Ware is the blower speed regulater located on a 94
  • 144 Answers
On a 94 what? the more info you give the better someone can help you
Posted on Sep 11, 2010
94 Plymouth voyager where is blower motor relay located
I believe you are looking for the blower motor resistor pack. Usually located on passenger front under dash/glove compartment area. The are normally held in with a couple of screws, screwed onto the HVAC unit itself.
Jan 12, 2016 | Plymouth Cars & Trucks
Location of high speed blower relay 1994 bonneville
98 shown, 94 similar. by the looks of it, this fuse block is under the hood.
Dec 05, 2013 | 1999 Pontiac Bonneville
Were would I find the fuse for an AC Blower Fan on a 1995 Ford Explorer ( 4.0) 5 speed
The fuse(Circut Breaker 30 amp) can be located in the fuse box located in the engine department.( I had a 94 with a similar problem. The fuse box on that explorer was in engine comartment)
Jun 17, 2011 | Ford Explorer Cars & Trucks
Let's say when i want to use my a/c or heater at times the blower doesn't blow. so i leave the blower on a certain level,(usually high so i know when it kicks on) then it will work and other times mainly...
U need to replace the blower motor speed control resistor, it is located near the blower motor plugged into the air ducting for cooling of the resistor, it is held in by two screws
Oct 25, 2010 | Ford Explorer Cars & Trucks
The fan on my 94 is not working for my ac...it just stopped..i was told to lookat the relay under the hood....problem is the location...any help
Could be the blower resistor. Did you loose any of the speeds recently first. It is located on passenger side where the carpet meets the firewall and is next to the blower unit.
Aug 18, 2010 | 1994 Pontiac Grand Am
I have a 94 Ford Explorer 4dr 2wd w/ac. When I
Remove the blower motor located under the hood on the passenger side in the evap. case. HEld in by 3 8mm screws. The fan blade may have broken .
Nov 15, 2009 | 1994 Ford Explorer Limited
I have a 1995 E300 D, the climate control fan stopped working
There is a resister pack called the blower motor regulater (they are a common problem). The fan and regulater are under the passanger side under dash panal. remove the panal and there will be a plastic cover retained by phillips or torx scres. remove that cover and you will see the blower regulater and motor. i would try replacing the regulater first because if the motor is bad it is recommended to replace the regulater as well. You can give the blower 12v or test the continuity of the circuit. You can also see if the regulater has any open circuits. Good luck I hope i have been helpful
Sep 09, 2009 | 1996 Mercedes-Benz C-Class
94 olds climate control blower will not shutoff with ignition off
REplace fan control module, purchase car repair book on your model and locate it. Common problem, fan could also oscillate in speed at times.
Mar 14, 2009 | Oldsmobile LSS Cars & Trucks
Air will not blow out makes a noise from time to time from heater and air
hello I'm an M.B. tech. this is a common problem for that era. I t sounds like your blower motor is worn ou and occasionally it will rotate slightly. 1st I would check the fuses. During this era those fuses were not in the box. although the lid may say blower fuse outside fuse box. Often times they are a strip fuse inline with the blower harness. Generally they are located by the brake master cyl. They supply voltage to the blower motor resister pack. Some vehicles had 3 strip fuses 1 for each speed. The resister pack is called a blower mot regulator. It should be accessible from you passenger side underdash panel. assuming your fuses are good. Most likley it is the blower motor regulater
Mar 12, 2009 | 1992 Mercedes-Benz Mercedes Benz 300 Class
94 Celica Heater not blowing
Could be a blown fuse for the blower motor or the blower motor itself is worn out. There is also a blower motor resister pack that could be at fault--it has three resisters in it that vary the blower speed--but it would be unusual for it to fail in such a way that the blower stops. Usually it just gets stuck on one speed. However, the resister is located down near your feet on one side (I forget which for that model) and if the wiring connector becomes unplugged (from an accidental kick), then the blower won't work.
Feb 21, 2009 | 1994 Toyota Celica
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
