Question about LG L192WS LCD Monitor
How to open LG Flatron L192WS model? I can't locate the screws
  • 11,361 Answers
Here are the sevice manuals: http://elektrotanya.com/?q=showresult&megnev=LG&megnev2=L192WS&kategoria=&kat2=all
Remove the base and any screws on the rear panel, I usually start at the bottom edge and work your way around using thin blade screw driver and be real careful with the cable attached to the front bezel.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Sep 12, 2010
I found two ants inside my monitor how can i remove them
Posted on Oct 19, 2011
Lg flatron L192ws DEAD CAN IT BE FIXED. shows no lights - nothing. Changed power leads but still dead.
A dead monitor indicates a power supply problem. If unit has an external power supply and you have have substituted it with another known working supply and the unit still does not work, then the problem lies within the monitor's circuits. Yes, it can be repaired, but it might just be cheaper to replace it due to high labor costs.
Jan 27, 2014 | Computers & Internet
How i can open my LG flatron w1943sb
In LG w1943sb monitor, screw is not used. .In this type 'press-lock' of cover is used. Did you have opened IR remote control, most remote control also used as this monitor's lock, and you can open with a flat screw driver.
Sep 02, 2011 | LG Flatron L1951S-SN 19" LCD Flat Panel...
I have problem with lg flatron monitor l192ws. its pixel so spread.
Good Day!
Maybe the problem is in your video card?
Try to change the setting of the resolution of your video card and restart your computer.
Thanks and God Bless!
Apr 20, 2011 | Computers & Internet
White display on my lg flatron L192ws
Most common problems with LCD monitors arises due to weak or damaged capacitors. Disconnect the power and signal supply from monitor, then open the case gently. Use a flat screwdriver for pry opening the case, after removal of screws. Here you have to look for faulty capacitors on the circuit. On the PCB of the monitor, check each capacitor for deformation/leakage around it. In case of any doubt, it's better to replace the capacitor, as they are inexpensive. The only thing is that you should use the correct rating capacitor for replacement. You will need a soldering iron, and at best a multimeter for carrying out the job. After doing all this, assemble the monitor back, and your monitor will be working fine.
Caution : If you are finding yourself uncomfortable with all the work doing yourself, then ask for help from a qualified technical person.
Nov 01, 2010 | LG Flatron 563LE 15.1" LCD Monitor
How do I Open / disassemble LG Flatron
Remove all the screws from the screen that you can, check for screws under all soft objects and labels, after all screws are removed, use a flat screwdriver or a case opener tool to start snapping the display cover open, it is hold in place with plastic clips, these will clip open but be carefull not to break any.
Sep 11, 2009 | LG Flatron L1750S 17" LCD Monitor
Acer netbook Aspire One doesnt support extarnal LG Monitor L192WS.How can I get the monitor to work properly?
First have you turned the port on for the monitor ? if not it usually is a function key like F2 ect. If this is done the right click on a free space on your desk top > then properties > settings tab ....and make sure you have two display checked in the drop box.
May 30, 2009 | LG Flatron L1750S 17" LCD Monitor
Where can I find driver for my LG Flatron L192WS?
Go there:
http://www.lge.com/us/support/product/support-product-profile.jsp?customerModelCode=L192WS-BN&initialTab=warranty
or
http://tinyurl.com/dyrzc4
Apr 06, 2009 | LG Flatron L1750S 17" LCD Monitor
FLATRON L192WS LG
hold de book buton 5 or 6 sek
Aug 10, 2008 | LG Flatron L1750S 17" LCD Monitor
LG L192WS LCD Monitor Logo
1,721 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
