Question about Microwave Ovens
How much vinergar do put in a 12 cup coffee maker when cleaning it
  • 490 Answers
Howdy, 1 part vinegar to 3 parts water. Pretend you are making a pot of coffee. It is recommended to do this every 2 months or so, more oftenif you have really hard water.
Regards,
Farmerbear at FixYa.com
Posted on Sep 12, 2010
We have a Mr Coffee 10 cup thermal programmable coffee maker COF FTTX95-1 The clean light is blinking and I can't figure out what else to do. HELP!
When the clean light is blinking it is saying that the tubes are blocked up with mineral deposits. If you waited until the light in blinking then it is going to take some time for a vinegar clean to work.
Just put vinegar where you normally put the water, and let it perk about 1/3 of the water through, and then shut it off for 30 minutes. Then restart and let it perk another 1/3 through. Let set for 30 minutes. Then let it complete the cycle.
Take a look at the output vinegar, if there is a lot of chunks in it, strain it using a coffee filter and then reuse the same vinegar and do it again. Keep repeating until the light is out and the vinegar no longer get the chunks.
Jul 13, 2011 | Microwave Ovens
We have a 12 cup Mr. Coffee about a year old. We put 4 scoops of coffee in and the appropriate amount of water. Every day, the filter overflows and grains of coffee get into the pot. How do we keep this...
Because I own a espresso company,I believe I can help you. There is several things that can cause a coffee machine to over flow. 1, putting to much coffee in, where water can not drain through filter. 2. The grind of the coffee, if it is ground to fine, like ground for espresso, will not allow coffee to flow through filter , drip machine that are not under high pressure like espresso machines have to have ground more course. 3, wrong type of filters, not fine enough for water to flow, or made for high pump pressure machine such as espresso machine . 4, putting to much water in, is not an issue on a mr coffee, because even if you fill it to full cup line, it would have nothing to do with filter over flowing, besides the coffee grounds always absorb some of the water anyway. In conclusion, my positive professional diagnose is Grounds of coffee to course, and 4 scoops seem a bit to much for a filter of a mr coffee machine that holds only 12 cups. To test this is make a pot same way and use only two rounded scoops and see what happens, if does not over flow that solves that. But your saying I want it stronger, believe me I know. I too like my coffee strong and a flavorful . I have that solved too. Go to a good walk in espresso shop, like a star bucks, tell them you want some good strong blend and have it ( Ground for Drip) and then still only put two rounded scoops, it takes less do to the blend and kind of coffee. Please let me know if my advice worked, thanks mike. oh notice my screen name of mc1 bean, now you know, I know what I am talking about :)
Jun 07, 2011 | Microwave Ovens
Keurig Coffeemaker says to descale. How do I do that?
Hi, unplug the coffee machine and remove the cup.
Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
Unplug the machine and dump the water into the sink.
Fill up the reservoir with fresh, clean water and plug it in. Place the ceramic cup back on the drip tray and run multiple brews in order to rinse the machine of any remaining vinegar residue.
Apr 28, 2011 | Microwave Ovens
How do you go about "descaleing" the coffee maker? The water does not flow through the coffee capsule very well.
I know that most grocery stores sell a "cleaner" or two next to their coffee filters/coffee makers/kitchen appliances section. These are usually heavily acidic, and will do a great job of cleaining your coffee maker. I've always been wary of acid in my coffee though, so I just use white vinegar. It'll do a decent job of cleaning out the coffee maker. Run a 1:1 mix of water and vinegar through your coffee maker, drain it, then run water through at least twice.
Scaleing/deposits building up in a coffee maker are signs of imperfections in the water. All tap water has it, but if you don't want to worry about it, use bottled or filtred water in your coffee pot. Plus, your coffee will taste better!
Mar 16, 2011 | Microwave Ovens
My 12 cup coffee maker does not keep the coffee hot after it has been made - whats wrong with it......
The heating element is open on the warming plate, cheaper to replace the coffee maker for a new one.
Feb 27, 2011 | Microwave Ovens
My coffee maker has stopped making full size coffee cups - it spits a bit of water out and then stops
put some vinger and water mixed and see if this cleans out resdue from water out of the lines.
How to program my Hamilton beach Coffee Maker,49464 To make coffee in the am before I get up.
12 Cup Programmable Coffee Maker 49464 could help you to operate your Hamilton Beach Coffee Maker. Anyway, if you are looking for a best coffee maker that can extract a perfect cup of coffee, allbestcoffeemakers.com is a great choice. Hope it helps you!
Nov 30, 2010 | Hamilton Beach Microwave Ovens
How much coffee grounds should I use for 30 cups of coffee made in a west bend 30 cup coffee maker?
!/4 cup of coffee for every 8 cups of water or almost a full cup of coffe for your 30 cup pot...
heatman101
Sep 07, 2010 | Microwave Ovens
Microwave Ovens Logo
22 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
