Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
It won't turn on. It buzzes but that's - Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
  • 377 Answers
Blades are bound up. Unplug the unit under the sink and using an allen wrench (one should have come with the unit, looks like a bent rod with 8 sides on it), insert it into the manual turn fixture on the bottom center of the ISE. Use this to turn the unit by hand to see if you can free it. If you can free it, see if you can find something inside the sink drain that might have caused the blades to bind up. Remove any debris and reset the circuit breaker, a small button, on the bottom of the unit as well. Also, the ISE needs to hang straight down below the sink. If it is pulled one way or another due to the way it is hooked to the plumbing, the blades may bind up and keep from running.
Posted on Sep 12, 2010
  • pwillitz Sep 23, 2010
    Sorry you found no help in my solution.
  • pwillitz Oct 04, 2010
    Thank you very much for the rating!
When i turn it on, it buzzes and doesn't start
Sounds like the control board won't allow the motor to begin the cycle. Contact a professional for an accurate diagnosis.
Sep 03, 2012 | Frigidaire Affinity ATF7000E Front Load...
Dryer won't restart breakers ok door switch funtional but when i press srart button just buzzes......... suggestions?
Reach inside and try to turn the drum. If it is stiff you could have a bad roller or support bearing depending on your model. I have all kinds of dryer manuals HERE
and Here
Jul 07, 2012 | Dryers
My ge dryer model DRS483ED1WW won't turn on all it does is buzz when I try. I have changed starter switch that didn't work
does the drum and motor turn by hand freely. but i think its possibly the bushes in the motor. just have a look at motor and see if theres black carbon dust on it, you will get this on a motor anyway but not in excess
Jan 06, 2012 | GE DBSR453EBWW Electric Dryer
My Lennox ac is making a very loud buzzing sound and the fan blades are not turning. We replaced the dual capacitor and that seemed to fix the problem for a couple of days, now it's doing the same...
Fan motor is probably bad, if it is under 5 years old the parts are under warranty. Do not run the unit for very long without the fan working as it can damage the compressor.
Aug 23, 2011 | Heating & Cooling
I have a Maytag LSE1000. The dryer and washer each have an issue at the moment. The dryer intermittently won't engage when it is turned in. When you press the "regular" button to start it,...
I really have NO idea what's causing your Maytags to misbehave, BUT I can tell you that the Maytag service centers have always been very accommodating when I've called about problems with dishwashers, dryers, and washing machines.They have explained the construction of the appliance and even told me the type of tools I needed to make repairs! If you still have your owner's manual, the toll free number should be in there. I hope this helps!
Jul 28, 2011 | Maytag Dryers
Hi, my1999 mercury mystique sunroof will tilt but won't open. It makes a buzzing noise when I try. Is it a fuse or what?
If the fuse is bad you won't hear the actuator buzzing. Sounds like something has stripped or broke.
May 16, 2011 | 1999 Mercury Mystique
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
262 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
