Question about Brother PC-420
The auto threader won't thread the needle (it broke). I need to be able to replace the auto tthreader. The machine works otherwise. PRW PC-420
    Genius:
  • 1,788 Answers
Call 1-800-276-8437 and order one right from Brother, or go to sewingpartsonline.com
Posted on Sep 11, 2010
  • Mary Dunn Sep 11, 2010
    Sorry the number for Brother is 1-877-276-8437, not the above number, their website is brother-usa.com. Good luck
Brother PC-420 sewing machine wont switch on at all.
Take off the slide plate and reseat the bobbin case. Can you turn the handwheel by hand now? If not, you may have a thread jam that seized the machine causing the security device to activate to prevent further damage. This doesn't seem like a situation that would fry a board, but if it moves freely, but still won't turn on; take it to a technician or return it.
Sep 04, 2016 | Brother PC420-PRW Project Runway...
Can the automatic threader be fixed can i do it myself?
Depends what is wrong with your needle threader. Needle threaders tend to be very fragile parts so it is not uncommon for them to stop working. You may be able to replace the part if it is broken but it may be a job trying to find the part. Search the internet for parts for the make & model of your machine. Once you get the part, search the internet (YouTube) for videos showing how to replace the part.
On the other hand, it is not a serious problem if the auto-needle threader does not work. These options were not available until the most recent sewing machines were manufactured and your machine will most likely operate for many years despite the broken needle threader. Manual threading was all that was available for over 100 years.
HINT: To help make needle threading easier, lick your forefinger then swipe the back of the needle's eye. The moisture in the eye will help pull the thread through.
Nov 11, 2015 | Sewing Machines
Auto threader wont thread
Move the needle to the top.
Loosen the screw on the threader.
Use the threader as if you are using it. You will have to adjust it to the side and up or down. Move it so the threader is in the needle hole.
Tighten the needle.
If it still doesn't work you may need to replace the threader.
Apr 18, 2015 | Sewing Machines
Automatic needle threader won't work on brother pe-770
Always make sure the hand wheel is at the exact top. Have you replaced the need recently? If it's bent, then the threader will not work. If the needle is loose or not all the way to the top in the holder, it will also cause the threader to not work.
Jan 06, 2013 | Brother PE770 Computerized Sewing Machine
The self threader won't catch the thread
make sure the needle is inserted correctly into the needle holder
if the needle threader has worked before then there could be something
wrong with the needle threader
here is a link for a manual
http://www.singerco.com/uploads/download/545_7470-instruction-book-engfrespa.pdf
Dec 13, 2012 | SINGER 7470 Sewing Machine
The threader to the needle wont catch the thread
It takes some getting used to, to get these to work properly. Practice. First make sure your needle is in correctly and fully. then make sure that when you engage the needle threader the tiny little hook goes through the eye of the needle. If it doesn't it won't work at all.
Then follow the instructions in the book. Make sure the thread is on the proper side of the tiny hook....
Good luck
Aug 08, 2012 | Euro-Pro Fast and Easy 420 Mechanical...
All of a sudden, the needle threader won't work. First I noticed the upper thread broke, and then I tried over and over to re-thread the needle. After a while I gave up. I finally replaced the needle and...
I don't know much about Brothers but the first thing I do with any new machine I get it to get rid of the needle threader if it is in my way. They never work and with use they start to shread the tread.
I use a bright light and a strong pair of glasses to hand thread it. I use tweasers on my more difficult machines.
You may have a lemon of a needle threader too. It happens. There are sharp barbs that we can not see but the thread has a hard time catching on them and most of the problem seems to be in the threader letting loose of the thread as it is caught on these barbs.
Dec 18, 2010 | Brother CS6000i Computerized Sewing...
Cant make the auto threader work on an elna 2007
Do you mean the auto needle threader?
Mine won't work on very small needle sizes so I resort to the old manual needle threader for these. Ditto for twin needles.
Otherwise its a case of pulling the auto threader down so the hook swings into the needle eye, then pulling the thread over the face of the needle and catching it into the hook, then release the threader so it pulls back through the needle eye, taking the thread with it.
The only other thing that springs to mind is "is the needle at the top position in its stich cycle so that the threader lines up with the needle eye?
hope these ideas help a little.
Dec 03, 2010 | Elna 2007 Mechanical Sewing Machine
AUTO THREADER CAME OUT
When you activated the threader, the needle was down and the threader came off or broke.
If it is not broken, you may be able to push it back into place.
Turn off the power and tip the machine back on some towels so it does not slip and with a flash light check the area where it fits and see if you can get it back into position.
If not, will have to thread the needle the old fashion way.
Check with your Brother dealer to see if they can look at the machine while you wait.
They may be able to get it back together or they will have to replace the threader.
It is possible they will have one in stock, or they may have to order it.
May 01, 2010 | Brother CS-8060 Computerized Sewing...
I need a replacement Auto needle threader. There seems to be no where that I can find the pat numbers for anything on the machine....Euro-Pro 9106 Deluxe Denim & Silk sewing machine.
I've never had an auto needle threader work properly for very long. My suggestion is to not bother to replace it and just relearn how to thread the needle. Sorry.
Jan 13, 2010 | Euro-Pro 9105 Computerized Sewing Machine
Brother PC-420 Logo
133 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
