Question about HP Photosmart D7360 All-In-One InkJet Printer
After getting a message from the printer (HP D7360) indicating the yellow ink cartridge needed to be replaced, I installed a new yellow (02) ink cartridge. I recieved the same message after replacing the ink cartridge. I replaced it with another new yellow ink cartridge. Got the same message. Printer will not allow printing in color until all cartridges have sufficient ink. The cartridge in the printer now does have ink in it. I tried following the following "FixYa" suggestion but to no avail. TheSelkie Rank: Guru Rating: 86%, 58 Votes Assuming you were careful to take off the little strip of cellophane tape that protects the ink from coming out of the cartridge, then I suggest you open a document and type a few words and choose ONLY yellow as the color. It will either activate the cartridge or you'll know that you have a sensor/software problem and not a hardware problem. Any other suggestions?
  • 3 Answers
Hp support>d 7360>software and drivers>diagnostic utility (2010-11-09). download (run). Test and print test page which is only one sentence. worked for me.
Posted on Nov 14, 2010
HP Photosmart D7360 ink system has failed. How do I fix this?
with 2 new cartridges installed, shut the machine off and back on again.
Jan 06, 2015 | HP Photosmart D7360 Digital Photo Inkjet...
How to fix Ink System Failure Oxc18a0206 error message?
Hi John,
Please do check this link which will give you the detailed steps about the HP Cartridge Printer issue that you have
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00786043&cc=us&lc=en&dlc=en&product=439491&tmp_track_link=ot_search
Jul 13, 2014 | HP for D7355 D7360 D7460 D7355 12 Pack 02...
Despite a new full original HP Yellow ink cartridge I still get a message the the cartridge is empty and as such the printer will not print. I thought I had a defective printer cartridge so I took the...
How to Clean the printhead
  1. Open the All-in-One Toolbox:
    1. Open HP Solution Center (click Start, click All Programs, click HP, and then click HP Solution Center).
    2. If you have more than one All-in-One installed, make sure to select the correct All-in-One tab in HP Solution Center.
    3. Click Settings.
    4. Click Print Settings.
    5. Click Printer Toolbox.
  2. On the Device Services tab, click Clean the Print Cartridges, and then follow the onscreen instructions. Three levels of cleaning are available.
Dec 27, 2017 | HP Photosmart D7360 All-In-One InkJet...
The printer indicates that the yellow ink cartridge is empty even when it is replaced with a new cartridge.
Good Luck
Sep 11, 2010 | HP Photosmart D7360 All-In-One InkJet...
Photosmart D7360 - message says "ink cartridge empty. To print in color, install the following cartridges: yellow. To print in black ink only, press o.k." I have replaced the cartridge (yellow) and the...
go to hp support>d 7360 >software and drivers. Download (run) latest diagnostic utility 2010-11-09. run test and print test page (only one sentence). worked for me. Took about one minute.
Sep 10, 2010 | HP Photosmart D7360 All-In-One InkJet...
Ink system failure error telling me to refer to printer documentation error 0xc18a006
The "Ink system failure" error is caused by air in the ink feed tubes, this happens if you use poorly filled cartridges or allow you cartridge to run all the way out. We have a step by step guide to purge the ink feed tubes posted on our web site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ This should get your printer back going in about 10 minutes.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jun 02, 2010 | HP Photosmart C6100 All-In-One Printer
How do you take the right side off a HP D7360?
Follow the steps below to resolve this issue.
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.If the error codes still display on the front panel, service the printer.
Dec 29, 2009 | HP Photosmart D7360 All-In-One InkJet...
HP Photosmart D7360
HP support decided it could not be repaired on line, agreed to replace it but found it was a few days out of waranty...so it is dead in the water. Probably not cost effective to repair it.
Aug 03, 2008 | HP Photosmart D7360 All-In-One InkJet...
HP Photosmart D7360
try cleaning the cartridge contacts with alcohol and cotton swab.
Jan 16, 2008 | HP Photosmart D7360 All-In-One InkJet...
HP Photosmart D7360 All-In-One InkJet Printer Logo
156 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
