Question about Boating
Where do u add gear case oil - Boating
  • 677 Answers
Without a model its a bit hard.But.On the lower bulge of the g/box is a screw.Up near the cavitation is another that looks the same.You remove both.Pump the oil in the lower hole untill it comes out the top hole.Quickly put both back in.Job done.Hope this helps
Posted on Sep 12, 2010
How can I add gear oil to transfer case?
Any good DIY home mechanic would be able to slide under, find the level plug and check it. Oil and Fluid Capacities
Go to this site, select suv/small truck, find Mitsubishi etc, scroll down, select engine version, click, and all the capacities and oil specs are there.
Feb 15, 2016 | 2000 Mitsubishi Montero Sport
Where do you add gear oil on a 2006 yamaha vk pro
There should be a dip stick on the chain case remove it and add oil there. until it is full on the shight glass.
Hope this helps.
Feb 15, 2014 | Yamaha 2006 VK Professional
How many qts of oil do i need
Depends on your engine.
1980 JEEP CJ-7 2.5L 4-cyl Engine Code [B]
CAPACITIES
Engine, GM without filter..........2.4 quarts[1]
Wix Filter ........ 51040
Cooling System, Initial Fill..........8.0 quarts
Automatic Transmission, A904, 30RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, A999, 32RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, Total Fill
3 speed A999, 32RH..........8.4 quarts
3 speed A904, 30RH..........7.0 quarts
Manual Transmission, 4-SPD, SR-4..........3.0 pints
Manual Transmission, 4-SPD, T176..........3.6 pints
Differential, Front..........2.5 pints[3]
Differential, Rear..........4.9 pints
Transfer Case,..........4.0 pints
1. Add extra oil when replacing filter. After refill check oil level.
2. With engine automatic transmission operating temperature, shift through all gears.
Check fluid level in NEUTRAL and add fluid as needed.
3. 1984-1992 Models with command-Track, add 5 oz of 75W-90 GL-5 to shift motor housing opening.
TORQUES
Oil Drain Plug.....25 ft-lbs
Manual Transmission T176
Fill Plug.....15 ft-lbs
Drain Plug.....15 ft-lbs
Manual Transmission SR4
Fill Plug.....20 ft-lbs
1980 JEEP CJ-7 4.2L 6-cyl Engine Code [C]
CAPACITIES
Engine, without filter..........5.0 quarts[1]
Wix Filter..... 51522
Cooling System, Initial Fill..........11.0 quarts
TORQUES
Oil Drain Plug.....30 ft-lbs
1980 JEEP CJ-7 5.0L 8-cyl Engine Code [H]
CAPACITIES
Engine, without filter..........4.0 quarts[1]
Wix Filter..... 51258
Cooling System, Initial Fill..........13.0 quarts
TORQUES
Oilman
Feb 02, 2013 | 1984 Jeep CJ7
Why does gears 1 and 5 work normal but 2 thru 4 has a grinding metal sound? sounds pretty bad.Does the trans. have a separate oil resevoir? 2004 883 sportster
Yes the primary case-transmission require it's own oil as the lubricant for this area is not provided by the engine oil. There is a drain plug located at the lower point of the case. Remove the plug and drain any oil that may be in the primary case. When finished, add one quart of oil to the case through the access hole at the top of the primary case where you check the tension on the primary chain.
Good Luck
Steve
Aug 01, 2011 | 2004 Harley Davidson XL 883 Sportster
Were do you the put gear oil in on a 1984 chevy S-10 4x4 p/u
OK, if you are talking about the differential, there should be either a plug at the top of the differential case or there should be a ventilation tube connected to this area.
Add Gear Oil of the weight recommended by the manufacturer to this inlet, and replace the plug or tube that connects to this.
Oct 13, 2010 | Chevrolet S 10 Cars & Trucks
Some gears can not get engaged. specifically my reverse, gear two and five simply can't be engaged. how can i solve this problem?
If you can engage 1st gear, it rules out any clutch problems. If gear case ran low on oil, for a prolonged time, it could cause this. If this is the case, flush transmission oil, and add a manual gearbox additive, in order to prolong life and diminish damage already done.
Other likely possibilty is that a synchronizer ring went bad for second gear, since that synchro is shared for all the gears that you mention.
Dec 26, 2009 | 1993 Toyota Corolla
What is the capacity of the transfer case and exactly what fluid do i use
GM Full-Size Trucks 1980-1987 Repair Guide
Transfer Case - FLUID RECOMMENDATIONS
The type of lubricant used in the transfer case varies with model year and type of transfer case. Refer to the list below for the type that applies to your truck.
1980
Conventional transfer cases require SAE 80W or SAE 80W-90 GL-5 gear lubricant.
Full time systems use SAE 10W-30 or 10W-40 engine oil.
1981
Conventional transfer cases require DEXRON®II transmission fluid.
1982-85
All transfer cases require DEXRON®II transmission fluid.
1986-87
All transfer cases except the K30/35 series require DEXRON®II transmission fluid.
For fluid recommendations for the K30/35 transfer cases refer to the owner's manual.
LEVEL CHECKS
Fig. Model 208 Transfer Case
Check the four wheel drive transfer case lubricant level every 4 months or 6,000 miles.
  1. With the truck parked on a level surface and the parking brake firmly applied, remove the filler plug from the rear of the transfer case (behind the transmission). Be careful not to take out the drain plug at the bottom.
  2. If lubricant trickles out, there is enough. If not, carefully insert a finger and check that the level is up to the edge of the hole, EXCEPT in full time four wheel drive cases should be 1 /2 in. below the hole.
Lubricant may be added, if necessary, with a funnel and tube, or a squeeze bulb.
DRAIN AND REFILL
Part Time Systems
No intervals are specified for changing transfer case lubricant, but it is a good idea for trucks that are worked hard or driven in deep water.
  1. With the transfer case warmed up, park on a level surface and apply the parking brake.
  2. Slide a pan of a least 6 pts. capacity under the case drain plug.
  3. Remove the filler plug from the rear of the transfer case (behind the transmission). Remove the drain plug from the bottom.
  4. Wipe the area clean and replace the drain plug.
  5. Add lubricant with a suction gun or squeeze bulb. Conventional transfer cases require SAE 80W-90 GL-5 Gear Lubricant.
  6. When the lubricant level is up to the bottom of the filler hole, replace the plug.
Full Time Four Wheel Drive
The full time system requires oil changes at regular intervals, according to the amount and type of work done by the unit. Trucks used for normal on-off road work should have the transfer case oil changed at 24,000 mile intervals. When used for heavy duty work, trailer towing, snowplowing, and the like, the interval should be halved to 12,000 miles. If the truck is exposed to extremely dusty or muddy conditions, the oil should be changed at 1,000 mile intervals.
The transfer case oil must be hot before changing. Drive the truck until the engine has reached normal operating temperature, and park on a level surface.
  1. Slide a pan of at least 8 pts. capacity under the case drain plug.
  2. Remove the filler plug.
  3. Remove the lowest bolt from the front output shaft rear bearing retainer cover, and allow the lubricant to drain. Be careful; the oil will be hot. There may be a drain plug. If so, remove that instead.
  4. Remove the six bolts on the left (driver's) side of the case which secure to P.T.O. (power take-off) cover. Remove this cover and allow the lubricant to drain out.
  5. Remove the speedometer driven gear from the upper left rear corner of the case.
  6. Use a suction gun to remove as much lubricant as possible from the case cover location and the speedometer gear location.
  7. Install the speedometer driven gear, the P.T.O. cover, and the lowest bolt or drain plug.
  8. Add approximately seven pints of oil through the filler plug opening. The proper oil to use is 10W-30 or 10W-40 engine oil.
  9. Check the fluid level and add sufficient oil to raise the level to 1 /2 in. below the filler plug opening. Replace the plug, and wipe the surfaces of the case and skid plate to remove any excess oil. Drive the truck and check for leaks.
I really hope help ypou woth this (remember rated this help) Good luck.
Oct 16, 2009 | 1983 Chevrolet Silverado
What kind of ATF goes in my 1992 cherokee?
Use ATF+4
Do not use Dexron or Mercon
Aug 08, 2009 | 1992 Jeep Cherokee Sport
I need to change the oil in the transfer case but i dont know what kind to use or how much.
your transfer case does not use regular motor oil..it will use gear oil which can be purchased at any local parts store or even wal-mart (most part stores can tell you how much you need to add to the unit but a good rule of thumb is add the gear oil until it starts to drip out the fill/check hole..
Jul 30, 2009 | 2003 Chevrolet Blazer
Trying to add correct volume of oil
there is an oil site glass on the trans case, the oil will not cover the gears, the oil level should be at the 1/2 way point of the site glass window.
May 03, 2009 | Honda Accord Cars & Trucks
Boating Logo
52 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
