Question about Homelite Garden
Homelite 25cc 2cycle trimmer.built in March of 1999. what is the proper oil to gas ratio?
    President:
  • Homelite Master
  • 1,545 Answers
If you use a synthetic 2-stroke oil, you can easily get by running a 40:1 ratio mix...that is 3.2oz oil/gallon of gas. A richer oil mix won't hurt either (say 20:1 (2X the oil of 40:1). I recommend synthetic always be used alongwith Stabil fuel treatment because after about 30 days, gas loses its volatility and begins to breakdown without it...causing fuel problems.
Posted on Sep 11, 2010
Need oil mix ratio for 25cc homelite gas trimmer
Hi anon the mix ratio is 50:1. That's five litres of unleaded and 100 ml of 2 stroke oil
Sep 10, 2014 | Craftsman 25cc Gas Line Trimmer
What is proper gas/oil ratio for homelite grass trimmer
Generally 2-cycle engines use ratios of 32:1 to 50:1. As a rule if you start with 40:1 you should be O.K. If your concerned that it might be to lean then start with 32:1 and if it smokes too much add 25% more gas to make it a 40:1 ratio.
Aug 02, 2010 | Homelite Garden
GAS TO OIL RATIO
Homelite products are 40:1 gas to oil ratio
May 28, 2010 | Homelite Mighty Lite Lawn Trimmer
Was given a homelite zipstart versatool string trimmer (25cc). what is the proper gas to oil ratio for this tool?
between 32:1 and 50:1 should be OK.
The best bet is to buy the premeasured 2 cycle fuel/oil mix in the bottles. They come with 8oz for a gallon of fuel.
Sep 23, 2009 | Garden
I got a second hand homelite trimmer but no manual....what is the oil to gas ratio needed to run this machine?
the most common is 32/1
you can buy 2cycle oil premeasured for easier mixing
Jul 30, 2009 | Garden
25cc trimmer gas ratio mixture
the correct ratio is 50-1 mix
Jul 01, 2009 | Homelite Garden
Oil/fuel ratio for 25cc model ut200006 2-cycle homelite trimmer?
All Homelite products should use 32:1 ratio.
Jun 24, 2009 | Garden
Homelite zip start 2cycle trimmer.
I had this same problem, would run a couple of seconds, stop, and you couldn't start it again.
Had good gas/oil mix 50:1 and 25cc Homelite. Had replaced the fuel filter, gas, spark plug, and took carb apart and cleaned with carb cleaner and primer bulb worked fine. None of that fixed it. What did? Take the muffler off and see if it will start and run with the muffler off. If it does, chances are the muffler is clogged. Also check the exhaust ports and clean them out if plugged with black oil carbon residue.
My muffler was clogged up, took it off, cleaned out the exhaust ports, there was some oil that was in the muffler(oil that didn't burn during combustion). It now starts and runs like a champ on first or second pull.
Mar 27, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
255 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
