lasts the longest when you use it regularly.
Keep the brushes clean. If the brushes and brush axles get clogged with hair and other debris, your Roomba will strain to spin them, using more battery power than normal. In extreme cases, the battery can even be damaged. See How to remove and clean Roomba's brushes
Keep your Roomba plugged in when not in use. If you have a Home Base®, keep your Roomba docked in the Home Base and plugged into the charging brick. If you don’t have a Home Base, keep your Roomba plugged into the APS Fast Charger.
Make sure you are charging your Roomba correctly. When your Roomba is plugged in correctly, the solid green light should be illuminated on the charger or on the Home Base.
Plug your Roomba in as soon as possible after using Max Mode. Leaving your Roomba unplugged for more than 24 hours can damage the battery.
Place your Roomba and the Home Base on a smooth, hard surface when yourRoomba is plugged in. Make sure your Roomba and the Home Base have plenty of space for ventilation. Do not charge your Roomba on a carpet or rug.
Charge and store your Roomba in a cool, dry place. Keep your Roomba out of direct sunlight and away from sources of heat such as windows, radiators, heating vents, and large appliances.
Remove the battery when not using your Roomba for a long period of time. If you will not be using your Roomba for more than a few weeks, fully charge the battery, remove it, and store it in a cool, dry place. When you want to use your Roomba again, insert the battery and fully charge it. Leaving your Roomba plugged in for weeks when it is not being used can damage the battery.
You can purchase a second battery or replacement online at the iRobot Store.
Nov 11, 2007 | iRobot Roomba 4210 Bagless Robotic Vacuum
iRobot Roomba 530 Robotic Vacuum Logo
543 people viewed this question
Top iRobot Vacuums Experts
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
