Our front loading washing machin P/N 1344535000409 isn't spinning out our loads to dry, so the items are still soaking wet after the cycle.
Krazytech
  • 725 Answers
SOURCE: clothes soaking wet after cycle completed
looks like you washer is not spinning your clothes out and maybe not agitate them either. Start your machine normaly on heavy load, watch it and check if it fill and moves back then drains and goes into a spin.. if water is still in the machine then you may have something stuck in the drain. If it fulls and drains then you may have a motor or control problem. If its still under warranty you will need to call authorized repair service or authorized frigidaire service. if not under warranty and you want to repair it yourself let us know and we can help.
Posted on Sep 15, 2007
SOURCE: GE Front Loading Washing Machine seems to be holding water....
manual
Posted on Mar 21, 2008
SOURCE: LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
Posted on Jan 08, 2009
  • 107 Answers
SOURCE: My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Posted on Mar 13, 2009
SOURCE: Washer won't go through spin cycle
this happened to me. there are other things it could be but i was told the most common is a broken or unhooked suspension spring. I'm a housewife and i fixed it myself in about 30 min.
Posted on Aug 06, 2009
What will cause my Whirlpool washing machine to set on low speed spin cycle?
The machine uses automatic load sensors to balance the load and when you put something in the machine that is big, like a comforter, it knows that it cannot balance that item. So with a front loader it wont spin at high speed because it would be off balance and either damage the machine or the machine would "walk" because of the off balance motion.
Apr 28, 2014 | Whirlpool Washing Machines
Washing Machine Won't Spin Dry Clothes
You may be overloading the machine. Just because you got them all in there and wet, doesn't mean there was enough room for them to get a good washing. Cut back on size of the load (make sure you have large load selected) and see if that doesn't help you.
Jan 22, 2014 | Kenmore 44932 Front Load Washer
I have a Whirlpool WFC7500V Front Load Washer and after the load is done the clothes are still soaking wet, is there a step i am missing why are the clothes still really wet. Do i need to drain or is the...
What spin cycle are you using? Try a faster spin option. (The wrinkle release setting uses more water and a lower spin speed.)
Try putting fewer items in a load in the futute and make sure it isn't unbalanced. (One really heavy item could imbalance the load and shift the spin efficiency.) Redistribute the clothes and run a Drain/Spin cycle.
Make sure to use HE detergent (don't use more than the recommended amount of detergent).
The other issue to check is if the machine is draining properly. Check that the drain hose isn't clogged. Also check the voltage at the washer - low voltage will result in a slower spin cycle. To correct this, you probably will want to call an electrician.
I hope this helps.
May 05, 2011 | Whirlpool Washing Machines
My neptune front loading washing machine will not spin on the spin cycle. Clothes are soaking wet.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 05, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Spin cycle is not working. clothes are soaking wet when cycle is finished.
heatman101
Dec 21, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
When I put towels or rugs in the washer the cycle show complete, but when I open it the items are soaking wet.
Its probably because the items are too heavy for the washer to safely spin.
If you squeeze some of the water out of them into a sink then put it on spin cycle, it should work. Otherwise spin them in two loads. Its a bit of a pain but its to protect the washing machine mechanical parts.
Hope that helps!
Dec 29, 2009 | Kenmore 43142 Front Load Washer
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Jan 07, 2009 | LG WM-1832C Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
