Question about Garden
Craftsman Sander 315.117120 has begun smoking after mere minutes of sanding and sounds much weaker than it once was. Is this definitely a motor burnout issue, the motor is no longer sold by sears for this product, or could brush replacement fix the problem?
    Brigadier General:
  • 4,088 Answers
Brush failure usually doesn't produce much smoke--check the motor windings for apparent overheating. Replacement of the machine appears to be the best solution. Good luck!
Posted on Sep 12, 2010
Craftsman dual action sander model#875.199770. how do you remove sanding pad to replace with new one?
I used a thin vise grip to hold the spindle and the old rubber pad was easily removed.
Apr 17, 2013 | Craftsman Dual Action Sander
DeWalt DW 421 palm sander. Sander was working. All at once it lost power.Did not quit, just slowed down. When I lifted it off the board it sped up,but when I tried to sand again it slowed down-lost power....
From your description it sounds like the bearings on the armature seizing up . Mainly the bearing on the bottom towards the pad. I see it a lot . It'll seem ok when turned on but under a load it can stop , slow down , smoke ....I'd start by checking the bearings. If it was the cord power would cut in and out completely. It doesn't have a variable speed switch or any speed sensors on that model. .if you have any questions feel free to ask and give as much detail as possible plz.
Oct 01, 2017 | Dewalt Tools & Hardware - Others
I have and OLD bench 1
The local hardware store has brushes in all different sizes in a box, next to the switches, fuses, plugs, cords, tool type stuff. They are standard sizes, should be able to find them no problem. Hope this helps.
May 25, 2010 | Campbell Hausfeld Tools & Hardware -...
The Belt of my craftsman 3x21 sander slowly moves off track.
There is a leveling (screw/knob) on the side of the belt sander. Turn it up and the belt will drift in one direction. Turn it downward and the belt will drift in the opposite direction. play with this leveling screw/knob until you reach a good balance and the belt will stop drifting.
Dec 04, 2009 | Craftsman 3 x 21" Variable Speed Belt...
Orbital sander doesnt orbit!
Never start the Sander without first placing it against the surface to be sanded. In free air the Sander will not osolate.
Jun 12, 2009 | Makita BO5010 5" Random Orbit Sander
Hand sander stops spinning once placed on item to be sanded
This sander has a brake pad that is supposed to stop the rotation when the sander is not actually in use. It sounds like it's malfunctioning.
The only other thing I can think could be a cause of what you describe is an improperly assembled sanding base. Have you changed out the base, and if so, were you sure to properly align the replaced base on the machine before you tightened the allen screw?
If you're not comfortable disassembling a tool that is still under warranty ( I think it's two years for that one), I would recommend finding a Dewalt service center and taking it in for a factory service call.
Mar 24, 2009 | Black & Decker Black And Decker Cyclone 4...
Garden Logo
121 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
